[Plugin] BezierSpline - v2.1a - 01 Nov 18
Re: [Plugin] BezierSpline - v1.9a - 12 Feb 17
Postby Dave R » Fri Feb 02, 2018 7:32 pm
If you want to keep the curve in 2D, it's best if you start out by drawing it on a large rectangle. Or, you can set the camera to Parallel Projection and selected the appropriate standard view befor editing the curve. I like the large face option myself.
Global Moderator
Postby robertWan » Fri Feb 02, 2018 7:47 pm
Dave R wrote:If you want to keep the curve in 2D, it's best if you start out by drawing it on a large rectangle....
Or use the plugin WorkPlane.
Robert
robertWan
Postby jayaha5 » Mon Feb 12, 2018 10:35 am
thank you
jayaha5
Postby raguenther56 » Sun Feb 25, 2018 5:47 pm
I am using v1.9 with Sketchup Make 2017 on a Mac. Some of the curves do not allow me to edit them after being created. After selecting the curve, with a right-click I get the standard menu items and not the editing options. Some curves work and some don't. I've seen this with the Cubic Bezier Curve and Catmull Spline. It appears to have something to do with the number of control points. Simple curves and its OK. Curves with more control points and I loose the edit function. Any suggestions?
raguenther56
Postby Dave R » Sun Feb 25, 2018 5:50 pm
Share an example SKP file showing a curve that you can't edit.
Global Moderator
Postby fredo6 » Sun Feb 25, 2018 6:05 pm
raguenther56 wrote:I am using v1.9 with Sketchup Make 2017 on a Mac. Some of the curves do not allow me to edit them after being created. After selecting the curve, with a right-click I get the standard menu items and not the editing options. Some curves work and some don't. I've seen this with the Cubic Bezier Curve and Catmull Spline. It appears to have something to do with the number of control points. Simple curves and its OK. Curves with more control points and I loose the edit function. Any suggestions?
Be careful that a contour generated by BezierSpline must remain a Sketchup Curve to be editable. If you cut it by another edge intersection or explode it, it won't remind that it was created by BezierCurve.
As Dave said, maybe it's best to post a sample model where you have the problem.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby raguenther56 » Sun Feb 25, 2018 7:49 pm
Curve on right is OK. Curve on left I can't edit. Both were made using Cubic Bezier Curve with precision set to 20.
raguenther56
Postby raguenther56 » Sun Feb 25, 2018 8:15 pm
I did some additional experiments. Drew a simple curve with Cubic Bezier Curve that I was able to edit. From there I added control points one at a time while editing. Once I got to 24 control points (not counting the two end points), I could no longer edit the curve. A right-click gave me the standard menu selections.
The attached file has two curves. The one on the right can be edited. The one on the left is a copy of the right curve, but one more control point has been added. It is no longer editable.
raguenther56
Postby fredo6 » Sun Feb 25, 2018 8:55 pm
Thanks for signaling.
Actually, it is not related to the number of control points but to the number of edges of the curve.
For whatever reasons, there was a limitation to 500.
I will republish without the limitation.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] BezierSpline - v1.9b - 25 Feb 18
Postby fredo6 » Sun Feb 25, 2018 9:52 pm
NEW RELEASE 1.9b - 25 Feb 18
This release increases the maximum number of points in curves, even if it is not advised to have too many points in a curve.
Download new release at main post
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby raguenther56 » Mon Feb 26, 2018 1:02 am
Thanks! The update works great. I love this tool as I would not be able to do what I want without it.
raguenther56
Postby Einstein » Wed Apr 04, 2018 10:33 pm
Please, in the next release, make "Redo last change" to quickly compare changes when editing control points.
Einstein
Re: [Plugin] BezierSpline 1.9a - 25 Feb 18
Postby sashagas » Thu Apr 05, 2018 3:21 pm
Hello!! Tell me why I can not install the plugin
BezierSpline 1.9a. It does not appear on the toolbar, although it is installed. I can not understand what's the matter, the side plugins work.[img][img][img][img][/img][/img][/img][/img]
sashagas
Postby cotty » Thu Apr 05, 2018 4:07 pm
sashagas wrote:Hello!! Tell me why I can not install the plugin
LibFredo is installed too?
cotty
Top SketchUcator
Postby Einstein » Thu Apr 05, 2018 11:53 pm
Right-click on free space in your toolbar and check if there's BezierSpline in the drop-down list. If so, check it. If not, restart SketchUp or even your computer and check again. If it still doesn't work then I don't know.
Einstein
Re: [Plugin] BezierSpline - v1.9c - 31 Jul 18
Postby fredo6 » Tue Jul 31, 2018 9:08 pm
NEW RELEASE 1.9c - 31 Jul 18
This release fixes issues related to non-ascii Windows usernames.
More info at main post
Download BezierSpline at Sketchucation Plugin Store
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] BezierSpline - v2.0a - 01 Aug 18
Postby fredo6 » Wed Aug 01, 2018 7:47 pm
NEW RELEASE 2.0a - 01 Aug 18
This release fixes other issues related to non-ascii Windows usernames.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby delandc » Thu Sep 06, 2018 4:42 am
Just what I was looking for. I'm having some issues with a few of the tools. I'm in Sketchup Make 2017 and the polyline arc corners is acting odd. I click the first couple of points and then the whole line vanishes. Uniform b-spline... same. Thoughts?
delandc
Postby autumnwind » Fri Sep 28, 2018 5:13 am
Hi Fredo, thanks so much for your plugins, they are incredible.
