[Plugin] Front Face - 1.2
Re: [Plugin] Front Face - 1.1
Postby tomasz » Sun Dec 06, 2009 5:00 pm
Hi Gaieus,
The option of having back material reset to default looks nice.
I am currently terribly busy, but Christmas is coming.
I will put it on my list.
Tomasz
tomasz
SU2TH & SU2KT Developer
Postby TIG » Sun Dec 06, 2009 5:01 pm
In the meanwhile, before it gets written into something better - to make ALL rear faces in the model [and faces inside definitions too] have the default material on their backs, just copy and paste this line of code into the Ruby Console - I compressed it into one line for ease of pasting...
Code: Select all
m=Sketchup.active_model;es=m.entities;es.each{|e|e.back_material=nil if e.class==Sketchup::Face};ds=m.definitions;ds.each{|d|d.entities.each{|e|e.back_material=nil if e.class==Sketchup::Face}};return nil
Global Moderator
Postby thomthom » Sun Dec 06, 2009 5:08 pm
:D
I'd added the feature to Remove Materials. Will post it later.
PluginStore Author
PluginStore Author
Postby tomasz » Sun Dec 06, 2009 5:10 pm
Boofredlay wrote:Any progress on changing the cursor Tomasz?
I am using it today and was just curious. Handy tool BTW.
Checked the API. It looks easy...
tomasz
Postby Gaieus » Sun Dec 06, 2009 9:39 pm
Guys, I am amazed at the helpfulness of all of you.
Once I win this combpetition, I hope you will all come and enjoy the party.
(BTW I am planning a difficult plugin - you will hate me...)
Re: [Plugin] Front Face - 1.2
Postby tomasz » Mon Dec 07, 2009 6:15 pm
Ok. I said I was busy, but I had to refresh my memory, how to write a Tool in SU, so played with FrontFace and here we go:
Version 1.2 is ready.
Greetings
Tomasz
tomasz
Postby boofredlay » Mon Dec 07, 2009 8:15 pm
Beautiful. Thank you. :thumb:
boofredlay
Global Moderator
Postby Ecuadorian » Mon Dec 07, 2009 8:29 pm
TIG wrote:to make ALL rear faces in the model [and faces inside definitions too] have the default material on their backs, just copy and paste this line of code into the Ruby Console - I compressed it into one line for ease of pasting...
Code: Select all
TIG, this is probably one of the most useful pieces of code ever. Thank you very much. :thumb:
Ecuadorian
Postby Fletch » Mon Dec 07, 2009 10:15 pm
TIG, does it also make all groups and components have the default material? (in case one or two got accidentally painted somehow?)
Fletch
Twilight Render
Postby Ecuadorian » Mon Dec 07, 2009 10:42 pm
Fletch, Matthieu Noblet wrote a plugin for that:
http://forums.sketchucation.com/viewtop ... 23#p102323
Ecuadorian
Postby TIG » Mon Dec 07, 2009 11:09 pm
Fletch wrote:TIG, does it also make all groups and components have the default material? (in case one or two got accidentally painted somehow?)
No, it fixes back_materials inside them, but not materials applied to them - to do that you need this line...
Code: Select all
Sketchup.active_model.definitions.each{|d|d.instances.each{|i|i.material=nil}}
:ugeek:
Global Moderator
Postby Royvas » Thu Aug 12, 2010 10:13 pm
gosh thank you so much for this :) works great
Royvas
Postby alvis » Sun Oct 24, 2010 10:54 am
Tomasz :berserk:
alvis
Premium Member
Premium Member
Postby Zacchia » Sat Nov 27, 2010 8:58 am
Hi Tomasz
I have found now this plugin!! This is fantastic. Thanks a lot!
Zacchia
Postby Zacchia » Tue Dec 21, 2010 5:00 pm
Thomasz
It seams that when material is on normal face and i use this plugin then material will be default SU material when turned the faces. Why is it like this? I think it should keep material and just turn faces.
Zacchia
Postby Jrudd » Tue Jan 25, 2011 3:09 pm
Hi all,
Proud to announce that there is finally a solution to the face flipping problem. You can now reverse faces and preserve UV coordinates! I tested it and the results are accurate!
The UV Toolkit makes it possible. You also need to download the TT_Lib and put it in your plugins folder.
