by Fletch » Mon Jul 14, 2008 5:01 am
Fredo, I'm with Coen, I got this so I can offset the edges of a curved surface onto the surface... but the LINE TOOL ON CURVED SURFACE?! well... that just made my day This is obviously a labor of love you have created. Thanks to you, the Joint Push Pull, the Soap Skin Bubble, Free Form Deformation, and the Subdivide and Smooth tools I am officially at a creative loss... I mean... I'm sitting here saying "now I can draw ANYTHING I WANT!" and just like when I got Z-brush's demo... had no idea WHAT I WANT to create. Thanks so much for your work, and generosity!
Fletch
- Twilight Render
by watkins » Mon Jul 14, 2008 7:11 am
Dear Fredo,
Thank you for the explanation. I use Sketchup for mechanical design and so I almost always draw on flat surfaces, hence my interest in using your tools for both plain and construction lines.
Kind regards, Bob
watkins
by Fredo6 » Mon Jul 14, 2008 7:59 am
watkins wrote:Dear Fredo,
Kind regards, Bob
Bob (and Daniel) That's simply a bug, thanks for signaling (actually the script was generating a face for the shape, even in construction line). This is fixed and I updated the Zip file in the main message of this thread. Fredo
Fredo6
- Top SketchUcator
by Fredo6 » Mon Jul 14, 2008 8:09 am
Coen Naninck wrote:It has already been said by Gaieus, the Freehand On Surface tool does not close the path. You think you can fix this? Or am I missing an option?
Freehand does not close automatically and does not have inference on by default, but if you keep Shift depressed when approaching a remarkable point, the inference is activated (on existing point, and on points of the curve drawn). Also CTRL depressed allow you to pause the input of points when you move the cursor.
Fredo6
- Top SketchUcator
by Fredo6 » Mon Jul 14, 2008 9:16 am
CadFather wrote:goooodness me Fredo.. how many cursors in this plugin!  (could they impact on loading speed?) anyway, at 1am - with divorce proceedings well under way - i have finished icons and cursor - both for small and large toolbar (16, 24) [plus an extra set] - again just place them in your "...\Plugins\TOS_Dir_13" folder, overwriting all files". @Plot-Paris, thanks, glad they can be of use
CadFather, The cursors are very good and well designed. Nice work For the icons, could you make them a little 'bigger', meaning using more of the surface of the toolbar button. On my small-screen computer (15'), it is hard to distinguish the shapes and visually see the differences between buttons. Thanks a lot. I promise not to touch the naming convention for these icons and cursors in future versions (but I may have to add new ones !). Fredo
Fredo6
- Top SketchUcator
by plot-paris » Mon Jul 14, 2008 10:53 am
Fredo6 wrote:I promise not to touch the naming convention for these icons and cursors in future versions (but I may have to add new ones !)  something like a "Scale on surface"?
plot-paris
- Name: plot-paris
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by CadFather » Mon Jul 14, 2008 11:35 am
Fredo6 wrote:For the icons, could you make them a little 'bigger', meaning using more of the surface of the toolbar button. On my small-screen computer (15'), it is hard to distinguish the shapes and visually see the differences between buttons.
Fredo
Fredo, i made these yesterday too but didn't post them as they need more work to get the lines bolder. 24 pixels only - i'm planing, more work on them. also i personally wouldn't mind having an .exe installer (it would take care of previous installs and minimize probs (just an idea)
Please, register (free) to access all the attachments on the forums. Quarr-IT - SketchUp Training from the Master .. . .
CadFather
- Name: Max Coppoletta
by erikB » Mon Jul 14, 2008 12:31 pm
Fredo, many thanks again fot this update. erikB
erikB
- Name: Erik Bosquet
by Juju » Mon Jul 14, 2008 1:15 pm
Fredo, thanks for the update and improvements.
CadFather, thanks for the red flat 24 icons, I prefer them.
Save the Earth, it's the only planet with chocolate. Keeping things organised is not a sin.
Juju
- Name: Julian Smith
by wq418 » Tue Jul 15, 2008 2:00 am
i like it! thank you
wq418
by dolphus » Wed Jul 16, 2008 5:55 am
Thank you very much for the latest update, I am just missing the original buttone the only buttons i have are for the circle, circle 3 points and arc what am i doing wrong?
dolphus
- Name: Dolf Cochrane
by JGA » Wed Jul 16, 2008 10:03 pm
Fredo, Thanks for the tools, they are great, & to CadFather for the icons to match!
