SketchUcation Plugin Store
[Plugin] Lines to tubes
Re: [Plugin] Lines to tubes
Postby Pilou » Thu Feb 18, 2010 9:18 am
@majid
for some things you can use that ;)
A cool use of this "Multiple Face Offset" By Remus :fro:
If you don't use it in this case Windowizer(3 free or 4) By Rick Wilson @Smustard
don't make the "Frame Inset"! ;)
Windowizer is a crazzy plug : All types of piercing windows + multiple selections :shock:
Selection Only faces by Selection Toys by Thomthom :enlight:
Invert Selection by TIG :enlight:
For Crazzy Geodesic domes By TaffGoch @ 3Dwarehouse :shock:
His site :ugeek: Crazzy PDF collector! :fro:
Speedy Galerie
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Advanced
Postby TIG » Thu Feb 18, 2010 11:12 am
My EEbyFace also does something similar but it allows you to define the extrusion's cross section by making a 'flat' face [it's Y green axis = extrusions initial Z blue axis] - the face can be any shape you like so you are no longer limited to circular tubes...
Global Moderator
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Postby harshal kshatriya » Sun Feb 21, 2010 10:08 am
wow its working man............
i love it
thanks a lot :thumb:
harshal kshatriya
SketchUp version: 7
License type: Pro
Postby cadmunkey » Mon Jul 05, 2010 4:32 pm
Just installed this plugin and its great for converting custom autocad hatches into solids. Thanks man!
cadmunkey
Postby Pilou » Mon Jul 05, 2010 4:35 pm
Didier Bur plug "Line to tubes" can make circles of 3 edges so a triangle, 4 edges so a square, etc...:enlight: ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby agamemnus » Sat Nov 20, 2010 8:36 pm
I tried this, but the tubes don't get "welded" / smoothed at edges:
http://img109.imageshack.us/i/tubes.png/
Is there a plugin that does this?
Edit: Ok, never mind.. I used BZ tools to convert my loop to a bezier curve (edit 2: polyline is better, actually, for this...), and then applied this plugin. It's all welded now! :)
agamemnus
Postby alvin_pox » Fri Oct 14, 2011 5:16 pm
Hi.
I've downloaded the .rb file in the plugin folder but when I restart sketchup, I keep getting a pop-up window with the following...
Error Loading File lines2tubes.rb
undefined local variable or method `book' for main:Object
This plugin would really help with my design project greatly, so I'm really hoping someone here could help me get it to work.
I'm using sketchup 8 on mac btw.
Thanks.
alvin_pox
Postby TIG » Fri Oct 14, 2011 10:46 pm
Sounds like the file is corrupted as there is no reference to 'book' in it. :?
Get the file again and put the .rb file into the Plugins folder, and retry.
Don't edit it with a word-processor or similar as this might corrupt it...
The file is 'packed' and is unencrypted as it loads - I have no problems with it so you seem to have messed up something in the file's text itself ? :?
Global Moderator
License type: Pro
Postby alvin_pox » Sat Oct 15, 2011 2:05 am
TIG wrote:Sounds like the file is corrupted as there is no reference to 'book' in it. :?
Have downloaded the file again and it works now!
I noticed that the file I had yesterday had a big red "Rb" on the file icon thumbnail, but it doesn't today after I redownloaded it.
I also tried other plugins yesterday and all seemed to get the same error message when loading and the big red Rb on their thumbnails, so it doesn't look like it was a single corrupted file. Weird.
