[Plugin] Tools On Surface - v2.4a - 01 Nov 18
Re: [Plugin] Tools On Surface - v1.8a - 12 Jan 11
Postby galinette » Wed Nov 21, 2012 12:00 pm
Well, I deleted all plugins, re-downloaded all, everything works...
Sorry for the mess
Etienne
galinette
Postby TIG » Wed Nov 21, 2012 12:04 pm
Weird! :shock:
But at least it's fixed.
Although we don't know how exactly... :?
Global Moderator
Postby Dave R » Wed Nov 21, 2012 1:05 pm
Perhaps the problem has to do with the order of events? I've assisted several users who have Win7 and had problems getting plugins to work. They tried installing the plugin prior to setting the admin privileges for the Plugins folder correctly. Removing the .rb file from the folder and installing it anew allowed it to work.
Global Moderator
Postby sicksickisck » Mon Jan 14, 2013 3:44 pm
great plugin :ecstatic: but I need more shapes maybe shape editor [in commercial version :sketchstatic: ]
sicksickisck
Postby thomthom » Mon Jan 14, 2013 3:53 pm
sicksickisck wrote:great plugin :ecstatic: but I need more shapes maybe shape editor [in commercial version :sketchstatic: ]
Drape or intersect?
PluginStore Author
PluginStore Author
Postby sicksickisck » Mon Jan 14, 2013 7:43 pm
Intersect 8-) [difficult ?].
edit : ...or both... I like how "tools on surface" works ;)
sicksickisck
Postby Dave R » Mon Jan 14, 2013 7:47 pm
No. Intersect isn't difficult and it is a fundamental thing to know how to use in SketchUp.
Global Moderator
Postby metagamer » Sun Mar 10, 2013 3:42 am
I've been playing around with this tool for a day, and I really like its potential. But I'm having a really hard time getting the shapes I draw to turn into surfaces to use with the Joint Push Pull tool. For example, I extrude a simple cylinder (using built-in tools), and then draw a rect, a circle and a hexagon on the side using ToS. Sometimes it creates a face that I can use with JPP, sometimes it doesn't, and I can't figure out why. Any clues?
metagamer
Postby Dave R » Sun Mar 10, 2013 7:46 am
It works for me. How large is the cylinder?
Or are you getting a result something like this?
In this case the left edge of the rectangle falls on one of the natural softened edges of the cylinder. You can see that edge if you turn on Hidden Geometry under the View menu. You'll have to unsoften that edge to separate the rectangle from the rest of the surface. You can do that with the native Line tool or the Line tool in ToS and just connect the ends of the adjacent edges of the rectangle. Or you can display Hidden Geometry, select that edge and unsoften it.
Global Moderator
Postby jgb » Sun Mar 10, 2013 5:47 pm
Faster; easier ..... Shift+Ctrl Erase (tool) Just click on the soft "missing" line segment.
__________________
jgb
jgb
Postby dakenyon27 » Sat May 25, 2013 6:50 pm
I can't seem to get this fantastic plugin working on sketchup 2013. Can anyone help?
David.
dakenyon27
Premium Member
Premium Member
Postby Dave R » Sat May 25, 2013 7:08 pm
Sure. But we need some useful information. What do you mean you can't get it working? What happens when you start SketchUp? Do you get an error message related to the plugin?
Did you install the required LibFredo6 files as spelled out in the first post in the thread? How did you install the files? Do you have Administrative privileges for the Plugins folder?
Global Moderator
Postby thomthom » Sat May 25, 2013 7:10 pm
dakenyon27 wrote:I can't seem to get this fantastic plugin working on sketchup 2013. Can anyone help?
Can you please describe the problem?
Installation problems? Operation problems? Errors?
PluginStore Author
PluginStore Author
Postby martosurf » Wed Jun 12, 2013 11:51 pm
FRedo thanks a lot for all good plugins
You a great thanks a lot
martosurf
Postby alek_mc » Mon Jun 24, 2013 3:43 am
hi... I have a problem with this plugin... I installed the sketchup pro 2013 and when I started the program, one message said that the plugin can't been uploaded... what can I do?
alek_mc
Postby TIG » Mon Jun 24, 2013 9:57 am
Reread this plugin's main-page instructions.
Is it installed exactly like that page says ?
Have you also installed the very latest version of 'LibFredo...' from the link that is given [or the SCF PluginStore listing] ?
Global Moderator
Postby ibrahim zambak » Sat Jul 06, 2013 10:02 am
tools on surface v1.8a plugin, sketchup 8 does not work. windows 8 operating system
ibrahim zambak
Postby Gaieus » Sat Jul 06, 2013 10:18 am
Ibrahim,
More info is needed here. I have SU 8 on Windows 8 and the tool works fine on my computer so a "general doesn't work" is not enough.
Postby sasrabirawa » Sat Jul 27, 2013 5:42 am
works fine on SKP 8 but doesn't work on SKP 2013. The libfred doesn't compatible w/ SKP 2013. even if I use the latest one... can anybody tell me how to fix ??
Just an ordinary Sketchup user
sasrabirawa
Postby TIG » Sat Jul 27, 2013 11:28 am
The latest LibFredo... and several related tools were remade to be compatible with all previous versions and v2013.
