by sahi » Thu Jul 31, 2008 3:13 pm
Changes in the size of the selection or groups or components Dom_12.jpg mashtab_7.rbz
sahi
- PluginStore Author
- Name: sahi
- Operating system: Windows
- SketchUp version: pre-6
- License type: Free/Make
- SketchUp use: architecture
- Level of SketchUp: Beginner
by pav_3j » Thu Jul 31, 2008 3:30 pm
sorry i'm confused, is this a scaling ruby?
pav
Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
pav_3j
- Name: Luciano
by sahi » Thu Jul 31, 2008 3:38 pm
changes a model size.
sahi
- Name: sahi
by pav_3j » Thu Jul 31, 2008 3:41 pm
ah i see! i shall have a tinkle and see how i get on.
pav
pav_3j
- Name: Luciano
by urgen » Thu Jul 31, 2008 3:53 pm
...it is "resize tool" more.. by axis... Useful idea,SAHI!
--pupil forever...------
urgen
by stanmarsh » Thu Jul 31, 2008 4:34 pm
hi sahi thanks for this ruby! is there anyway to change it to meters?
stanmarsh
by sahi » Thu Jul 31, 2008 6:28 pm
stanmarsh wrote:is there anyway to change it to meters?
meters mashtab.zip
sahi
- Name: sahi
by Didier Bur » Thu Jul 31, 2008 10:15 pm
Hi, This doesn't work here: it gives weird results, out of range, entities are moved elsewhere. If entities are not grouped at start, there are grouped at the end. Am I missing something ??? Before/After a scale of 2: scale.jpg
Didier Bur Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
- Name: Didier Bur
- SketchUp version: 2020
- License type: Pro
- Level of SketchUp: Advanced
by sahi » Fri Aug 01, 2008 7:50 am
sahi
- Name: sahi
by N Lindenthal » Fri Aug 01, 2008 12:08 pm
On Mac I did not see the scaling tool palette. Is it Menu > Plugins > Scale?
N Lindenthal
by Didier Bur » Fri Aug 01, 2008 12:35 pm
Hi, Dialog is ambiguous: "on all of axes" is not a target size but adds entered size to actual size. The final size would be better IMHO ? Why choosing the bounds center as the center of transformation ? I suggest not to use "to_cm" or "to_m" in the code, but to use only Length type variables. Thus you will suit everyone's unit, no matter what it is. Useful script, though.
Didier Bur
- Name: Didier Bur
- License type: Pro
by sahi » Fri Aug 01, 2008 1:27 pm
Didier Bur wrote:Hi, Dialog is ambiguous: "on all of axes" is not a target size but adds entered size to actual size. The final size would be better IMHO ? Why choosing the bounds center as the center of transformation ? I suggest not to use "to_cm" or "to_m" in the code, but to use only Length type variables. Thus you will suit everyone's unit, no matter what it is.
"on all of axes" ---How to name??? corrected all of other as you specified
sahi
- Name: sahi
by Didier Bur » Fri Aug 01, 2008 3:37 pm
Correct me if I'm wrong, but the resize operation works only for faces in XY,XZ and YZ planes (red,green,blue) ? "On all of axes" -> "In every direction" ? English speaking people please help ! Another enhancement is to encapsulate in an operation for one step undo: - Code: Select all
def mashtabirovanie_create Sketchup.active_model.start_operation "Resize" ss=Sketchup.active_model.selection ... ... Sketchup.active_model.select_tool(nil) Sketchup.active_model.commit_operation end
Didier Bur
- Name: Didier Bur
- License type: Pro
by sahi » Fri Aug 01, 2008 3:52 pm
Didier Bur wrote:- Code: Select all
Thank you! Corrected a code. Added an icon. mashtab_3.zip
sahi
- Name: sahi
by CadFather » Fri Aug 01, 2008 5:24 pm
..growing into a nice little ruby.
CadFather
- Name: CadFather
- SketchUp version: 2014
- License type: Pro
- SketchUp use: landscape architecture
by ilay7k » Fri Aug 01, 2008 7:11 pm
Equal "In every direction" is global settings for object of selection(world scaling system in most graphic packages...in attached pic, like cinema4d) or about directions of red,green,blue, Didier, you are right/something like object system/
ilay7k
- Name: Ilya Shpilkin
- SketchUp version: 8
by marcosrodrigues » Fri Aug 01, 2008 7:14 pm
Simple and very useful. Thank you!
| menos é mais
marcosrodrigues
- Name: marcosrodrigues
by Fletch » Sat Aug 02, 2008 6:49 am
I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
Fletch
- Twilight Render
- Name: Fletch
- SketchUp version: 2017
- License type: Pro
by sahi » Wed Aug 06, 2008 6:36 pm
Fletch wrote:I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
dom_3.jpg mashtab_4.zip
sahi
- Name: sahi
by unclebim » Thu Jun 07, 2012 9:17 pm
I don't get what should I input in the Lock aspect ratio box in order to get the selection scaled proportionally to exact dimension input in one axis?
unclebim
- License type: Pro
- SketchUp use: interior design
- Level of SketchUp: Intermediate
by Zacchia » Tue Jun 11, 2013 7:38 pm
I like it. Thanks!
Zacchia
- Name: Zacchia
- SketchUp version: 7
- License type: Pro
by chialiang168 » Tue May 19, 2015 5:51 pm
尺寸不正確 Size is not correct
chialiang168
- Name: AN_Hoshino
- License type: Pro
- SketchUp use: engineering and mechanical design
by cotty » Tue May 19, 2015 5:56 pm
Perhaps your bounding box has a different orientation than the box itself?
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
- SketchUp use: hobby
by juju » Wed May 20, 2015 12:31 pm
cotty wrote:Perhaps your bounding box has a different orientation than the box itself?
that would no sense if the plugin measures the bounding box instead of the geometry
juju
- Premium Member
- Name: Juju
- SketchUp version: 2021
- License type: Pro
by sahi » Mon Feb 15, 2016 11:04 am
Updated the plug-in in the first message
sahi
- Name: sahi
by designerbursa » Tue May 21, 2019 10:54 am
alternative svg icon
designerbursa
- Name: sami bayram
- License type: Pro
by TeamCVZ » Wed Sep 11, 2019 3:27 pm
Should it work with SU19 ?
TeamCVZ
- Name: MACARY
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
