[Plugin] follow me rotateRe: [Plugin] follow me rotate
A simple Push-Pull can do that ![]() Frenglish at its best !
My scripts Re: [Plugin] follow me rotate
Matt, Wiki's ruby is designed to "Twist" the shape as it follows the path. Do you mean the push pull tool will rotate a shape as well as extrude it? Re: [Plugin] follow me rotate
Thank you so much, so your plugin you share that truly the key of "follow me rotate" ![]() Re: [Plugin] follow me rotateHi,
It doesn't seem to work with straight paths. If the path I use is a curve it works, if it is a straight line it doesn't do anything. Is that how it is supposed to work? Re: [Plugin] follow me rotateIt works on Macintosh running 10.5.6. Get the .zip file if you have trouble with the .rar.
Wow, this is a great plugin— thanks!!!! It blows up on me if I scale up more than about 1.1. Looks like it scales once for every segment on the line— I was expecting it to scale over the whole length. This makes for a very sensitive scaling feature. Re: [Plugin] follow me rotate
Yes.
you can divide a line into many segments and then weld them again. It works! Re: [Plugin] follow me rotateI love what this does!
While it worked fine for me at first, now I'm having troubles. If anyone has fixes, let me know, I need this script! -sometimes the script reverses the follow line. It starts from one side, but when I select the script it flips to the other. -sometimes the script does not work, even after welding my follow lines religiously -sometimes all the script does is place a 2" long construction line on the underside of the face, one segment's length away from the face. -I just tried again. The first time, it didn't work. The second try, it placed the 2" construction line on the underside and reversed the path. The third try, it worked great, with the path coming from an offcenter construction point. The following five times, it shifted the path from the construction line to the center of the face and, other than that, worked. -not a bug, but a feature request: as I posted earlier, scaling and rotation are per segment of the follow path, not over the whole length. It might be more intuitive and controllable if they were measured over the whole path. Again I will repeat, I always weld my follow lines or use unexploded curves. I'm using FAR on a Mac and some posters feel it is Win only— Is this the issue? SU seems buggier as I use FAR, though this may be coincidence, or confusing the cause and effect. Thanks for any assistance, Jim Re: [Plugin] follow me rotateI checked the Ruby Console at some point during my last experiments, and here's what I was getting:
I don't seem to be able to reset the Console without quitting and restarting Sketchup, so it's hard to tell at what stage things were going wrong. How to create a twisted balaustre with Follow Me rotateThank you, very much, wikii. This tool is extremely useful and solves one of my main gripes about SketchUp.
I created a video tutorial for twisted balaustres/legs... ...in response to this tutorial found on the web: http://finewoodworking.taunton.com/item ... -the-twist I hope you see the BIG difference your script makes. Without Follow Me Rotate, it is like being in the stone age! By the way, I discovered that if I don't deselect the line after dividing it and make sure it has been properly divided, sometimes Follow Me Rotate will extrude in the opposite direction. Thank you again. And thanks to Simon Bonnet for the tip on posting Youtube videos here. ---------------------18:08 31/01/2009 UPDATE-------------- Here's the Youtube link for those who can't see it embedded: http://www.youtube.com/watch?v=0eBIQC2Cgps I've just discovered that the video shows only a black screen in Internet Explorer 6, but works fine in Firefox 2 and Google Chrome. ----------------------------------------------------------- Last edited by Ecuadorian on Sun Feb 01, 2009 12:11 am, edited 2 times in total.
-Miguel Lescano
Subscribe to my house plans YouTube channel! (30K+ subs) Re: [Plugin] follow me rotateHi Miguel,
Great tutorial. I noticed some quick shots of your tools which don't look familiar. Would you mind posting a screen shot of your tools so I can see what ones you have that I don't? Thanks, Jeff Have I mentioned how much of a laugh I get out of some of the Signatures on here!
Re: [Plugin] follow me rotate"...in response to this tutorial found on the web:"
I wish I could see your video. I've tried the plugin but it doesn't yield the same thing I showed in the tutorial. I did the tutorial without the plugin because of that and because I was asked to demonstrate a manual way of drawing that. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] follow me rotateHello, Dave. I'm sorry, I'll be more careful with the wording in the future.
I liked your tutorial because it is actually the best way to do it in SketchUp without having to install any additional scripts. It's just that I really think that Follow Me Rotate is an extremely cool script thas not everybody is aware of, so I wanted to share with your readers an even faster way to do the same balaustre. Here's the Youtube link for those who can't see it embedded: http://www.youtube.com/watch?v=0eBIQC2Cgps (Weird, it's working fine in Google Chrome...) And sorry for my bad English, I learned it through Pink Floyd songs... -------------------UPDATE-------------- Video does not work in Internet Explorer 6, but works fine in Firefox 2 and Google Chrome. -Miguel Lescano
Subscribe to my house plans YouTube channel! (30K+ subs) Re: [Plugin] follow me rotateI appreciate you wanting to show the readers a faster way but you need to provide the links for the plugins or they're not in any better position.
