[Plugin] follow me rotate
Re: [Plugin] follow me rotate
Postby Einstein » Sun Jan 07, 2018 12:03 am
Houson, I have a problem :(
I installed Follow and rotate, checked that all files have been pasted into Plugins folder. I clicked the extension record but the plugin window didn't show up :( Instead, Ruby throwed an error:
Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
c:/users/dell/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:42:in `add'
c:/users/dell/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:42:in `wikii_push_pull'
c:/users/dell/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:109:in `block in <main>'
SketchUp:1:in `call'
I preselected a face (with and then without its bounding edges, as TIG advised) and a welded path-curve but nothing happened. Adding quide point at the begining and ending of path did not help either. I read that many people had similar problem formerly but I didn't find solution in the thread.
I removed the .rbs file with _en suffix which prevented SU from splashing error on startup but still I cannot run the tool.
Einstein
Postby Dave R » Sun Jan 07, 2018 1:10 am
Einstein, see this. It doesn't work in SU2017 or SU2018 and the author would need to fix it because it is encrypted. So far the author hasn't shown any interest in fixing it, though.
Global Moderator
Postby ninja29 » Fri Mar 30, 2018 7:34 am
hi, how to i install this rbz file to sketcup 2017? thank you
ninja29
Postby Dave R » Fri Mar 30, 2018 11:59 am
ninja29 wrote:hi, how to i install this rbz file to sketcup 2017? thank you
If you've downloaded the RBZ file to your computer, use Install Extension which will be found in Window>Extension manager. There's not much point installing this one, however. If you read my post before yours and follow the link I provided, you'll see it doesn't work in SU2017.
Global Moderator
Problem Problem...
Postby aleksandri » Thu Jul 12, 2018 10:37 am
somethings's wrong.. I can't get it to work properly
aleksandri
Postby TIG » Sat Jul 14, 2018 5:58 pm
Go back to posts over a year ago where it's explained how to remove the incorrect RB file so that it at least loads.
However, since it's already been reported as flaky in v2017, its encrypted files might not now be fixable...
Global Moderator
Postby hikamalsingh » Sun Nov 04, 2018 9:43 pm
Hi Wikii ... please help
I am using sketup2018pro
I have loaded the new file Far_v1.0
I am selecting the follow curve and then the plane (without edges)
and its giving me the following error
c:/users/kamal/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in `add'
c:/users/kamal/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in `wikii_push_pull'
c:/users/kamal/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:109:in `block in <main>'
thanks
hikamalsingh
Postby Dave R » Tue Nov 06, 2018 3:34 pm
hikamalsingh wrote:Hi Wikii ... please help
It's already been reported that this extension doesn't work in Su2017 or SU2018. See the previous posts in this thread regarding that. It appears that the author isn't going to update it for newer versions of SketchUp. At least they haven't yet.
Global Moderator
Postby TIG » Tue Nov 06, 2018 3:42 pm
As Dave says the original author hasn't supported this tool for many years.
It doesn't work in any of the newer SketchUp versions.
Under the terms of its © notice it could be reworked and republished, but I looked at it last year and found that to make it compatible with newer SketchUp could involve so much work it might as well be rewritten from scratch !
So search for an alternative tool...
Global Moderator
Postby maxosmedia » Mon Mar 25, 2019 8:39 pm
Is the plug-in module dead? Does not work on SU 2018-2019
maxosmedia
Postby Dave R » Mon Mar 25, 2019 8:45 pm
maxosmedia wrote:Is the plug-in module dead? Does not work on SU 2018-2019
If you read the posts above yours, you'll see that it hasn't been updated in quite a long time. Evidently the author has elected not to support it anymore.
Global Moderator
Postby Swick » Wed Apr 17, 2019 9:22 pm
I get this error in the ruby console:
c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in `add'
c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in `wikii_push_pull'
c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:109:in `block in <main>'
Swick
Postby Dave R » Thu Apr 18, 2019 3:06 pm
Swick wrote:I get this error in the ruby console:
If you read the last few posts in this thread you would know that this plugin hasn't been updated in years. It appears the author no longer supports it.
