by TIG » Tue Jul 01, 2014 9:04 am
@pep If you can't be bothered to read... Here's a précis... Delete the file FaR .rb, which has the 'en' suffix. When SketchUp restarts the 'cn' version will load properly, giving you the ENglish version [perversely!] The faulty 'en' version will not be there to load and so no more errors at startup.
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by pep75 » Thu Jul 03, 2014 8:06 am
Oh no TIG, then you misunderstood me...I was actually very glad with your analysis  ..But I did what you wrote down and it still gave an error message(only deleting the cn version). I just removed the plugin, installed it again, removed the CN file...and again the error. Maybe my 'cocktail' of plugins doesn't match with this particular one!  Well please don't spend to much time on this as I'm, I guess, the only one with this problem...Thanks Tig!
pep75
- SketchUp version: 2015
- License type: Pro
- SketchUp use: interior design
by TIG » Fri Jul 04, 2014 11:09 am
@pep NO ! You do NOT remove the CN suffixed version Leave it where it is. It is actually the ENglish version within the CN wrapper, owing to a code typo by the author. So that CN version loads and works OK - giving ENglish menus rather than the ChiNese ones it was meant to make... In v2014 the EN has some ChiNese text which causes failures... So if you remove the EN version that error will stop appearing as SketchUp starts. The CN one loads and works OK on its own... BUT the EN one will always fail in v2014, so NOT having that EN one load just stops any related errors !
- Global Moderator
- Name: TIG
- License type: Pro
by pep75 » Fri Jul 04, 2014 11:47 am
Sorry, will try it! Thanks!
pep75
- License type: Pro
by myskp99 » Sun Sep 07, 2014 3:08 am
Hello mates, hope one can answer this: installed the rbz file of follow me and rotate and it works, but at the begining of the program i get this message: Error: c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8) c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8) c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end inp=Inputbox.new "±äÐθúËæ" ^ -e:1:in `eval' hope some help, why does this happen? thanks
myskp99
- Name: Juan
- SketchUp version: 8
- License type: Free/Make
- Level of SketchUp: Beginner
by TIG » Sun Sep 07, 2014 12:52 pm
myskp99 wrote:Hello mates, hope one can answer this: installed the rbz file of follow me and rotate and it works, but at the begining of the program i get this message: Error: c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8) c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8) c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end inp=Inputbox.new "±äÐθúËæ" ^ -e:1:in `eval' hope some help, why does this happen? thanks
See a few posts back viewtopic.php?p=530627#p530627 and then viewtopic.php?p=531322#p531322One of the .RBS files inside the RBZ is wrongly encoded [in Chinese!], so if you delete it the other version will load and work OK... Note the error in the file naming that is confusing - remove the EN but keep the CN version...
- Global Moderator
- Name: TIG
- License type: Pro
by gonashvili » Thu Sep 03, 2015 4:19 pm
Seems super.
Does it work for a free v8?
Can't seem to install this.
gonashvili
- Name: Hamlet G
- License type: Pro
- SketchUp use: woodworking
by TIG » Thu Sep 03, 2015 5:30 pm
gonashvili wrote:Seems super.
Please [re]read the post immediately before your own... viewtopic.php?p=537020#p537020You need to access this plugin's folder inside Plugins, and then delete an RBS file - illogically the EN version is wrong! - keep the CN one...
- Global Moderator
- Name: TIG
- License type: Pro
by gonashvili » Sun Sep 06, 2015 11:46 pm
Oh I had it working, just couldn't find it in the menu at first, then forgot to delete my post. Cheers
gonashvili
- Name: Hamlet G
- License type: Pro
by alnahrini » Wed Apr 13, 2016 9:08 am
Hi guys,,
i just installed it, but i have this error message Note: am using sketchup 2016
Error: c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8) c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8) c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end inp=Inputbox.new "±äÐθúËæ" ^ SketchUp:1:in `eval'
please can any one help me..
thanks in advance
alnahrini
- Name: alnahrini
by Dave R » Wed Apr 13, 2016 3:37 pm
alnahrini wrote:Hi guys,,
thanks in advance
Read TIG's post just a few up from yours.
- Global Moderator
- Name: Dave R
- License type: Pro
by pipinek » Thu Apr 14, 2016 8:39 pm
After installing the plugin on SU 2015 I have the following message on SU start:
Error: c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8) c:/users/artur/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8) c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end inp=Inputbox.new "±äÐθúËæ" ^ SketchUp:1:in `eval'
I will be thankful for any solution to this issue. Thank you in advance.
pipinek
- Premium Member
- Name: HansKloss
- SketchUp version: 2018
- License type: Pro
- SketchUp use: urban planning
by Dave R » Thu Apr 14, 2016 8:44 pm
pipinek wrote:I will be thankful for any solution to this issue. Thank you in advance.
You might do the same thing I suggested in the post just above yours in response to the post before that in which the poster reported the exact same problem.
- Global Moderator
- Name: Dave R
- License type: Pro
by irminv » Sat Oct 15, 2016 11:23 am
I installed the plugin, but I get an error message whenever I start SU. also the plugin is not visible as a toolbar. I have SU15 pro...
irminv
- Name: irmin
- SketchUp version: 2013
- License type: Pro
by TIG » Sun Oct 16, 2016 3:26 pm
Reread this, about using the correct [but oddly named] version viewtopic.php?p=537020#p537020
- Global Moderator
- Name: TIG
- License type: Pro
by Dave R » Mon Oct 17, 2016 12:04 am
irminv wrote:also the plugin is not visible as a toolbar. I have SU15 pro...