To reverse a face, first select what you want reversed, then go to Plugins > UV Toolkit > Frontface material to Backface (or the opposite).
Hope it helps,
Jeremy
Jrudd
Postby simoni » Wed Jul 20, 2011 11:42 am
I find it works 50% of the time, sometimes textures are mapped wrongly, maybe I am doing something wrong?
simoni
Postby Need2SeeAttachments » Mon Jan 21, 2013 9:31 pm
LOOK AT MY USER NAME, ENOUGH SAID. Need2SeeAttachments.
I WANT TO DOWNLOAD, NOW BYE FOREVER SKETCHUCATION.
Meant no offence, k thx bai.
Need2SeeAttachments
Postby thomthom » Tue Jan 22, 2013 9:54 am
Bye bye.
PluginStore Author
PluginStore Author
Postby desunvn » Thu May 02, 2013 3:57 am
Thank you for plugin this
desunvn
Postby dancho » Fri Oct 11, 2013 9:20 am
Hi Tomasz,
I was installed Fredo Additional Plugin folder plugin viewtopic.php?p=345150#p345150
and have a problem with finding icons if I use your plugin in another dir.
Its only work with Sketchup 2013/Plugins place. Can you look at this?
Regards,
Daniel
dancho
Premium Member
Premium Member
Postby TIG » Fri Oct 11, 2013 9:58 am
dancho wrote:Hi Tomasz,
Regards,
Daniel
This is an old script...
You are unlikely to get it chnaged now...
BUT you can adjust the tool's code yourself.
It is quite easy...
Open the file frontface.rb using Notepad, or another plain text editor like Notepad++ - BUT NEVER USE a word-processor!
Near the beginning there are three lines that setup the button icons [#36/40/44]
The first line reads:
cursor_path = Sketchup.find_support_file("FrontFaceCursor.png", "Plugins/FrontFace_files")
You must rewrite it to read:
cursor_path = File.join(File.dirname(__FILE__), "FrontFace_files", "FrontFaceCursor.png")
so it now looks in a folder named FrontFace_files that is in the folder with the .rb file [wherever that is located], rather than always the main Plugins folder as the original code sets.
The other two entries for cursor_path = need to be similarly recast, using:FrontFaceCursorOff and FrontFace_OnDef for the .png respectively...
Global Moderator
Postby dancho » Fri Oct 11, 2013 12:39 pm
Hi TIG,
thanks for help, I do it like you wrote
class FrontFaceTool
def initialize
@ip = Sketchup::InputPoint.new
cursor_path = File.join(File.dirname(__FILE__) ,"FrontFace_files","FrontFaceCursor.png"
if cursor_path
@cursor_on = UI.create_cursor(cursor_path, 12, 12)
cursor_path = File.join(File.dirname(__FILE__) ,"FrontFace_files","FrontFaceCursorOff.png"
if cursor_path
@cursor_off = UI.create_cursor(cursor_path, 12, 12)
cursor_path = File.join(File.dirname(__FILE__) ,"FrontFace_files","FrontFace_OnDef.png"
if cursor_path
@cursor_on_def= UI.create_cursor(cursor_path, 12, 12)
and receive this error message, have you any idea?
THX
Dancho
dancho
Premium Member
Premium Member
Postby TIG » Fri Oct 11, 2013 2:09 pm
You have mistyped.
It should be:
The error message tells you the error...
Add the final ) to the three lines and it will work OK...
Global Moderator
Postby samothrace41 » Sat Dec 21, 2013 5:25 pm
A great THANK YOU Tomasz !!!
samothrace41
Postby tcalvinsimmons » Wed Jan 21, 2015 7:50 pm
Is the current FaceFront ruby current with SU 2015 version? I downloaded it and installed it in my Plug in file but it doesn't show up. Any thoughts
tcalvinsimmons
Postby Dave R » Thu Jan 22, 2015 1:02 pm
tcalvinsimmons wrote:Is the current FaceFront ruby current with SU 2015 version? I downloaded it and installed it in my Plug in file but it doesn't show up. Any thoughts
Hi Tom,
Small world. ;)
So did you try installing it with the SCF PluginStore plugin? Or did you download the file as .rbz from here?
Global Moderator
Previous
Return to Plugins
Users browsing this forum: dansamanek, deeplonac, fredo6, samuel_t and 16 guests