Global Moderator
Postby duanekemp » Tue Jan 07, 2020 9:52 am
What plugin would be suggested to replace Follow me rotate for the newer versions of SU that would follow a bezier curved line?
Duane Kemp
Kemp Productions
Puidoux, Switzerland
Gallery:
https://duanekemp.artstation.com/
duanekemp
Postby pilou » Tue Jan 07, 2020 11:36 am
Helix along curve ?
(can't test on the new versions :cry:
Speedy Galerie
Top SketchUcator
Postby duanekemp » Fri Jan 10, 2020 12:44 am
Pilou,
I'll give that a try. Thanks
Duane Kemp
Kemp Productions
Gallery:
duanekemp
Postby andrea1980 » Fri May 29, 2020 1:18 pm
hello, when I install the Follow me and rotate plugin and open sketchup it gives me Error: SketchUp: 1: in `eval 'and the extension doesn't work. how can i use it?
andrea1980
Postby Dave R » Fri May 29, 2020 1:39 pm
andrea1980 wrote:how can i use it?
You'd need an old version of SketchUp. If you read a few posts up from yours you will see this plugin does not work with SketchUp 2017. It hasn't been supported for years. Best thing is to look for a different tool to do what you want.
Global Moderator
Postby andrea1980 » Fri May 29, 2020 1:48 pm
do you know a plugin that has the same follow me and rotate functions for sketchup 2017?
andrea1980
Postby Dave R » Fri May 29, 2020 2:04 pm
Again, if you read the last few posts in this thread you can see that Pilou offered a possible alternative. There may be something else that could do what you are trying to do but you haven't told us that, yet. You could start a new thread in the Newbie category, share your model file and describe what it is you are trying to accomplish. We'll surely be able to give you guidance.
Global Moderator
Postby andrea1980 » Fri May 29, 2020 2:31 pm
Thanks Dave for your availability. I have to make a model similar to this in the photo. what can i use? https://youtu.be/rfWNn6Yfyhs?t=415
andrea1980
Postby pilou » Fri May 29, 2020 4:24 pm
Helix along a curve by Albertsoft above don't work for the 2017 ?
Helix along curve 0.9
Support Sketchup 2017, 2016, 2015, 2014, 2013, 8 & 7
If you want see some examples without Plugins take a look at Kito Raupp ;)
Speedy Galerie
Top SketchUcator
Postby andrea1980 » Sun Jun 07, 2020 9:55 pm
Thanks for the advice you have given me, with helix along curve I managed to draw what I wanted. Thanks
andrea1980
Postby pilou » Mon Jun 08, 2020 12:21 am
Dancing things! :enlight:
Speedy Galerie
Top SketchUcator
Postby RAVZ » Sat Aug 08, 2020 12:21 pm
Hei, I am facing a problem regarding this plugin. When i installed it a load error is generated saying Error: sketchup:1:in 'eval'. Moreover, this plugin is not working. It is showing in "Extension" Tab but not working even after trying various permutations of usage. Please, rectify this error along with the specified glitch.
RAVZ
Postby Dave R » Sat Aug 08, 2020 3:10 pm
If you read back through the last few pages of this thread you will see that this plugin does not work in SketchUp 2017 or later and is not supported anymore. Best to use some alternative. Pilou provided some options a few posts up from yours.
Global Moderator
Postby RAVZ » Sun Aug 09, 2020 1:06 pm
Dave R wrote:If you read back through the last few pages of this thread you will see that this plugin does not work in SketchUp 2017 or later and is not supported anymore. Best to use some alternative. Pilou provided some options a few posts up from yours.
Thanks people for telling me that the plugin named "follow and rotate" doesn't work in SU17 and later versions. But anyone please enlighten us with the alternative(s) till the time author brings the updated version of FaR so that there is no lag in work. Thank You! :D :D
RAVZ
Postby Dave R » Sun Aug 09, 2020 1:35 pm
There is probably some other extension that will do what you need. Which one depends on exactly what you are trying to model.
I wouldn't hold my breath. It's been years since the author made any updates to this extension. I think it's fairly safe to assume there won't be any.
Global Moderator
Previous
Return to Plugins
Users browsing this forum: dilveer, jakataboy, lokinini, smartbunnyTuts and 18 guests