Regards, JGA
JGA
- Name: JGA
by tald311 » Thu Jul 17, 2008 10:00 pm
This script is AMAZING. Coen showed it to me at 3D base camp and he has made fun of my reaction since. This latest update has pushed the ability to use SketchUp into a new direction. I have one request, unless it can already be done, sommeone please let me know - the ability to offset lines once they are drawn. Ther reason: I want to lay out a trail or walk on a surface. I can use the line on surface and the arc on surface - once I draw the first one, I want to create an offset to make them parallel. THANK YOU AGAIN Simply amazing Daniel Tal
tald311
- Premium Member
- Name: tald311
- License type: Pro
- SketchUp use: landscape architecture
by Pilou » Thu Jul 17, 2008 10:13 pm
the ability to offset lines once they are drawn This tool can't make the trick? Just close your lines, make the offset, erase lines that you don't want
Pilou
- Top SketchUcator
- SketchUp version: 6
- License type: Free
- SketchUp use: hobby
by tald311 » Thu Jul 17, 2008 10:20 pm
Pilou wrote:the ability to offset lines once they are drawn This tool can't make the trick? Just close your lines, make the offset, erase lines that you don't want
Unfortunlaty it does not. That will offset the surfaces and not the line. Keep in mind, I am not complaining about the ruby at all either.
tald311
- Premium Member
- Name: tald311
- License type: Pro
by Pilou » Fri Jul 18, 2008 1:01 am
Yes it's not automatic, but it's not a big deal after the Offset of contour! Explode curve and you have all offset you want  And after free to you to weld any part of curves you want
Pilou
- Top SketchUcator
by remus » Fri Jul 18, 2008 7:07 am
Not really sure what your getting at daniel, as a surface is always defined by its edges so to offset the surface you need to offset the bounding edge.
remus
- Name: remus
by boofredlay » Fri Jul 18, 2008 4:50 pm
Thanks again for the updated script! I just now got around to installing it.
boofredlay
- Global Moderator
- Name: Eric Lay
- License type: Pro
by CadFather » Sat Jul 19, 2008 11:42 am
Hi, i think this is going to be the final release (for now) TOS Cursors updated (smaller pencil). TOS Icons updated: - large i.png small i.png .
CadFather
by stanmarsh » Sat Jul 19, 2008 2:15 pm
@CadFather thanks for the icons, i really like it, its very refined! btw, the offset cursor icons are missing.
stanmarsh
by CadFather » Sat Jul 19, 2008 2:32 pm
thanks Stanmarsh, files updated.
@ Fredo.. to make the toolbars easier to manage.. (you may already know)
i know Didier has a way of changing the icons from small to large (projections/layer manager) according to the toolbars setting in SU. unfortunately the script is scrambled so i can't see the relevant code. would be good to have all big and small icons in the TOS folder (and not worry about it anymore).
CadFather
by stanmarsh » Sat Jul 19, 2008 2:46 pm
icons are pretty!
stanmarsh
by CadFather » Sat Jul 19, 2008 3:01 pm
thanks Stan, your comment makes glad two weeks of work to achieve it!
CadFather
by watkins » Sat Jul 19, 2008 4:58 pm
Dear CadFather,
Your icons are clear and crisp, and a pleasure to use. Thank you for all your efforts.
Kind regards, Bob
watkins
by CadFather » Sat Jul 19, 2008 9:35 pm
CadFather
by Frederik » Sat Jul 19, 2008 9:50 pm
Thank you so much for the icons and cursors, Max..!!  They sure look GREAT..!!
Frederik
- Top SketchUcator
- Name: Kim Frederik
- License type: Pro
- SketchUp use: engineering and mechanical design
by kwistenbiebel » Sun Jul 20, 2008 12:00 am
Hi Fredo, Maybe an idea for a next on-surface-tool: ' paint-on-surface' Just like the new Cinema4D plugin: see movie: http://www.dns-plugins.de/video/pos_1_overview.movAlthough, when I think about it...maybe this would be a feature to add to the existing 'component spray' ruby...
kwistenbiebel
by Pilou » Sun Jul 20, 2008 9:42 am
Very design icons! it's like a dream  Seems there is something with large buttons on the toolbars Seems jpg compress ??? Maybe I miss something they are fine on the screen work Little buttons icones works fine  [Edit]it was me ! I had not install Large cone file
Pilou
- Top SketchUcator
by CadFather » Sun Jul 20, 2008 10:34 am
are you sure you installed the 24 pixels ones? (TOS_IconsCursors_24)
CadFather
by Pilou » Sun Jul 20, 2008 10:44 am
Yes I have missed that see my previous edited post  But i have always a problem what must be the organisation of folders TOS_IconsCursors_24 and TOS_IconsCursors_16 inside the Plugins folder? because I have the same problem now for the little button I must miss again something
Pilou
- Top SketchUcator
Return to Plugins
