by charly2008 » Wed Jul 28, 2010 4:01 pm
I wanted to try compo spray but I get a huge number of components at a small circle. What am I doing wrong?
Charly
Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
charly2008
- Name: Karlheinz Hauser
- Operating system: Windows
- SketchUp version: 7
- License type: Pro
- SketchUp use: historical reconstruction
- Level of SketchUp: Advanced
by Didier Bur » Wed Jul 28, 2010 10:42 pm
Hi, Did you draw a great circle (20m or so) or a small one (2m or so) ? But don't worry, since FaceMe components don't really have a bounding box, the number of components to be created is wrong, if I remember well... Regards,
Didier Bur
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
by charly2008 » Wed Jul 28, 2010 11:01 pm
Hi Didier,
The circle was about three meters. I tried the whole day. If i use it at a single line or a point then i get very small copies.
Charly
charly2008
- License type: Pro
by charly2008 » Thu Jul 29, 2010 2:33 pm
For the above mentioned problem i found the solution. The values for Low and high scale where to less.
But now although Keep vertical is selected, the tree is horizontal. For this I could not find the reason.
Charly
charly2008
- License type: Pro
by charly2008 » Fri Jul 30, 2010 11:43 am
I found the error. This component was the reason. After I exploded the component and made it a new component, the error was gone.
Charly
charly2008
- License type: Pro
by mariocha » Tue Sep 14, 2010 11:07 pm
I'm having difficulty to make it work in SU 8. Confirmation ? But it is my first try, I must say.
Mario C. Certified SketchUp Trainer, QC CA, Mac Pro 2xQuad core & MacBook Pro 3.06 Ghz.
mariocha
- Premium Member
- Operating system: Mac
- License type: Pro
by thomthom » Wed Sep 15, 2010 7:26 am
mariocha wrote:I'm having difficulty to make it work in SU 8. Confirmation ? But it is my first try, I must say.
Exactly what isn't working?
- Global Moderator
- Name: thomthom
- License type: Pro
by mariocha » Wed Sep 15, 2010 2:09 pm
Well, like I said it was my first try. I finally got it after a few more tries. My mistake was to try to "spray" on a face in a group being outside of it. Somehow I assumed that's what it did. Maybe cause I cannot get the "selection" option to work. It just stops and asks to select objects, even when a face is selected before, and it stays suck there, clicking or enter do nothing. I read the manual, again (very well done btw). Maybe a warning line could be added about groups.  Although it is so obvious now.
mariocha
- Premium Member
- License type: Pro
by koolarsenal » Wed Sep 29, 2010 8:50 pm
Didier Bur wrote:Hi all, Here is an update of the component spray tool (updated PDF doc included).
What's new in 1.3.: New "shape" option to drop component at each vertex of selected faces. Bug fix when loading the script on Mac. Bux fix that froze the script when no destination layer were specified. Enjoy !
EDIT: Last version posted 03.09.10 (no more progressbar conflict, not an rbs)
This is my problem with the plugin, can you tell me how to fix it? The table is to big, It isn't match with my screen so I can't see the rest of the table.
koolarsenal
by compadre.lucas » Mon Oct 18, 2010 6:48 pm
thank you so much!!.I;ve been dreaming about this tool for months. I will try it out now. sketchup is infinity.
compadre.lucas
- Name: lucas rivera
by bitslapped » Sat Oct 23, 2010 9:14 am
I initially could not get this to work in selection mode, but it worked fine after removing all my other plugins. Must be some incompatibility, I have quite a few.
One thing I did notice is a tendency for scattered objects to be more dense toward the centre of the regions in all cases. I don't know ruby but it seems whatever random function you are using is a bit biased towards the mean.
That being said, what a fantastic script! Keep up the good work Didier!
bitslapped
by Pilou » Sat Oct 23, 2010 10:32 am
@Kool AS you have just 3 box values missing Just enter your values then press TAB and at the end Press Enter Some rustic but efficient  Below box values missing
Pilou
- Top SketchUcator
- SketchUp version: 6
- License type: Free
- SketchUp use: hobby
by Didier Bur » Sat Oct 23, 2010 1:02 pm
Hi all, I'm on my way to the next release to fix all these minor problems, and to add a webdialog as well. cs2.gif
Didier Bur
- License type: Pro
by thomthom » Sat Oct 23, 2010 2:04 pm
charly2008 wrote:Hi,
Charly
Maybe it was very small in size. What if you Right-Click and choose Scale Definition?
- Global Moderator
- Name: thomthom
- License type: Pro
by thomthom » Sat Oct 23, 2010 2:07 pm
Didier Bur wrote:Hi all, I'm on my way to the next release to fix all these minor problems, and to add a webdialog as well. cs2.gif
That's very cool! Can I just come with a request? Make one multi-select list to pick the components, instead of a fixed 6 slots. And if the selected components can be preselected, that'd be a great user experience addition.
- Global Moderator
- Name: thomthom
- License type: Pro
by Gaieus » Sat Oct 23, 2010 3:35 pm
Thanks a bunch for the new version!!!
When we are at it; could you also add a function whether the tool sprays with that centralized way on a face it does at the moment or not (so that in some ways it would work similarly to the fur plugin or something like "populate")?
Also, beside the sliders, will the fields accept precise, manual input too?
- Administrator
- Name: Csaba Pozsárkó
- License type: Pro
Return to Plugins