What makes you think there is a toolbar button that is missing? If you watch the tutorial video in the first post, you see it tells you the tool is accessed through the Plugins menu which is now called the Extensions menu.
- Global Moderator
- Name: Dave R
- License type: Pro
by Albert95 » Sat Feb 25, 2017 2:19 pm
Hello wikii Is it possible to update "follow me and rotate" for sketchup 2017 ?
console ruby Error: #<NoMethodError: undefined method `curve' for nil:NilClass> c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:28:in `wikii_push_pull' c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:109:in `block in <main>' SketchUp:1:in `call'
thank you Albert
Albert95
- Name: Alain
- SketchUp version: 2017
- SketchUp use: hobby
by Albert95 » Sun Feb 26, 2017 2:28 pm
Hello, I followed the advice of Tig : "Find the 'en' version and remove it from the v2014 Plugins folder [find that folder using the appropriate utility in the SketchUcation submenu]." viewtopic.php?f=323&t=13014&start=120#p530627But "FAR" does not work properly to model a rope. Can I get help thank in advance Albert
Albert95
- Name: Alain
by chri » Mon Mar 06, 2017 10:36 am
hi
Same problem as Albert . I had trying after removing the "en" file but the plugin still does not work ! The error message has disappeared but i don't see the plugin menu.
chri
- Name: christian
- License type: Pro
- SketchUp use: engineering and mechanical design
by TIG » Mon Mar 06, 2017 12:16 pm
@chri You do not seem to have actually removed the ..._en,rbs file as the error-message relates to that ! To recap... There are two version of the plugin installed by the RBZ. The ..._en one loads in preference to the .._cn one, Perversely the .._en one has issues because of Chinese characters etc - so that needs removing [..._en.rbs] and the other one [with ..._cn.rbs ending] will be used loaded successfully... viewtopic.php?p=531322#p531322 Note how the author has misnamed the two files before encrypting them !
- Global Moderator
- Name: TIG
- License type: Pro
by Box » Mon Mar 06, 2017 12:21 pm
I'm not sure the plugin works properly on 2017 anyway. I installed it earlier and it was very flaky, (highly technical term).
- Name: Box
- SketchUp version: 2020
- License type: Pro
- SketchUp use: other
by pilou » Mon Mar 06, 2017 12:35 pm
- Top SketchUcator
- Name: Pilou
by TIG » Mon Mar 06, 2017 1:59 pm
I've not tested it in v2017 - but if it is "flaky" it will now be unfix-able because its code is encrypted !
- Global Moderator
- Name: TIG
- License type: Pro
by chri » Mon Mar 06, 2017 2:19 pm
TIG wrote:I've not tested it in v2017 - but if it is "flaky" it will now be unfix-able because its code is encrypted !
Hi TIG your are righ, i made a mistake during installation it works fine with 2015 2016 but not 2017 version. Thanks
chri
- Name: christian
- License type: Pro
by CoreMaster110 » Thu Apr 06, 2017 12:48 pm
Doesn't work with 2017 version. I removed the en version of the file. I made polyline and a face, selected both, clicked "Extensions/FollowAndRotate" but nothing happens, no dialog box.
CoreMaster110
- Name: Karl H. Künstler
- License type: Pro
by Dave R » Thu Apr 06, 2017 1:21 pm
CoreMaster110 wrote:Doesn't work with 2017 version.
Yes, if you read the posts above yours, this has already been reported. Unless the author fixes it, the extension won't work, It doesn't seem likely that the author will fix it so it's probably a good idea to find other ways to manage what you did with this one.
- Global Moderator
- Name: Dave R
- License type: Pro
by pilou » Thu Apr 06, 2017 2:34 pm
...or use an old version of Su!
- Top SketchUcator
- Name: Pilou
by targetx » Fri Apr 07, 2017 3:34 pm
Hi guys! Carefully had read everything, made every step as adviced. Installed, removed EN version. No errors, plugin appeared in the menu and everything seemed to be successful, but ... while clicking on the plugin there is NO input box ... Tried on SU 2016 ans 2013 - same result. Please help me to run the plugin  Thanks!
targetx
- Name: Sergey Ivanchuk
- SketchUp version: 2014
- License type: Pro
by duanekemp » Wed Sep 27, 2017 9:08 am
wikii wrote:It is still in developing, here is the current version. Get the latest version as an RBZ from the PluginStore:
wikii, This is such a cool, useful and needed plugin. Alternatives to get similar results are tedious, time consuming and not always effective. If possible, I'd like to encourage the continued development of this plugin for SU2017 and SU2018.... resurrect this puppy so it can be used without reverting to SU 2015/16. I hope you release a new version since this does what needs to be done. And again, thank you for making this!!!
duanekemp
- Name: Duane Kemp
- Operating system: Mac
- SketchUp version: 2019
- License type: Pro
by Ahmed0007 » Tue Oct 17, 2017 2:54 am
Thanks For Plugin Please Update for 2017/18 Thanks
Ahmed0007
- Name: Ahmed
- License type: Pro
- Robot
Return to Plugins
