[Plugin] BezierSpline - v2.1a - 01 Nov 18
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)
Postby Lana » Thu Oct 11, 2012 12:11 am
Thanks Fredo. I love yours plugins.
Lana
Postby mwm5053 » Sat Jan 05, 2013 10:57 pm
In using the Classic Bezier Curve, I tried to change segments from 20s to 6s but doesn't seem to want do that and pressing tab doesn't seem to bring up anything obviously I'm missing something here I'm sure maybe someone can help. Thanks
2011 iMac
SU 2015 Pro, 2017 Make
V2 Twilight
macOS Sierra 10.12.5
mwm5053
Premium Member
Premium Member
Postby jeff hammond » Sat Jan 05, 2013 11:02 pm
mwm5053 wrote:In using the Classic Bezier Curve, I tried to change segments from 20s to 6s but doesn't seem to want do that and pressing tab doesn't seem to bring up anything obviously I'm missing something here I'm sure maybe someone can help. Thanks
i'm not 100% sure of the # with classic bezier but i do know that if you're using a uniform B-spline, the lowest acceptable amount of segments is 15s (and if you enter something lower, it will still be 15 segments)
[EDIT]-- with classic bezier curves, the lowest acceptable # is 7
dotdotdot
jeff hammond
Global Moderator
Postby mwm5053 » Sun Jan 06, 2013 12:38 am
Thanks Jeff will try that
2011 iMac
V2 Twilight
mwm5053
Premium Member
Premium Member
Postby Woody Longspike » Thu Feb 28, 2013 10:03 am
Thank you Fredo, a most excellent plugin and easy to use!
Woody Longspike
Postby shemalpandya » Tue Apr 16, 2013 6:47 am
THANK YOU SOOOOO MUCH :ecstatic:
shemalpandya
Postby gigi500 » Tue Aug 06, 2013 8:29 pm
Is anybody using this plug in on Mac Sketch Up Pro2013? My plugin crashes after a few seconds....
gigi500
Postby TIG » Wed Aug 07, 2013 9:36 am
Have you got the latest files and the latest LibFredo...
Which was recast for v2013 compatibility.
Also do you have any other know problem tools loading like Vray-beta ??
Global Moderator
Postby Dave R » Wed Aug 07, 2013 10:32 am
I've been using BZ_Spline tools on Mac in SU2013 with no problems. I do have the latest version of LibFredo6.
I wonder if you have a permissions issue.
Revised: It seems to work fine unless I try to use a number of tools from the toolbar in succession. Even just switching tools seems to cause a crash. I hadn't ever had an occasion to do that in my normal workflow so hadn't seen it. It doesn't seem to throw any Bug Splats, either.
Global Moderator
Postby gigi500 » Wed Aug 07, 2013 3:21 pm
library and all that - downloaded from the store, so all new...Tried to delete and reinstall - the same thing.Without changing tools, just a few curves on a blank file, sometimes less than a complete curve - bugsplat. I am attaching a screen shot of plug ins - maybe you see something that I do not. Permissions are all the same for other plugins,including Fredos, so should not be an issue. His other plugins work just fine, no crashes.
gigi500
Postby fredo6 » Wed Aug 07, 2013 3:37 pm
You have a wrong installation
jointpushpull_main.rb should be in JPP_Dir_20, NOT in the main SU Plugins directory.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby gigi500 » Wed Aug 07, 2013 4:21 pm
You are right. I moved it. Bezier lasted this time for maybe 8 curves, then bugsplat:(((
gigi500
Postby Dave R » Wed Aug 07, 2013 4:30 pm
Fredo, I'm seeing the same thing on my Mac. I successfully drew 5 Bezier curves but while drawing the 6th, SketchUp crashed without a Bug Splat.
Global Moderator
Postby gigi500 » Wed Aug 07, 2013 4:53 pm
I am attaching a new screen shot - got rid of all plugins but native sketch up and bezier. Still Crashes!
gigi500
Postby TIG » Wed Aug 07, 2013 7:32 pm
What is the FULL path to that Plugins folder ?