We must assume you are using the latest versions available from the SCF PluginStore...
So you must be doing something wrong ?
Are you properly installing things ?
Since you haven't told us your OS I must guess at PC.
If it's a new v2013 installation into the usual 'Program Files' folder, then Windows will have given the new SketchUp folder [and all of its subfolders] Read-only permissions. Then you can't Write new files into the Plugins folder; but to confuse you Windows might make it look like you have, but it has a actually put the files into a VirtualStore to protect you from yourself, so they don't auto-load as SketchUp starts! A link/button in the top-bars of the Plugins folder's Windows Explorer window is an indication of such limitations...
If you use an RBZ archive and then 'install' button under Preferences > Extensions, or use the SCF Plugin Store dialog's AutoInstall feature from within SketchUp then it might still install properly, despite your own limited permissions; but that depends on several other things though...
It is always best to have your Plugins folder set to have FULL read/write permissions for every entry in the 'users' uder the Security list: to do this...
right-click > context-menu > Properties > Security > Edit ... tick FULL for each and Apply & OK...
[you will need admin rights to do this].
Note that even if you are setup in the Users Control Panel to have full 'admin' rights, that will not change the initial permissions the OS sets to the SketchUp folder and its contents, even admins are limited.
Note that it is also advisable to always install apps as as admin... AND for SketchUp.exe I'd also set its Properties > Compatibility, with the 'Run this program as an administrator' box ticked...
Global Moderator
Tools on Surface showing up in extensions but no tool there!
Postby elisaha » Fri Aug 02, 2013 12:12 pm
Hi everyone,
I'm a SU-newbie with SU 8 on a Mac with OS X 10.7.5, however I have troubles installing ToolsOnSurface 1.8a. I do have the ZLoarder, LibFredo and the Tutorial Offset on Surface in the correct plugin folder. It even shows up in my extensions, but there is no line-up. What can I do?
I do have a general problem with installing plug-ins.. I don't know what I would be doing wrong, please help!
Thanks alot,
Elisa
elisaha
Postby mitcorb » Fri Aug 02, 2013 12:40 pm
Hi:
On the very first page of this thread under Installation, for Mac is this:
[On Mac the SU plugin directory should be:
Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins]
In your case, it will be Sketchup 8 but the rest of the path should be correct.
Alternatively, go to the top of this page, mouse over Resources, and select Plugin Store Download. This automates the process. Watch the video, read the information.
mitcorb
Top SketchUcator
Postby giltora » Sun Aug 04, 2013 1:23 am
tools on surface not responding.. help please!!!!
giltora
Postby TIG » Sun Aug 04, 2013 11:31 am
giltora wrote:tools on surface not responding.. help please!!!!
More info is needed.
HOW isn't it 'responding' ?
Do you get the extension/toolbar ?
Are there error messages?
[Try it with the Ruby Console window open...]
Did you get the latest versions of this tool AND the required LibFredo...
Both are available in the SCF PluginStore...
Global Moderator
Postby popfunky » Sat Sep 21, 2013 5:55 am
Thank but i can't install :cry:
popfunky
Postby TIG » Sat Sep 21, 2013 11:30 am
popfunky wrote:Thank but i can't install :cry:
Please explain your problem better, so we can help you properly.
How are you trying to install this ?
Do you have the required support 'Lib' installed as explained in the download details ?
Global Moderator
Postby archdeacon » Sat Sep 21, 2013 3:04 pm
Fredo thank you for these great tools. i am having a hard time installing this one though. I am on sketchup 8 pro - Windows 7. any ideas...? i have observed the footprint and everything. I do not appear to have the LibFredo6.rb that you are mentioning (i have the newer library). Is this because you have updated the lbrary to the new version? can you instruct me on how to cure this problem.
thanks for your help.
archdeacon
Postby fredo6 » Sat Sep 21, 2013 5:33 pm
archdeacon wrote:Fredo thank you for these great tools. i am having a hard time installing this one though. I am on sketchup 8 pro - Windows 7. any ideas...? i have observed the footprint and everything. I do not appear to have the LibFredo6.rb that you are mentioning (i have the newer library). Is this because you have updated the lbrary to the new version? can you instruct me on how to cure this problem.
Since you have Sketchup 8, you should
- first, install the Sketchucation Plugin Store tool
- Then Auto-install my scripts with this tool. You'll have zero problem and it's much easier and faster than with the ZIP file. You will also get the latest versions available
You may need to do a clean up of your SU Plugins directory before if you had a wrong installation
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby archdeacon » Sat Sep 21, 2013 7:51 pm
oops...
i just restarted sketchup (i had done it before as well and it did not work)
BUT IT WORKS FINE NOW!
thank you very much! :ecstatic:
archdeacon
Postby kdrr1607 » Tue Oct 08, 2013 7:05 pm
Hi! I have a question. The construction lines are not showing every time I click on the surface after picking the initial point, so I cant pick an end point. Uhm, how can I solve this? Thanks.
kdrr1607
PreviousNext
Return to Plugins
Users browsing this forum: datto93, ECOUS, Grauer, junebug, monkey63, rosekearsley, spencemik00, surendra12 and 19 guests
