SketchUcation Premium Membership
[Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)
Re: [Plugin] BezierSpline v1.4 - 24 Aug 10 (upgrade)
Postby Dave R » Wed Aug 25, 2010 2:55 am
Jeff, if you have access to a large format printer, it would make sense to print full size patterns and use those. I've done that (with a normal printer) on numerous occasions and it works quite well. Don't dismiss plotting offsets though. You really don't need very many if you're going to spring a batten around them. Don't worry about the approximation of curves with straight line segments in SU. With BezierSpline you can set a larger number of segments. Whether you use a full size pattern of bend the batten, you can tell fairly easily if the curve is fair by sighting down it from one end.
We should probably take this to PMs or something and let Fredo have his thread back. ;)
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby cmeed » Wed Aug 25, 2010 12:40 pm
Stupid suggestion Here..... BUT -
could a projector work?
we used to blow up small images using a projector onto walls. then trace, paint etc. Its not the most accurate of methods but it is quick, your probably looking for precision. see, told you it was stupid.
Although, I like the image of you striding over the building site with school projector tucked under your arm!
cmeed
Re: [Plugin] BezierSpline v1.4 - 02 Sep 10 (upgrade SU8)
Postby webdeladelineacion » Thu Sep 09, 2010 9:28 pm
would be important to also be translated into Spanish
Please. Great tool!!!
webdeladelineacion
Postby mozzie » Mon Sep 13, 2010 3:45 am
Download link for 1.4 does not appear to be working? (for me, at least).
mozzie
Postby Dave R » Mon Sep 13, 2010 3:56 am
Mozzie, I just tried it and it downloaded for me just fine. What browser are you using?
Global Moderator
License type: Pro
Re: [Plugin] BezierSpline v1.3 - 22 Dec 09 (better conversio
Postby pieterv » Tue Sep 21, 2010 10:25 pm
First of all: Thanks A LOT Fredo, for your very handy plugin. Thanks to your plugin I was able to make things like this: http://forums.sketchucation.com/viewtopic.php?f=15&t=29881 Without your plugin this would be very difficult to make.
I would like to continue on something that has been discussed earlier:
Fredo6 wrote:
plot-paris wrote:I've got one question though, that I wanted to ask you for quite some time now:
when I transform a polyline (or now just a series of linesegments ;) ) into a Polyline Arc Corners, sometimes the distribution of vertexes is a bit strange, showing some corner with very high polygon detail, leaving others almost unrounded... is there a way to influence that? like to tell the plugin to distribute the vertexes evenly per corner?
The number of vertices for the rounding is based on the Precision parameter given on a Full Circle basis. So for Precision = 24s, you'll get 24 points for 360°. Depending on the arc angle of the rounding, you'll get less or more points.
Is that the explanation or do you see another issue or bug?
Fredo
I think I experience the same thing (see attachement): There are more vertexes towards the end of the curve. The main problem with this for me is that I have to put in a lot of sides sometimes (like 60s) untill the big part with the least number of vertexes becomes smooth. Is there something you can do about this? Or is there just no other way?
Thanks in advance man!
Pieter
pieterv
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby Jeff Hammond » Tue Sep 21, 2010 10:38 pm
pieterv wrote:I think I experience the same thing (see attachement): There are more vertexes towards the end of the curve.
it's not that there are more vertices towards the ends, it's that there are more when the bend is a tighter curve..
here it's shown with the vertices closer together in the middle of the line.
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby seraphix » Thu Sep 23, 2010 4:40 pm
very nice plugin thanks.
seraphix
Postby thomthom » Sun Sep 26, 2010 8:51 pm
"Classic Bezier" - what does that refer to?
I was under the impression that Cubic Bezier was the most common one - so what is the classic?
Global Moderator
Name: Thomas Thomassen
License type: Pro
Postby thomthom » Sun Sep 26, 2010 8:53 pm
Oh wait - I'm getting confused... Is Cubic the Classic?
Global Moderator
License type: Pro
Postby fredo6 » Tue Sep 28, 2010 6:43 pm
thomthom wrote:Oh wait - I'm getting confused... Is Cubic the Classic?
Classic Bezier is the true bezier curve, which does not pass thorugh the control points, except the first and the last ones. It is often referred to as simply "Bezier".
In contrast, Cubic Bezier is a spline passing through all control points. It is made of portions of Bezier curves for 3 consecutive points, with derivative continuity. There are other type of splines, but this one is quite fast to compute with direct formulas.
Fredo
fredo6
Top SketchUcator
License type: Pro
SketchUp use: interior design
Postby mitcorb » Tue Sep 28, 2010 6:58 pm
Thank you, Fredo, for that clarification, and best that you did.
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free/Make
Postby meganm » Mon Oct 11, 2010 4:04 am
Hi there,
I'm trying to download this plugin but am receiving a message saying I'm not authorised to download it...
I'm registered on this site. Are there other steps I need to take to be able to run BezierSpline?
Thanks,
Megan
meganm
Postby Gaieus » Mon Oct 11, 2010 8:02 am
Hi Megan,
There should not be any further steps and you shuld be able to access any attachments once you are logged in. Please, have a look at this topic however and see what the problem can be (essentially the issue is that the forum software logs people ooff once in a while):
viewtopic.php?f=15&t=19797
Administrator
License type: Pro
SketchUp use: historical reconstruction
Postby LannorMov » Sun Oct 24, 2010 7:02 am
Gracias Fredo.you are wonderful in the art of making plugin, great is thy heart to give. Muy agradecido.
