[Plugin] BezierSpline - v2.1a - 01 Nov 18
Re: [Plugin] BezierSpline v1.4 - 07 Nov10 (upgrade SU8)
Postby fredo6 » Wed Nov 10, 2010 10:06 am
Oxer wrote:Hi Fredo!
Thanks for the plugin, i have introduced the spanish language to the BezierSpline v1.4 - 07 Nov10, i upload it here for share with all users.
Oxer,
I have published an update with the Spanish translation integrated.
see main post
Could please edit the previous post and remove the attachment (actually, there are some issues with the files you posted).
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] BezierSpline v1.4e - 10 Nov10 (upgrade SU8)
Postby fredo6 » Wed Nov 10, 2010 11:00 am
NEW RELEASE 1.4e - 10 Nov 2010
This release just integrates a Spanish translation kindly provided by Oxer
Download new release at main post
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby theark » Wed Nov 17, 2010 2:37 am
Thank for your sharing.Great work. :thumb: :thumb:
theark
Postby poohnut » Fri Nov 19, 2010 6:23 am
thankssssss :ecstatic: :P
poohnut
Postby Krypt » Mon Nov 22, 2010 8:57 pm
Thank you very much for this. :thumb:
Krypt
Postby queti2000 » Wed Nov 24, 2010 2:45 am
Fredo6,Thank You very much!
queti2000
Postby Elibjr » Thu Dec 09, 2010 9:31 pm
Thank you very much! :ecstatic:
Elibjr
Premium Member
Premium Member
Postby aswas » Wed Dec 15, 2010 4:43 am
HThe link for this [Plugin]is not working, is there a reason for this? I would realy like to try the bezier tool.
aswas
Postby Gaieus » Wed Dec 15, 2010 10:44 am
Hi aswas,
The link does work for me. What do you see in place of the download link to the zip archive under that big, yellow, download label?
Postby thomthom » Tue Jan 11, 2011 1:16 pm
Hi Fredo
I have 1.4e - 10 Nov 2010 installed, but I still experience the context handler to lag on larger models.
Example: ~92.000 entities:
### Context Handler ###
bezierspline_main.rb:2465:in `load_all_menus' [...] bezierspline.rb:50
3.013 seconds
PluginStore Author
PluginStore Author
Postby fredo6 » Tue Jan 11, 2011 6:50 pm
thomthom wrote:Hi Fredo
3.013 seconds
I guess these are 92000 entities at first level, which is normally seldom, since most co,plex model tend to be structured with components.
Then, yes, BezierSpline cycles through it to find a curve which is of type BezierSpline.
I'll see what I can do
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Wed Jan 12, 2011 12:09 am
It was on a selection inside a component or group.
PluginStore Author
PluginStore Author
Postby fellanamedlime » Wed Jan 12, 2011 12:12 am
Hi Fredo,
I love your Bezier plugin - it's a really great help. There's one thing though: is there any way to constrain the direction by which you can move the control points of the curve?
For example, if I want to move a point vertically, it's really tricky: I have to draw a vertical line, then try and move the control point to the top of that line, although even then it doesn't work properly because it doesn't snap.
If there was a way to constrain it (like you do normally, by pressing shift to constrain it to the blue axis), that would be a major, major help. Is there any way to incoroporate this into the plugin?
Thanks once again for all you hard work.
fellanamedlime
Postby mitcorb » Wed Jan 12, 2011 4:04 am
What you are asking may not be available, since these are supposed to be 2d functions. I could be wrong, and it won't be the first time- believe me.
I believe Bezierspline has some documentation which you can find within your Sketchup Plugins Folder, since it is supplied with the script. Should be pdf. I am saying this without checking my folder for sure.
mitcorb
Top SketchUcator
Postby jeff hammond » Wed Jan 12, 2011 4:07 am
mitcorb wrote:What you are asking may not be available, since these are supposed to be 2d functions. I could be wrong, and it won't be the first time- believe me.
i'm leaning toward the ICBW side ;)
dotdotdot
jeff hammond
Global Moderator
Postby mitcorb » Wed Jan 12, 2011 4:22 am
Yeah, me too.
I just checked the documentation and then did an experiment. Yes, I was able to intentionally click a point above the horizontal plane, although I did not click on a particular line.