You leak out the story drip by drip... ;)
Global Moderator
Postby gigi500 » Wed Aug 07, 2013 9:08 pm
the normal for mac:library/application support/sketchup2013/plugins/
Everything else works. And Dave R apparently encountered the same thing...I got rid temporarily of other plugins to make sure they do not affect that one. No change.
gigi500
Postby fredo6 » Wed Aug 07, 2013 9:33 pm
@gigi500, @Dave,
Not sure what it can be and why it appears now (I did not change anything to the plugin for a while).
Since you have a deterministic crash situation (after a few curve), would you mind to remove the file LibTraductor.rb (or rename it .rb!). Since you have LibFredo6 installed, it should be harmless.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Dave R » Wed Aug 07, 2013 9:38 pm
I disabled LibTraductor.rb and opened SU. I got the following:
I do have the most recent LibFredo6 installed.
Global Moderator
Postby fredo6 » Thu Aug 08, 2013 1:42 pm
Dave,
But do you still get BezierSpline loaded?
And if so, do you get the crash?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Dave R » Thu Aug 08, 2013 1:51 pm
No. With LibTraductor disabled I don't get BezierSpline loaded at all. No option for toolbar nor any menu entry.
Global Moderator
Postby fredo6 » Thu Aug 08, 2013 1:57 pm
Dave R wrote:No. With LibTraductor disabled I don't get BezierSpline loaded at all. No option for toolbar nor any menu entry.
My mistake,
You should replace the statement rescue by rescue LoadError on line 35 of bezierspline_main.rb.
This will allow checking for potential conflicts ebtween the old version (libTraductor.rb) and the new one embedded in LibFredo6.
If you still get a crash, then it is something else
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Dave R » Thu Aug 08, 2013 2:00 pm
I can't easily see line numbers. "rescue" appears several times. Could you give me a bit of surrounding text?
Global Moderator
Postby Rich O Brien » Thu Aug 08, 2013 2:29 pm
Code: Select all
require 'sketchup.rb'
begin
   require 'libtraductor.rb'      # for language translation
rescue
#Specify the two curve extensions: Bezier Classic and Polyline
BZ____LIST = ["BZ__BezierClassic", "BZ__Polyline"]
Rich O Brien
Administrator
Postby Dave R » Thu Aug 08, 2013 2:33 pm
10Q
Global Moderator
Postby Dave R » Thu Aug 08, 2013 2:36 pm
OK, LibTraductor disabled. The rescue statement revised.
Upon opening SketchUp I still get the error:
Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BZ_Dir_14/bezierspline_main.rb
uninitialized constant Bezierspline::BezierContext::Traductor
Error Loading File bezierspline.rb
Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/JPP_Dir_20/jointpushpull_main.rb
no such file to load -- libtraductor.rb
Error Loading File jointpushpull.rb
Edit to add: After clicking OK, I see an entry for the BezierSpline toolbar but when I enable that toolbar it is blank with only space for one button.
Global Moderator
Postby fatboycakeshop » Mon Sep 02, 2013 6:18 pm
Hi. Im having the same issue. Done all of the above and still crashes after a few curves. Anything else I can try?
fatboycakeshop
Postby nigel_edward » Sun Sep 15, 2013 4:29 pm
Bloody well brilliant tool! Thank you so much! :thumb: :ecstatic:
nigel_edward
Postby ukchoiceshops » Mon Sep 16, 2013 1:35 pm
I am struggling to work out how to install this onto my sketchup 8 system on a mac. any help would be much appreciated :)
ukchoiceshops
Postby mitcorb » Mon Sep 16, 2013 3:57 pm
Hi, Ross:
Did you read the advice for Mac users on the first page of this topic?
Alternatively, have you considered using the Sketchucation Plugin Store tool?
http://sketchucation.com/resources/plug ... e-download
At the top of this page, there is a selection called Resources and in the drop down is the link to the download.
There may be some other issue, so post back for someone to assist.
mitcorb
Top SketchUcator
Postby aydee » Wed Oct 09, 2013 3:37 am
Fantastic. I can finally get more segments and smooth bezier curves. Thank you!
aydee
PreviousNext
Return to Plugins
Users browsing this forum: katieee and 13 guests