I particularly like Bezier Spline, but I have a problem: I absolutely cannot control the "control points" when I decide to move them along the axis.
I'm working on a uniform spline, a press CTRL and then the desired arrow for the axis direction, then when I drag the point with the mouse, even a super small movement makes the point go super far. Moreover, when I move along the axis, in reality the points sticks to other points in the drawing instead of just moving along the axis. Is there any solution to this?
I hope I was clear. Thanks in advance.
autumnwind
Re: [Plugin] BezierSpline - v2.1a - 01 Nov 18
Postby fredo6 » Thu Nov 01, 2018 1:59 pm
NEW RELEASE 2.1a - 01 Nov 18
This release fixes issues related to the size of toolbar icons for highDPI screens.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby multitabs » Sat Nov 10, 2018 4:00 pm
Hi Fredo, thanks so much for your plugins. Without them it would be very hard.
Was the idea to reduce the Tool Bar to save space?
multitabs
Postby gr8dane » Sun Jan 20, 2019 12:16 am
I just downloaded BezierSpline_v2.1a.rbz from the Plugin Store and then installed it from SU's extension manager (I have SU Make 2017 on a PC, by the way). It seems to have installed properly, but when I click on Documentation in the menu, nothing happens. So I downloaded the Quickcard and Tutorial PDFs, as well, but I don't know how to make them available from the menu (assuming they should be, of course). Are these PDFs the only documentation available, or is something missing?
gr8dane
Postby fredo6 » Mon Jan 21, 2019 7:11 am
gr8dane wrote:It seems to have installed properly, but when I click on Documentation in the menu, nothing happens. So I downloaded the Quickcard and Tutorial PDFs, as well, but I don't know how to make them available from the menu (assuming they should be, of course). Are these PDFs the only documentation available, or is something missing?
This is the only doc I wrote. If you put the PDF file in the Plugins directory, then it will be available from the menu.
fredo6
PluginStore Author
PluginStore Author
Postby gr8dane » Tue Jan 22, 2019 12:12 am
fredo6 wrote:If you put the PDF file in the Plugins directory, then it will be available from the menu.
I placed Quickcard BezierSpline - English - v1.2.pdf and Tutorial BezierSpline - English - v1.2.pdf in C:\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins, as you said, but still nothing happens when I click on Draw > BezierSpline curves > Documentation... .
BTW, your link to Scott Onstott's tutorial leads to a non-existent page.
gr8dane
Postby fredo6 » Tue Jan 22, 2019 12:23 pm
gr8dane wrote:I placed Quickcard BezierSpline - English - v1.2.pdf and Tutorial BezierSpline - English - v1.2.pdf in C:\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins, as you said, but still nothing happens when I click on Draw > BezierSpline curves > Documentation... .
Sorry, you have to put it in the bezierspline subfolder in the Sketchup Plugin directory. I forgot that bezierSpline is not based on LibFredo6
gr8dane wrote:BTW, your link to Scott Onstott's tutorial leads to a non-existent page.
Thanks for signaling. not surprising for a site which was around more than 10 years ago. I just removed the link.
fredo6
PluginStore Author
PluginStore Author
Postby gr8dane » Tue Jan 22, 2019 9:48 pm
fredo6 wrote:Sorry, you have to put it in the bezierspline subfolder in the Sketchup Plugin directory.
Thanks, that did the trick.
gr8dane
Postby reza1813 » Sat Feb 09, 2019 11:10 am
Dear Fredo,
Hello, I kindly reach you to suggest some feature for the future update of BezierSpline.
1. As you know there is a feature in Rhino software which you can change the point easily in 2D and 3D and it is Gumball. BezierSpline in the current version, you can change the point in the 2D position very quickly but when I wonder to change the point in 3D axes, I have some problem(Of course when I want to do it, I definitely push up arrow on my keyboard and also be in Front view). Therefore, I really wonder to ask you, would you add Gumball feature for next Update?
 Note: This type of Gumball already exists in the Vertex Tool of @thomthom which can help properly but I thought if this feature will be developed by you in this awesome plugin then it will be more integration.
2. The next issue is when I draw a curve in 2D, it is so hard to close automatically the curve and I have to zoom in to close it or use the plugin options(close loop nicely or closed loop with the line) which almost is not so accurate or my desirable shape. would you solve this problem?
Have the best wishes to you as one of the most prominent and most successful developers.
Sincerely
Hamidreza
reza1813
Postby reza1813 » Mon Feb 18, 2019 9:44 am
Dear Fredo,
Hello, I am eager to receive your feedback. Thanks in advance.
Hamidreza
reza1813
Postby fredo6 » Mon Feb 18, 2019 1:02 pm
reza1813 wrote:Dear Fredo,
Hamidreza
Closure of Spline will come, but probably in another plugin.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby reza1813 » Mon Feb 18, 2019 4:53 pm
Hamidreza
Fredo
Dear Fredo,
Thank you for all of your efforts. I am looking forward to the result of this plugin which seems to be very functional. Furthermore, concerning to the first request, would you add Gumball feature in order to change the point easily in 2D and 3D for next Update or another plugin. Thanks in advance.
Yours Sincerely,
Hamidreza
reza1813
PreviousNext
Return to Plugins
Users browsing this forum: yashiii and 18 guests