Re: [Plugin] follow me rotateSure, I posted the links in the Youtube video description. click on "(more info)" to show it. I'll copy the description here:
" Today I read this tutorial for doing a "twisted leg": http://finewoodworking.taunton.com/item ... -the-twist But I remembered that in the SketchUp Community Forums there are free tools that can do the same thing in a snap. So I decided to record a video tutorial. You'll need the SCF Power Toolbar, which includes the "Join edges" tool by Rick Wilson: viewtopic.php?f=180&t=14770&st=0&sk=t&sd=a&hilit=powertoolbar And the "Follow me rotate" script, by wikii: viewtopic.php?f=180&t=13014&st=0&sk=t&sd=a In this video I did a counter-clockwise twist. To do it clockwise, simple input a negative value in the "Rotate" field of the Follow And Rotate script. Remember to check that the line was properly divided before using the "Join Edges" tool; if you don't, the Follow And Rotate tool might not work properly. Tutorial created with Camstudio, a free and open-source excellent little piece of software, and subtitles added in Windows Movie Maker. " -Miguel Lescano
Subscribe to my house plans YouTube channel! (30K+ subs) Re: [Plugin] follow me rotateNow I see. It's all hidden normally.
Thanks. Etaoin Shrdlu
Re: [Plugin] follow me rotateI thought this plug-in would be useful in finally solving the missing "sweep" tool, so I tried it. More specifically, I showed this one before, trying to make a squared handrail on a spiral staircase. Using follow me doesn't work because it curves the form so that the top isn't parallel with the ground. For this spiral stair case the steps are rotated 30 degrees so I tried the ruby with a 30 degree input. Totally didn't work. I tried various different inputs and I finally found one that visually, was "good enough". The input was -3 degrees.
Can you take a look and let me know if there is a better number and if I there should be some relationship that can always be used to figure out what angle to use? Even if not, this saves just a ton of time as is and it is quite adequate for this job too! Thank so much. Susan Sorger
Seller Hand Rendered Entourage Canadian Authorized Training Centre, SketchUp http://www.entouragearts.com Re: [Plugin] follow me rotateAnother script still in development can do followme and keep the profile from rolling.
Left part of the first image is followme ,right part is follow_me_and_keep . In the second image ,the Long Corridor (exclude columns) is built by follow_me_and_keep after one time running.
Re: [Plugin] follow me rotateFantastic! Can't wait.
Susan Sorger
Seller Hand Rendered Entourage Canadian Authorized Training Centre, SketchUp http://www.entouragearts.com Re: [Plugin] follow me rotateFollow_me_and_keep should be a big hit among fans of the Great Wall, and will certainly help a lot when modeling roads. Keep up the excellent work, wikii!
Mrs. Susan, for your specific case, the screw1_5.rb script works well, too. Unlike FollowMeRotate, with screw1_5.rb you have to select both the face and its borders, and it only works around the blue axis, so before using it you have to center your stair in the origin. You can find it here: http://www.crai.archi.fr/RubyLibraryDep ... crew1_5.rb The "first end" and "second end" that you are required to enter are just required to determine a differential in height, so, irrespective of where you click, the shape will always be created around the blue axis. -Miguel Lescano
A must have tool! Welcome to try Thea Render, Thea support | kerkythea.net -team member
Re: [Plugin] follow me rotateUntil follow_me_and_keep is ready (which will save all these following steps), here's a workaround:
- Go to Camera > Standard Views > Left - Draw your profile within the plane formed by the positive blue and green axis, touching the origin. - Erase the face leaving the lines, and make it a component. - Select your profile (it must be a curve or a polygon, if it isn't, first join the edges with the join tool by Rick Wilson in the SCF Power Toolbar). - Use the "copy along distance" button on the SCF Power Toolbar (also a script by Rick Wilson) and play with the distance until you're satisfied. - Select all instances of the component and explode them. You can use Rick Wilson's script "select all instances": http://www.smustard.com/script/Instances - Click on the "configuration" button of the "Skin" script by Darrel to "By order". Leave the other options blank. - Execute the "skin" command and keep pressing "Enter" like crazy until the full object is done. - Add soften/smooth edges to your taste. You can download the "skin" script from this post: viewtopic.php?f=180&t=1306&st=0&sk=t&sd=a&hilit=skin&start=105#p101209 And you can browse the rest of that thread for the latest version of skin.rb, too, if you want... Yeah, it's a lot of extra work, that's why all await for follow_me_and_keep. -Miguel Lescano
Subscribe to my house plans YouTube channel! (30K+ subs) Re: [Plugin] follow me rotateThis is pretty fun to play with.
If I make it look easy. . .then it probably is.