LannorMov
Postby Scott M » Sun Oct 24, 2010 7:46 pm
Need help loading this file.I saved it to desktop and exracted to su 8 plugins restarted su 8 but it is not there.I see that the file ext. is efw how do I get it to load as rb. I am new to plugins.
Scott M
Postby Gaieus » Sun Oct 24, 2010 8:01 pm
efw? I have never seen that. Maybe try to rename it to rb (or rbs)?
Also, Bezier Spline may need to be enabled under Window > Preferences > Extensions (and then you find a whole toolbar for it under View > Toolbars)
Administrator
License type: Pro
Postby LannorMov » Sun Oct 24, 2010 10:34 pm
Scott M wrote:Need help loading this file.I saved it to desktop and exracted to su 8 plugins restarted su 8 but it is not there.I see that the file ext. is efw how do I get it to load as rb. I am new to plugins.
Scott M. you excuse my English is not so good. I use Sket8. What I did was to delete the first folder icons (without removing the internal folder containing the images), because it appeared to me the bar and showed me and the bar, but no picture and then I went back to get Images folder in the folder icons (which is the same, what happens is that it comes two in one) and do not know why but it appeared to me and icons. Not if you understand me, maybe you serve.
LannorMov
Postby danbig » Mon Oct 25, 2010 5:47 am
I have a question:
First, let me add my thanks to the many who have already said it: this tool should ship with SketchUp, and it really provides some key functionality.
I'm curious about the details of how you control the curves of a bezier curve: this plugin seems to have a different mode of control than say, Illustrator or even LayOut. In each of the latter programs, curves can be controlled with the two-sided handle, as shown here:
My question really has two parts:
1. Is the functionality of the bezier curves in this plugin the same as the curves in Illustrator and LayOut?
2. Would it be possible to change the mode of curve control to the two-sided handles for this plugin?
danbig
Postby thomthom » Mon Oct 25, 2010 8:15 am
The Bezier curves you see in Illustrator and similar are series of Bezier curves connected together. While the splines in this plugin are all one segment.
It would be interesting to see a variant like you describe, would allow for better local control.
Global Moderator
License type: Pro
Postby tfdesign » Mon Oct 25, 2010 12:34 pm
This is a brilliant plugin. Thanks Fredo6! When I've got some money again, I'll send you a donation :)
(In fact I'll send donations to all whose plugins I use, once the work gets flowing again! :oops: :D ).
My book "Let's SketchUp!" Download from here
tfdesign
Top SketchUcator
Postby Scott M » Mon Oct 25, 2010 1:17 pm
Gaieus wrote:efw? I have never seen that. Maybe try to rename it to rb (or rbs)?
If you go to the download link clik on save it will show the file type as a EFW file. When I save it too my desk top it is a EFW file. I then clck on send too zip folder.Then extract all into plugin folder. It showes up in this folder as a EFW file type.Am I doing something wrong.
Scott M
Postby thomthom » Mon Oct 25, 2010 1:29 pm
When you click the "BezierSpline 1.4 - 02 Sep 10.zip" link you get an .eft file?
That is odd. Are you using some download manager that might be interfering?
When I click I get the expected "BezierSpline 1.4 - 02 Sep 10.zip" file...
Global Moderator
License type: Pro
Postby Scott M » Mon Oct 25, 2010 1:45 pm
When I clik on the download link this is what I see.
File Download
Do you want to open or save
Name:BezierSpline 1[1].4-02 Sep 10.1.321C02.efw
type:unknown File Type,108MB
Scott M
Postby thomthom » Mon Oct 25, 2010 1:49 pm
Scott M wrote:Name:BezierSpline 1[1].4-02 Sep 10.1.321C02.efw
108MB! :shock: That is just wrong. You either got a download manager interfering, or a virus/malware. Something is not right there.
Can you try with a different browser? Or from a different machine?
Global Moderator
License type: Pro
Postby thomthom » Mon Oct 25, 2010 1:52 pm
Global Moderator
License type: Pro
Postby Scott M » Mon Oct 25, 2010 4:13 pm
Thanks went to the first link and fixed the problem it was my ca settings every thing worked this time thanks again
Scott M
Re: [Plugin] BezierSpline v1.4 - 07 Nov10 (upgrade SU8)
Postby fredo6 » Sun Nov 07, 2010 8:20 am
NEW RELEASE 07 Nov 2010
This release mainly fixes a performance issue with the contextual menu in models having a huge number of elements, whether you use BezierSpline or not (see discussion at http://forums.sketchucation.com/viewtopic.php?f=180&t=31788#p280335).
Download new release at main post
Fredo
fredo6
Top SketchUcator
License type: Pro
Postby utiler » Mon Nov 08, 2010 2:35 am
Thank you Fredo, Thank you, thank you, thank you..... :sketchstatic:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Oxer » Tue Nov 09, 2010 2:35 pm
Hi Fredo!
Thanks for the plugin, i have introduced the spanish language to the BezierSpline v1.4 - 07 Nov10.
http://www.oxervision.blogspot.com/
Oxer
SketchUp version: 8
License type: Pro
Artisan Organic Toolset - a set of powerful organic modeling tools.
PreviousNext
Return to Plugins
Users browsing this forum: Buynar, Google Bot, jorisbert, JuanV.Soler and 6 guests
