SketchUcation Premium Membership
[Plugin] Lines to tubes
Re: [Plugin] Lines to tubes
Postby gaucho » Mon Sep 01, 2008 9:16 am
Thanks didier!
It works great!
I've already used... :)
One single possible request... would be possible to modify so we could extrude along square shapes as well?
So in Solo's image above for example, i could quickly build beans, columns.. etc etc.. all square?
Thanks again!
PS: i've just donwloaded your all in one file... i'm feeling it'll take me ages to check them all...
"eat well, stay fit, die anyway..."
gaucho
Postby sepo » Mon Sep 01, 2008 12:07 pm
for the problems, maybe you must disable the old "line2cyl.rb"?
maybe...
for me it works with old tool....
Thanks Didier for a very usefull plugin... I was wondering if there is way to clean up intersection...
sepo
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby urgen » Mon Sep 01, 2008 12:17 pm
...thanks,Didier!...I expected it for a long time! ;) :D
--pupil forever...------
urgen
Postby rv1974 » Mon Sep 01, 2008 12:30 pm
Very nice Didier, thanks
Additionally may be you could:
1/ add a rotation parameter (when precision is 4 one would get square section (rotation 45))
2/now I weld lines to get continuous result. Any chance to get it automatically?
3/conjunctions?
rv1974
SketchUp version: 8
License type: Pro
Postby urgen » Mon Sep 01, 2008 1:32 pm
Pilou wrote:for the problems, maybe you must disable the old "line2cyl.rb"? ;)
maybe...
...yes! "line2cyl.rb" should be deleted :D
...Didier, please restore this function in "projection_extension.rb" ;)
urgen
Postby johnsenior1973 » Mon Sep 01, 2008 2:04 pm
Deleting the lines2cyl ruby did sort out the problem.
johnsenior1973
Postby Didier Bur » Mon Sep 01, 2008 4:54 pm
Hi all,
Sorry for the inconvenience of the "not showing plugin" problem. My fault. You must delete old "line2cyl.rb" of your plugins folder OR I must correct the name of the plugin in the code (I forgot to change it). If line2cyl is loaded first, SU doesn't create another menu item in the tools menu for the new version.
Use a precision of 4 and you'll get square section prisms.(RTFM)
Does this make sense ? This function has nothing to do with projection IMHO...
The script can't do it (I mean, quite difficult to code). A workaround is to draw as much curves as you can, and select "Yes" in the "follow-me on curves" option. But it cannot clean intersections on T or Y or X branching edges.
Maybe next version will do it ?
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
SketchUp version: 8
License type: Pro
Postby Frederik » Mon Sep 01, 2008 7:53 pm
THANKS A LOT, Didier..!!
Frederik
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby Dylan » Mon Sep 01, 2008 8:14 pm
Thanks Didier.
Could this be adapted to use a semi-circle with thickness? I am thinking of use for ridge tiles on a roof.
Dylan
Postby urgen » Mon Sep 01, 2008 10:24 pm
Dylan wrote:Could this be adapted to use a semi-circle with thickness? I am thinking of use for ridge tiles on a roof.
...HA!...good idea,Dylan! ;) :D
urgen
Postby ely862me » Tue Sep 02, 2008 12:45 am
:thumb: :ecstatic:
Another piece of....what????...let*s say Pandora*s box!!
This will help me to make tubular chassis instead of what i was making before.
Thank you Mr. Didier!!
Elisei
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby utiler » Tue Sep 02, 2008 2:05 am
maybe...
Ditto Sepo, I found the same thing...
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby 2myChaGrin » Tue Sep 02, 2008 2:22 am
Thanks so much Didier! You just made my life so much easier!
2myChaGrin
Postby boofredlay » Tue Sep 02, 2008 2:42 pm
maybe...
I did not have a chance to look at this until now on my work machine. I had line2cyl.rb here as well. I installed Lines to tubes and got the same results... not showing up. So I then tried as you suggested Pilou, deleting line2cyl.rb and now it is showing up.
Thanks. :thumb:
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
Postby Marian » Tue Sep 02, 2008 4:49 pm
i think there should also be an option to make not round tubes but square hexagonal triangular ones.
Marian
Postby gaucho » Tue Sep 02, 2008 5:35 pm
Simple anD easy.. MERCI!
gaucho
Postby Juju » Tue Sep 02, 2008 7:01 pm
Marian wrote:i think there should also be an option to make not round tubes but square hexagonal triangular ones.
I think if you downloaded the plugin and checked the manual you'd see that it already does what you want.
Keeping things organised is not a sin. ;)
Juju
Postby Didier Bur » Tue Sep 02, 2008 9:48 pm
Read the doc and USE PRECISIOn :bounce: !!!
You beat me on this Juju !
Didier Bur
SketchUp version: 8
License type: Pro
Postby CameronVan » Wed Sep 03, 2008 12:55 am
maybe...
Thanks. :thumb:
Ahhh, great.
Thanks Pilou!
CameronVan
Postby Marian » Wed Sep 03, 2008 7:43 am
Silly me....i did download the plugin and tried it before posting that...which makes me a bigger fool...but i didn't try the options...and manuals...who ever reads them? :P
Marian
Postby Didier Bur » Wed Sep 03, 2008 7:55 am
Those who don't want to bother doc writers :lol:
Didier Bur
SketchUp version: 8
License type: Pro
Postby lorca » Sat Sep 19, 2009 10:29 am
Great plugin. Is there a way to close the gaps in sharp corners just like in "Pipe Along Path"?
lorca
Postby lexmonteiro » Mon Sep 21, 2009 2:45 pm
Great plugin, I was trying to create a window and realized that using precision 4, the corners were at 45 degrees, can I control the orientation of the angles?
Thanks!
lexmonteiro
Postby chango70 » Thu Nov 19, 2009 3:59 am
Doesn't show up for me. I don't have older version at all. Any ideas?
chango70
Postby xrok1 » Thu Nov 19, 2009 4:31 am
i just DLd and it showed up in tools menu.
thanks dedier! :D
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby chango70 » Thu Nov 19, 2009 5:17 am
Whats DLd?
chango70
Postby chango70 » Thu Nov 19, 2009 5:22 am
Its working now! WOOHOO! Great plugin!
chango70
Postby xrok1 » Thu Nov 19, 2009 5:37 am
chango70 wrote:Whats DLd?
downloaded :oops:
xrok1
Postby flipya » Mon Jan 25, 2010 9:53 pm
I love this plugin! It's so incredibly easy to use and all the options I need are included. A+ for ease of use!
Combined with the soapskin bubble plugin it's almost addictive :shock:
It does sometimes crash my sketchup. The progress percentage builds up, slows down, and eventually just stops. A second or third try (saving before starting) usually does the job though.
All in all, pretty much brilliant!
flipya
Postby majid » Thu Feb 18, 2010 9:04 am
first I must thank you for your handy tool Dider, and then I thought if you could combine this plugin with a geosphere creator + an option to have sphere in junction points, then we would have A LATTIC TOOL ,right in sketchup, that makes space frames easy.
درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Artisan Organic Toolset - a set of powerful organic modeling tools.
Next
Return to Plugins
Users browsing this forum: cgeorg77, cotty, farhadtousi, Google Bot, Jean-Franco, Kable, Scaffman, tibormartin, Woodarc and 13 guests
