[Plugin] BezierSpline - v2.1a - 01 Nov 18
Re: [Plugin] BezierSpline - v1.7a - 19 Oct 14
Postby WebBeau » Wed Dec 31, 2014 6:16 am
Thanks a lot
-1
WebBeau
Postby Esense3d » Mon Feb 02, 2015 10:52 am
Hello Fredo
I would like to translate this plugin on all German but can not find language files
Bezier spline is only partially translated
Fredo I now have this new address
Roland F Swiss
Esense3d
Postby fredo6 » Mon Feb 02, 2015 12:26 pm
Esense3d wrote:Hello Fredo
Roland F Swiss
Thanks for this proposal.
BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
Anyway, the current version already includes a German translation.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Esense3d » Tue Feb 10, 2015 4:44 am
Hello Fredo
I See but it is not Full Translated
Just Parts of it
I also have your other plugins translated fully ie including the main folder
and other
Therefore, any icons etcetera in German
If you want I send you these versions as rbz versions to
If you do not mind I would publish in the German part please
Roland F.
Esense3d
Re: [Plugin] BezierSpline - v1.7b - 22 Mar 15
Postby fredo6 » Sun Mar 22, 2015 11:04 pm
NEW RELEASE 1.7b - 22 Mar 2015
This release removes noisy traces at startup of Sketchup
Download new release at main post
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] BezierSpline - v1.7c - 23 Mar 15
Postby fredo6 » Mon Mar 23, 2015 2:26 pm
NEW RELEASE 1.7c - 23 Mar 2015
This release removes noisy traces at startup of Sketchup - second trial
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rdcraighead » Tue Mar 31, 2015 12:37 am
This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
rdcraighead
Postby Gábor » Tue Mar 31, 2015 9:13 am
rdcraighead wrote:This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
What do you mean by being complicated? In the PluginStore you can easily find it by a simple search: http://sketchucation.com/pluginstore?pln=BezierSpline
Gábor
SketchUcation IT
Postby Rich O Brien » Tue Mar 31, 2015 9:24 am
It's free.
Rich O Brien
Administrator
Postby Msketcher » Thu May 14, 2015 2:18 am
I'm having problems with locking axis reference while drawing a classic bezier curve. It looks like it's trying to, as the "square mark" at the cursor is filled and turns color depending upon which arrow key I press, but it does not restrict axis for me. I'm on a Mac, SketchUp 2015 Pro. I've looked at the manual and thought I am doing everything right. I swear I had it working earlier today...
Msketcher
Postby NZSnowman » Thu May 21, 2015 9:19 pm
Just downloaded. Can not wait to try. Looks great!
NZSnowman
Postby iris1211 » Fri Jun 26, 2015 7:42 am
why I can't download it....
iris1211
Postby Dave R » Sat Jun 27, 2015 11:31 pm
iris1211 wrote:why I can't download it....
I can only guess it's because you didn't follow any of the links in the first post of this thread.
Since several options are provided, surely you can get it from one of them.
Global Moderator
Postby dbrenders » Tue Sep 29, 2015 12:55 am
Hi Fredo I'm a big fan and user of your plugins, i have them all in my must have plugins list. :) .
These days I've been working with bz curves for doing wires and cables etc... and i found a bit dificult some time to place contol points in the right way due to the snapping . Also when trying to reposition or edit the points was bit diffuclt to adjust in an accurate way.
Do you think it would be possible to have in future versions handles or any kind of gizmo thing, ( as thomthom uses in the bz surfaces) for this tools, would be very helpful and much appreciated. Thank you very much in advance .
Best
David
Enviat des del meu SM-P600 usant Tapatalk
dbrenders
Postby fredo6 » Tue Sep 29, 2015 8:50 pm
dbrenders wrote:Hi Fredo I'm a big fan and user of your plugins, i have them all in my must have plugins list. :) .
Best
David
You can use arrow and Ctrl-Arrows to get some inferences along axes.
But otherwise, the best is to try to use Construction points.
I'll try to make it easier in a next version.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby numerobis » Thu Oct 01, 2015 12:31 pm
fredo6 wrote:I'll try to make it easier in a next version.