Tralfamadorians have the ability to see things much more clearly than us earthlings :mrgreen:
My apologies, fellanamedlime
mitcorb
Top SketchUcator
Postby jeff hammond » Wed Jan 12, 2011 4:36 am
what's fellanamedlime?
fella named lime?
the only thing google is telling me at the moment is that it's a fairly popular forum user name (even one here at scf).
i'm thinking this one has flown over my head :lol:
dotdotdot
jeff hammond
Global Moderator
Postby chrisjk » Wed Jan 12, 2011 9:05 am
You can constrain the movement in editing mode. On the Mac, click Alt (I think it's probably Ctrl in Windows) then the black box turns into an outline, hit the up arrow as you would with the Move tool and Hey Presto you are locked in the Z direction. Fredo links to a tutorial here http://www.aecbytes.com/tipsandtricks/2 ... tchup.html that explains that plus other stuff.
Chris
chrisjk
Premium Member
Premium Member
Postby fredo6 » Wed Jan 12, 2011 11:08 am
fellanamedlime wrote:Hi Fredo,
When you edit a control point, you can press Arrows to impose a direction of axes. You'll see a small triangle (you may have to press and release CTRL if you are in plane constraint mode).
But I agree, this should be better done. Indeed, I will take care of it when I build a new version.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby mitcorb » Thu Jan 13, 2011 6:42 pm
Thank you, Fredo
Would there be any difficulty using this SU7.1 in anticipation of upgrading to SU8?
mitcorb
Top SketchUcator
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)
Postby Larsen » Sun Jan 23, 2011 10:50 pm
Total respect, chapeau Monsieur.
[Every form of thinking perish by excess of its basic principles.
Larsen
Postby fredo6 » Sun Jan 23, 2011 11:55 pm
NEW RELEASE 1.4f - 23 Jan 2011
This release just fixes a potential performance in the contextual menu when there is a big number of elements in the selection. This was signaled by ThomThom and Jim.
Download new release at main post on BezierSpline
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Jim » Mon Jan 24, 2011 12:09 am
Thanks Fredo.
Jim
Global Moderator
Postby fellanamedlime » Mon Jan 24, 2011 3:54 am
chrisjk wrote:You can constrain the movement in editing mode. On the Mac, click Alt (I think it's probably Ctrl in Windows) then the black box turns into an outline, hit the up arrow as you would with the Move tool and Hey Presto you are locked in the Z direction. Fredo links to a tutorial here http://www.aecbytes.com/tipsandtricks/2 ... tchup.html that explains that plus other stuff.
Aha! This is exactly what I was after... Pressing the arrow keys to constrain direction plane (i.e. up key=blue etc.) is actually a pretty easy way of doing it, I just wasn't aware of this function. This makes it a lot easier to use. Thanks for the tip!
fellanamedlime
Postby watkins » Mon Jan 24, 2011 10:56 am
Dear Fredo,
Just a brief note to say thank you for all your hard work. As always, your generosity is greatly appreciated.
Kind regards,
Bob
watkins
Re: [Plugin] BezierSpline v1.2 - Comprehensive Refresh
Postby junoswayam » Fri Jan 28, 2011 5:35 pm
Thanks a lot man..... This is amazing!!
junoswayam
Postby spruzza » Fri Feb 04, 2011 1:40 pm
Great!!! Really usefull!!
spruzza
a small bug!
Postby unclex » Sat Feb 12, 2011 11:17 pm
IF remove cadfather's icon catalog
the BS icon @ SU vanished...
when cadfather's and default catalog together,
the icon @ SU can work
unclex
Postby bentleykfrog » Mon Mar 21, 2011 4:58 am
cool tool, just one suggestion. It would be helpful to reverse the direction of the polyline divide function so you can choose which end the dividing starts at. Currently, for curves that have an incorrect start and end, I have to explode my curve, then recreate the curve using the classic bezier curve tool, then use polyline divide.
Sorry for my ignorance if this feature already exists.
bentleykfrog
Postby bentleykfrog » Mon Mar 21, 2011 5:07 am
Ohh, I forgot to post an example of how I've used the tool. I used Polyline divide in the image below on the lines that set out the rows of vines, then I used Chris Fullmer's Component Stringer to set out the vine components along these paths. Very happy with the result :enlight:
bentleykfrog
PreviousNext
Return to Plugins
Users browsing this forum: madoraafat, smtctnk and 13 guests
