SketchUcation Plugin Store
[Plugin] Terrain Reshaper
Re: [Plugin] Terrain Reshaper
Postby chango70 » Thu Jul 17, 2008 12:48 pm
Man u are the reason Sketchup is half as cool as it is for me! Keep it up!
chango70
Postby boerenkool » Thu Jul 17, 2008 1:05 pm
Mille grazie !
boerenkool
Postby redot » Thu Jul 17, 2008 3:54 pm
Thanks Didier. Great plugin
:thumb:
redot
Operating system: Windows
SketchUp version: 8
License type: Free/Make
SketchUp use: architecture
Level of SketchUp: Advanced
Postby plot-paris » Thu Jul 17, 2008 5:18 pm
hi Didier,
I just wanted to clean up a terrain. I used the options
-create group: yes
-delete original: yes
-merge faces: no
-size 600mm
when it was finished it looked like this
the original terrain had not been deleted. but the new terrain was incomplete where the old mesh was visible (see image above). no idea, why it didnt work. just thought I would tell, in case you have a clue. ;)
plot-paris
SketchUp version: 8
License type: Pro
Postby Didier Bur » Thu Jul 17, 2008 5:50 pm
The smoothing can be done with Matt666's smoothing plugin
Fredo6,Matt666 and me, the french connection :roflmao:
@Plot-paris:
Could you PM me the SKP file ? I'm curious to know what bug's still there :bounce:
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Jul 17, 2008 6:04 pm
And if Ruby was my cup of tea, that will the The Four Musketeers! :roflmao:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby REGIS » Thu Jul 17, 2008 9:56 pm
And if Ruby was my cup of tea, that will the "club des cinq" :roflmao:
@Plot-paris:
Can you show us or share the starting idea, I would like to see before you apply model with contours.(perhaps I've got an idea using your technic to model terrain).
After a few tests using different methods, I let you guess
who's who.
regards
REGIS
Postby plot-paris » Fri Jul 18, 2008 8:46 am
good morning REGIS,
the initial idea was discussed in this thread.
for the who is who test - could you give us some multiple choice answers? ;)
plot-paris
SketchUp version: 8
License type: Pro
Postby putnik » Thu Aug 14, 2008 4:40 am
Didier, amazingly useful tool! Thanks so much! :berserk: Thank you plot-paris and everyone else from this topic for this most excellent idea
putnik
Name: Kesha Chakhvorostov
Postby putnik » Thu Aug 14, 2008 4:48 am
Didier, don't know if it's possible to do, but it would be helpful (me thinks) if the the script somehow retained the information collected at the "Parsing terrain.." stage, in case one wants to reshape the terrain again with, say, differently sized triangles.
putnik
Postby johnnybfunk » Wed Apr 01, 2009 4:19 pm
Hey,
I've imported 6-7 GE terrain meshes, exploded them, put them all in a group, and then tried to run didier's plugin. :| It didn't come out as expected.
The problem is, i think, that i didn't really merge the different meshes before runnig the script, and that all 6 or 7 of them reacted as independent meshes.
Does anybody have a quick and easy solution for stitching together different meshes imported from GE?
Thank you,
Félix
johnnybfunk
Postby Chris Fullmer » Wed Apr 01, 2009 5:14 pm
Hi Felix, I think that the problem is just that you need to select all the terrains you want to reshape and turn them into a single group. Then just select the 1 group and run the plugin. It will not accept a selection of loose geometry. Only a single group.
Hope that helps,
Chris
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Re: [Plugin] Terrain Reshaper [Suggestion/Request]
Postby JClements » Wed Aug 12, 2009 3:24 am
Didier:
Suggestion/Request
When dealing with a large terrain surface, the Parsing, Triangulation, and Merging functions of the script can take quite a while.
I was wondering if at the end of each function (before the user goes to the next) if an elapsed time could be shown. At the completion of the script, then a final dialog would be displayed showing the elapsed time of each function.