But it's all sorted now. Thanks so much:p
alvin_pox
Postby majid » Sat Oct 15, 2011 5:06 am
Thank you Pilou
I was specting junction spheres. like this , 1 min try wings3d ( it is handy in some cases, while a different approach, and is easy enough for me that am not a 3dsmax fan)
درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
majid
Top SketchUcator
SketchUp version: 8
Postby Pilou » Sat Oct 15, 2011 2:12 pm
And Wings3D can reload 3DS format from 3Dwharehouse or from SU ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby majid » Sat Oct 15, 2011 5:15 pm
yeap, it has wide range of import/export formats included. very handy,... sort of free subd/smooth ;)
majid
Top SketchUcator
SketchUp version: 8
Postby btxscg » Sat Oct 29, 2011 7:52 am
it's great :berserk:
btxscg
Postby irwanwr » Wed Nov 30, 2011 8:51 pm
i'd like to thank the author, Didier for this very useful plugin.
i used to utilise the push/pull tool before. with this plugin, i could just do it on the line frames and one or two more clicks.
thank you very much :thumb:
irwanwr
SketchUp version: 8
SketchUp use: hobby
Level of SketchUp: Beginner
Postby Steuart » Sat Mar 03, 2012 1:17 pm
Hi Didier and all.
I have just installed the Lines2tubes plug in. Initially I tried to use it and it crashed (of course before I had saved anything - auto save does not seem to work unless you have done at least an initial save). Then each time I tried to re:launch SU it would instantly crash. I also tried TubeAlongPath and pretty much the same thing happens. In each case it was fine once I had remeoved the plug in. Anyone any ideas? I am using a Macbook pro, with 10.5 and SU 8. I would love to be able to use the program as it would save a huge amount of time.
Steuart
Postby TIG » Sat Mar 03, 2012 5:07 pm
Might it be the scripts are getting corrupted?
How are you downloading / installing them ?
DO you have other scripts that work OK ?
Global Moderator
License type: Pro
Postby Steuart » Mon Mar 05, 2012 1:25 pm
Hi Tig,
I simply put them into the plugins folder - the same as i have put several other plugins (see list below - I have removed the lines2tubes and the other similar plugin that was crashing the program) with no problems (hard disk/library/application support/google sketchup 8/sketchup/plugins
centerpoint.rb
DEFPARAM_Dir
Examples [folder]
examples.rb
Fredo6Trace.txt
LIBFREDO6_Dir_43
LibFredo6.rb
LibTraductor.rb
maxwell[folder]
maxwell.rb
Ocean[folder]
ocean_extension.rb
ROUNDCORNER_Dir_23
Smooze[folder]
Soften.rb
Utilities[folder]
utilities.rb
ZLoader__RoundCorner.rb
Steuart
Postby TIG » Mon Mar 05, 2012 9:44 pm
Global Moderator
License type: Pro
Postby bharvey » Thu Aug 09, 2012 2:54 pm
:D You're freaking awesome Didier!
Guard/Handrails just got alot easier.
Thanks!!!
bharvey
Postby ninehundred » Sun Jan 13, 2013 4:03 pm
also, here is a picture of the one ive made in blender but as mentioned before you cant edit the joins or create a join.
http://archibitd.tumblr.com/image/40256783011
ninehundred
Postby TIG » Sun Jan 13, 2013 5:47 pm
ninehundred wrote:also, here is a picture of the one ive made in blender but as mentioned before you cant edit the joins or create a join.
I've given some pointers in your other very similar thread...
Global Moderator
License type: Pro
Postby slocraftus » Tue Apr 09, 2013 1:52 pm
how can i download this plugin?
slocraftus
SketchUp version: 8
License type: Pro
SketchUp use: product design
Postby gilles » Tue Apr 09, 2013 2:01 pm
First page, don't you read the post?
gilles
Top SketchUcator
Operating system: Mac
SketchUp version: 8
SketchUp use: other
Postby slocraftus » Tue Apr 09, 2013 2:02 pm
will it be useful to create the rope on knife?
or can you tell me the better plugin,if it exists
slocraftus
SketchUp version: 8
License type: Pro
Postby gilles » Tue Apr 09, 2013 2:08 pm
Any reference image?
gilles
Top SketchUcator
SketchUp version: 8
SketchUp use: other
Postby Pilou » Tue Apr 09, 2013 4:29 pm
Some plugins about that are there!
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: alibaloc, Dave R, horskz, vicspa, ville_, yamanokuchi and 12 guests