A spline behavior like in ACAD would be nice. ;)
I think they are more harmonic or fluent. Here is a direct comparison:
https://www.youtube.com/watch?v=8YLSPBNs-FI
numerobis
Postby fredo6 » Thu Oct 01, 2015 1:34 pm
Which method did you use in your example: CubicBezier, Catmull, FSpline?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby numerobis » Thu Oct 01, 2015 6:37 pm
Catmull. What is FSpline? With CubicBezier you mean the B-Spline, right?
numerobis
Postby fredo6 » Thu Oct 01, 2015 9:12 pm
Catmull, Cubic Bezier and FSpline pass by the Control Points (BSpline does not).
Fred
fredo6
PluginStore Author
PluginStore Author
Postby numerobis » Fri Oct 02, 2015 12:46 pm
Ahhh... i thought the Cubic Bezier and F-Spline would be simple "curves" just looking at their picto and because they are placed between spirals and polylines... :oops:
Thanks for pointing this out :mrgreen: The F-Spline works great! 8-)
numerobis
Postby Bob James » Fri Oct 02, 2015 11:49 pm
Note: All PDF files are also available from the menu "Draw > BezierSpline curves > Documentation..."
All the spline tools work fine, but the Documentation feature does not work. I've used Autoinstall with the SCF Plugin Store tool to be sure I have the latest version, but nothing happens when I click on "Documentation"
Bob James
Premium Member
Premium Member
Postby fredo6 » Fri Oct 02, 2015 11:53 pm
You have to download the PDF doc separately and put it in the SU Plugins folder or the BZ_17 subfolder.
This is essentially for a matter of size that the doc file is not included in the script pacakage.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Bob James » Sat Oct 03, 2015 3:56 am
Thank you.
The phraseology of
"The doc is slightly outdated, but gives an overview of the essential features. All PDF files are also available from the menu "Draw > BezierSpline curves > Documentation..."
implied that they were "also" contained within the extension.
It's an excellent idea to have direct access to the documents for the more complex extensions that one does not use frequently: I wish all extension authors would do the same.
Bob James
Premium Member
Premium Member
Postby JClements » Fri Oct 30, 2015 7:27 pm
Hi Fredo:
I was wondering if there could be a "lock to plane" option which would only allow Beziers to be drawn to planes of the current Axes?
The way I would use this option is to 1st temporarily set the origin and axes to a surface that I want the bezier control points to "stick" to and then 2nd draw bezier curves and when finished the curves would "cut" the surface so that unwanted areas of the surface could be removed.
Currently when drawing a bezier, if not very careful, the curve may not be coplanar.
JClements
Premium Member
Premium Member
Postby Dave R » Fri Oct 30, 2015 7:33 pm
It would be nice to be able to lock points to be planar. How about a set of buttons across the top similar to the way you manage settings for other plugins? The user could choose red/green, red/blue, or green/blue.
As it is now, I prevent curves in 3D by drawing on a face but sometimes it would be nice to be able to draw in space.
Global Moderator
Postby JClements » Fri Oct 30, 2015 8:20 pm
Thanks for commenting, Dave.
If the surface is small and you need to drag or create a control point way off of the surface (in order to shape the curve) then drawing a planar curve is tough. Also, if there a lot of other closeby geometry it becomes even more of a challenge. There are work-arounds but they can be time consuming.
JClements
Premium Member
Premium Member
Postby Dave R » Fri Oct 30, 2015 8:50 pm
The curves I draw are usually fairly small but I generally draw a large face for the reason you describe. Still it would be great if the face wasn't needed.
Global Moderator
Postby fredo6 » Fri Oct 30, 2015 9:58 pm
I am not clear on your request.
I you type an Arrow before inputing the 3rd point, you lock all the points on the corresponding axis plane.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JClements » Fri Oct 30, 2015 10:14 pm
I guess I never knew this. I'll give it a try.
JClements
Premium Member
Premium Member
Postby Bob James » Sat Oct 31, 2015 1:27 am
JClements wrote:I guess I never knew this.
I didn't either! Saves having to make a plane to draw on :thumb:
Bob James
Premium Member
Premium Member
PreviousNext
Return to Plugins
cron
Users browsing this forum: Stanislava96 and 14 guests