This way, if you had to convert a series of similar terrains, you wouldn't have to wait around at your computer ... just go do something else and come back according the to elapsed times of the first reshaping session. :)
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby olishea » Fri Aug 14, 2009 12:15 pm
effing fantastic plugin. i could have done with this a few weeks back, works great
oli
olishea
Premium Member
Premium Member
Postby plot-paris » Mon Aug 17, 2009 7:09 am
sometimes, when you have got a terrain with a lot of detail in places and very little information in others, the terrain reshaper has to be set according to the highest level of detail. that results in models with unnecessarily large numbers of vertexes.
therefore the idea for an improved plugin - the Dynamic Terrain Reshaper! you define a maximum vertex size and a minimum vertex size. then the plugin calculates the whole terrain with the large vertices and subdivides, where neccessary, until it reaches the minimum vertex size limit.
was that comprehensible?
plot-paris
SketchUp version: 8
License type: Pro
Postby Aerilius » Mon Aug 17, 2009 8:27 am
I just used it for a terrain with steep slopes (a vertical rock face). The plugin has much better results than the polygon reducer (which produces many long stretched vertices).
I like your idea much! :berserk: Maybe the vertex size should also consider the slope.
Aerilius
Top SketchUcator
Postby mitcorb » Mon Aug 17, 2009 12:56 pm
Didier:
I am inferring that this tool is like a re-topology process. Is that correct?
mitcorb
Top SketchUcator
SketchUp version: 8
Postby plot-paris » Tue Aug 18, 2009 9:20 am
Aerilius wrote:Maybe the vertex size should also consider the slope.
good thinking! could be quite difficult though, because as I understand it, it would differ completely from todays procedure of the plugin (which casts rays vertically onto the terrain). any ideas how it could be done (that the vertex distribution is relative to the terrain normals and not to the top view)?
plot-paris
SketchUp version: 8
License type: Pro
Postby mitcorb » Tue Aug 18, 2009 12:41 pm
I don't understand "vertex size"? Do you mean the interior angle subtended by its edges? Otherwise, a vertex is a dimensionless point.
mitcorb
Top SketchUcator
SketchUp version: 8
Postby plot-paris » Wed Aug 19, 2009 7:43 am
sorry. I meant polygons.
plot-paris
SketchUp version: 8
License type: Pro
Postby theark » Tue Mar 23, 2010 10:18 am
Thank you so much.You make a good change.
theark
Postby TeKnoel » Tue Mar 23, 2010 4:05 pm
I've used the original a few times and it's great for simplifying nasty terrain. Thanks for the update on it!
TeKnoel
Postby SUCCESS01 » Wed May 19, 2010 12:47 am
how to get it
SUCCESS01
Postby Gaieus » Wed May 19, 2010 5:49 am
Hi SUCCESS01,
Download it from the very first post of the topic.
Administrator
SketchUp version: 2013
License type: Pro
SketchUp use: historical reconstruction
Postby SUCCESS01 » Wed May 19, 2010 6:43 am
SUCCESS01
Postby lubitel » Sat Nov 06, 2010 9:38 am
I need to eliminate the faces on overlapping terrain patches to be able to make one large clean mesh.
But when I run TR from the menu (after having made the two to a group and the group selected) its not happening....
It does show the "Computing faces area..." in the feedback part of the SU interface....but the pop up window doesn't show up...
What am I doing wrong?
thanx in advance
l
lubitel
Postby rachmatrf » Tue Feb 21, 2012 9:52 am
Thank you very much Didier..... :berserk: :berserk: :berserk: Great Work!!!
rachmatrf
Name: Rachmat Rhamdhani Fauzi
Postby brookefox » Mon Mar 19, 2012 1:16 am
please note: I'm going to leave this post as the issues are there but not at all urgent. I'm not pursuing reshaping my terrain because I think it is simple enough and nothing really is going to help it be any other than flat and boring.
I'm getting hangs at 8-9%. Will try with a smaller selection.
With a smaller selection, hang occurs at 85%.
Smaller still, it finishes. I thought I had given it sufficient time but perhaps not. I'll let it run while overnight.
~ Brooke
brookefox
SketchUp version: 8
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Next
Return to Plugins
Users browsing this forum: khtan, mgie, sasanbell, tomasz and 15 guests
