[Plugin] Double line
Re: [Plugin] Double line
Postby rv1974 » Wed Sep 24, 2008 5:05 am
Hi!
c=circle
x=explode.
Generally the letters are bad idea.
Could it be just cntl click for for close?
rv1974
Postby CadFather » Wed Sep 24, 2008 1:38 pm
i second that
CadFather
PluginStore Author
PluginStore Author
Postby Didier Bur » Thu Sep 25, 2008 7:56 pm
Everybody will agree now, I hope. I finally got the double-click detection to work, so a double-clic will close a shape.
Another small enhancement: when you draw only one segment on an existing face, it takes the face as the base geometric plane (to solve Fletch's issue).
Download it at the top of topic.
Regards,
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby pilou » Thu Sep 25, 2008 10:15 pm
Users presure :D :thumb:
Speedy Galerie
Top SketchUcator
Postby CadFather » Thu Sep 25, 2008 10:34 pm
Thank you Master Didier!
CadFather
PluginStore Author
PluginStore Author
Postby daiku » Fri Sep 26, 2008 12:16 am
Well, that last fix broke it for me. :( I like doing one wall at a time, and it now lays them down flat instead of upright. I'm adding walls to an existing framework, so there are planes adjacent to where I'm adding the wall. PS: if I could undo one wall at a time, that would be great - if I make a mistake and undo, I lose all the work I've done with the tool so far. Thanks, CB.
daiku
PluginStore Author
PluginStore Author
Postby Didier Bur » Fri Sep 26, 2008 7:55 pm
Done. Download it again... :bounce:
Didier Bur
Didier Bur
Postby EarthMover » Sat Sep 27, 2008 2:40 pm
Didier,
Thanks for the plugin, it's great! Any plans to incorporate a double line function for an arc type tool as well?
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby Didier Bur » Sat Sep 27, 2008 10:10 pm
Why not...
Didier Bur
Didier Bur
Postby Mike Lucey » Sun Sep 28, 2008 12:21 am
Thanks Didier :thumb:
Mike Lucey
Mayor
Postby rv1974 » Sun Sep 28, 2008 8:17 am
Didier many thanks for your efforts!
Double click for close is neat idea though I couldn't manage to get good result- it's a bit messy.
rv1974
Postby pilou » Sun Sep 28, 2008 8:37 am
it's a bit messy
? Very clear! :enlight:
A little trick if you find this difficult ;)
Draw your lines without the plug, group it, then redraw with the plug over them! :roll:
Erase the group
Speedy Galerie
Top SketchUcator
Postby rv1974 » Sun Sep 28, 2008 8:49 am
Now I understood: it closes wall in a new point not at the first one. I'm spoiled with CAD background )
@Pilou: With pre-drowed lines extrude lines.rb is better choise imho
rv1974
Postby pilou » Sun Sep 28, 2008 10:39 am
You have not the drawing of the dashed axis line ;)
And you have a thickness with extrude simple lines :?: And a wall :?:
Yes Didier is some original ! :mrgreen:
It's some pertubating but after some try we are in the move! :enlight:
Speedy Galerie
Top SketchUcator
Postby rv1974 » Sun Sep 28, 2008 11:34 am
Pardon, I meant extrude along path .rb (of TIG i beleive).
I'm afraid the wink about dashed line I didn't understand. What do you mean?
rv1974
Postby pilou » Sun Sep 28, 2008 3:32 pm
Just this ;)
Speedy Galerie
Top SketchUcator
Postby gogo2suf » Sun Sep 28, 2008 11:18 pm
Thank You vary much D. Bur ,
Thank you!!!!!!!!!!!!
GOGO
gogo2suf
Postby agrazdi » Wed Oct 01, 2008 3:09 pm
Is it possible to add a png icon into the tool bars for the double line function ?
agrazdi
agrazdi
Postby Fletch » Thu Oct 02, 2008 1:16 am
Didier! You are wonderful... but you already knew this. Thank you for sharing this wonderful update.
Since you love bug-hunting... here's what I get now... it does draw the wall but in the opposite direction from expected... I drew vertically on the 'inside' of this wall... I think it's picking the 'positive' direction of the green axis... perhaps - just a guess.
my axis lines show up now. :D
So, this guy goes to the doctor...
man: "Doc, my arm hurts when I move it like this."
doctor: "Well, don't move it like that."
Fletch
Twilight Render
Postby gamore » Thu Oct 02, 2008 3:11 am
some errors
what should i do?
gamore
Postby RickW » Thu Oct 02, 2008 6:42 am
That's caused from "sketchup.rb" not being loaded. Didier should be able to fix that in no time.
RickW
Postby gamore » Thu Oct 02, 2008 9:50 am
gamore
Postby lengai » Thu Apr 08, 2010 7:49 pm
HI - perhaps a little out of date, but this post appears active (despite last input Oct '08!)
Didier did you have an fix for RickW's error as I have got the same message?
'Error Loading File dline.rb
(eval):514: undefined method `file_loaded?' for main:Object'
Any pointers appreciated - i've got a pile of single lines from an OS map, representing adjacent site walls which I would like to double up and extrude (SU speak 'pull') - I figure Dbl Line will do it?
Thanks.
lengai
Postby Didier Bur » Fri Apr 09, 2010 10:45 pm
Hi, I've released a patch today (10.04.10)
See page 1 of the thread.
regards,
Didier Bur
Didier Bur
Postby lengai » Sat Apr 10, 2010 9:17 am
Didier thanks for snappy comeback! Still getting error message though..
I'm running SU7.1 pro on Vista in case that makes a difference?
Thanks, L
lengai
Postby Didier Bur » Sun Apr 11, 2010 8:37 pm
I don't understand what's happening on your side but it works here.
So the second patch uploaded page 1 of this thread is a version without a call to the offending method "file_loaded?". It SHOULD work.
Regards,
Didier Bur
Didier Bur
Postby simon le bon » Wed Apr 14, 2010 11:36 am
Cher Didier,
Happy to see you coming time to time into SCF. Hope you feel good. For me, several of your tools are definitively adopted!!
(Projections tools is an absolute must :thumb: :thumb: :thumb: )
As you probably know, we have intermittent problems to reach your Ruby Library Depot
About DOUBLE LINE I would like indicate to you a problem with French version. As far, we can't draw the walls because hitting ENTER key calls nothing. So I'm using English version which works fine. ;)
*simon
simon le bon
Postby Didier Bur » Fri Apr 16, 2010 8:29 am
Hi Simon,
Yes I know, we had serious problems with our server and it has moved to another computer, but it seems that this is not really the solution.
The RLD site is in complete rework, I hope that in June you'll have a brand new site where (among others) you can submit your plugin yourself, or provide a link to your blog/site, etc.
P.S.: pour la version française je ne comprend pas leproblème puisque c'est le même code avec juste les messages et menus traduits. Je regarde ça dès que possible.
Didier Bur
Didier Bur
Postby taralee324 » Sat Oct 16, 2010 3:35 am
Dider, you made my day!!! This makes my life much easier.
A couple of suggestions...
1) Can you add a "Set Defaults" button so that I can be lazy and save my preferred settings between opening/closing SketchUp?
2) Can you add functionality so to support switching to the pan/orbit tool and back w/o loosing the current path being drawn?
Even without... love it!
taralee324
Postby JuanV.Soler » Sat Oct 16, 2010 9:09 am
Thanks Didier great help :thumb:
just downloaded your plugin, did not noticed before.
_,_)))_,_
JuanV.Soler
PreviousNext
Return to Plugins
Users browsing this forum: Google Bot, jnjreid, samuel_t and 15 guests
