[Plugin] Toggle UnitsRe: [Plugin] Toggle Units
Hi ! I go back on this plugin, with another attempt for Mac users. Edson, Can you try please? ![]() EDIT1 : One other (And I hope the last !) update! Last edited by Matt666 on Thu Dec 11, 2008 4:26 pm, edited 1 time in total.
Frenglish at its best !
My scripts Re: [Plugin] Toggle UnitsCan someone test this last one on Mac, please ?
My scripts Re: [Plugin] Toggle Unitsstill not working on my mac. nothing changes after i click on any icon. and btw, the meter icon is not showing.
Re: [Plugin] Toggle Units..on pc that happens only if fractional or engineering is selected - once i click on decimal (from the toggle units icons) all icons become selectable and everything works..
i think we really need some 'certified mac testers'.. (or they may be left behind) ![]()
Re: [Plugin] Toggle Units+1 for certified mac testers!
Sorry Edson for that and thank you so much to loose some time for script testing ! ![]() Frenglish at its best !
no problem, matt. it is a pleasure to be of help. could you be more specific as to which is the build to be tested? i looked at the first post of this thread and saw nothing different there.
Re: [Plugin] Toggle UnitsYep! On Fedo6 advices, I changed the way that script called preferences units...
So we have to try some things... Open your ruby console, copy and paste code below and can you show me the result please ?
Another thing : When does error message appears? While start of SU? After clicking on an icon? Sorry for all these tests, but it's necessary if I want to find the problem! Thank you Edson! Frenglish at its best !
My scripts Re: [Plugin] Toggle Unitsmatt,
do no be sorry. just keep the tests coming. see the results in the attached picture. i do not get any error messages. it just does not change units. cheers.
Re: [Plugin] Toggle Units![]() So I will post an update soon with toolbar code changed! Thank you Edson ! Frenglish at its best !
My scripts Re: [Plugin] Toggle UnitsOk, I've finished this update! Can you try it, Edson, please? Thank you!
good news from the mac side of life. it works. however, in order to see the change in the info panel i must close it and open it again (not a big problem). what could be improved is the fact that the icon bar does not reflect the present units chosen. see the picture: i have decimal and centimeters on it but the icon bar is not reflecting it. sometimes it is all gray, others white. the buttons seem to "stick". but we made some progress.
Re: [Plugin] Toggle UnitsWow... Strange!
Thank you Edson! We will slowly succeed! ![]() Another request, please... A daunting request... Can you open your ruby console and your units window (in model info), please? Copy and paste code below in the ruby console
Change unit format, paste the code in the ruby console and give me the result like that :
Can You do that for all SU unit Format please? ![]() The same thing for units length... With this code :
Here is units options in SU/Windows : Unit Format
Unit Length
My scripts Re: [Plugin] Toggle Unitssorry, max. it may seem clear to you but i am not getting what i am supposed to do. lead me through it, ok?
after i paste Sketchup.active_model.options["UnitsOptions"]["LengthFormat"] what do i do? where do decimal and meters go? with or without quotation marks, etc? and where do i insert the unit options? write down one of the options and i will figure out the others. cheers.
Re: [Plugin] Toggle UnitsSorry
![]() Procedure : For all units format (decimal, architectural, engineering, Fractional) -> N°1 on the picture
For all units length (Inch, feet, millimeters, centimeters, meters) -> N°2 on the picture
If it's too constraining for you, don't hesitate to tell, I understand ![]() Sorry again, Edson! Frenglish at its best !
My scripts Re: [Plugin] Toggle Unitsgotcha! is this it?
Re: [Plugin] Toggle UnitsGreat ! The only problem is that it's the same thing as Window.... I d'ont understand your (Big) Mac Bug....
![]() ![]() ![]() Thank you Edson! Frenglish at its best !
Just one thing... With this update, can you try this :
On windows, dimension changes each time you change units... Frenglish at its best !
yes, the dimensions change. the functionality is now perfect. however, the buttons stay in "pressed" mode even when you change units. check below: after testing the meter button, i clicked on cm and then mm. all of them stayed as if they were active. would there be a way for making only the active unit's button to show as such?
Re: [Plugin] Toggle UnitsOk cool! Thank you!
Do you have any error in the ruby console? Frenglish at its best !
My scripts Re: [Plugin] Toggle Unitsno errors.
Re: [Plugin] Toggle UnitsSir
Matt666 your Plugin Toggle Units is very useful and I use it all the time when I get marine vessels in metric and diving equipment in Imperial. Just one question, would it be possible to add up and down precision buttons, so with a mouse selection, one could change the precision of the display either up or down as required? Thanks in advance and again thanks for the very useful plugin. Ken Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] Toggle UnitsHi Ken.
in the first post, a new tool has been added. The last with 11 icons. Enjoy ! Frenglish at its best !
My scripts Re: [Plugin] Toggle UnitsHi Matt, will do some new icons soon for all eleven (didn't like the other ones)
Thanks. As you can see from my avatar, I design in flat steel plate, and 1/8” is close enough for welders. Your response was faster service than I had at the restaurant I just returned from. Hope others find this helpful. Again much thanks. And on a side note, my youngest daughter is trying to be an exchange student to France this summer. She is taking French in HS this year. I know if she gets to go, she will have a great time. Again thanks Ken Fight like your the third monkey on Noah's Ark gangway.
Sure! ![]() Where will she want to go in France? Frenglish at its best !
My scripts Re: [Plugin] Toggle UnitsMatt
See will find out in the next two weeks if she is accepted and where exactly where she is going. Thanks for asking Ken Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] Toggle UnitsI've updated first post with a new tool and new icons by CadFather! Thank you Max!
Edson or Thomthom, does this version work on Mac? Frenglish at its best !
My scripts Re: [Plugin] Toggle Unitsi am afraid only the three added features work. the rest does not (but was working perfectly before). no error in the ruby console.
Users browsing this forum: aparat1392, orbital and 13 guests
