[Plugin][$] Tools On Surface - v2.5a - 22 Apr 21
Re: [Plugin] Tools On Surface - v1.6c - 15 May 10
Postby fredo6 » Sat May 15, 2010 8:48 am
[Important Upgrade version 1.6c, 15 May 10]
I just realized that in v1.6b, I have introduced a ennoying bug in the inferencing of the tool LineOnSurface.
This is fixed in this new release 1.6c.
See main post for download: viewtopic.php?p=76625#p76625
Fredo
fredo6
Premium Member
Premium Member
Postby chouaibcl65 » Sun May 16, 2010 12:18 am
thank youuuuuu
chouaibcl65
Postby keea1111 » Tue May 18, 2010 8:18 pm
HI,
I am trying to get this to install on my new computer and it isn't coming up for me. I have dropped both rb file as well as the tools file into the plugins folder, open sketchup and am not finding it. Is there a companion plug in needed for this, or am I missing something else. thanks so much for the help..Keea
KEEA
keea1111
Postby massimo » Tue May 18, 2010 8:50 pm
Hi Keea, have you installed LibFredo as well? Btw have you read the PDF quickcard (2. installation and configuration)?
massimo
Postby mavie » Tue May 25, 2010 1:06 am
After reading his installation notes and carefully loading all the components for Fredo's great Tools on Surface plugin (about 4 times), I got my error messages down to just this one upon opening SketchUp after install:
Error Loading File Zloader_OnSurface.rb unititialized constant Traductor:Plugin
I reinstalled Zloader (the freshest version, I believe) and have the latest version of his plugin, but I would love to find out what I'm doing wrong. MacBookPro, Snow Leopard, and I cleaned out all the bits of Fredo's older versions, etc.
Thanks in advance for any advice,
Mave
mavie
Premium Member
Premium Member
Postby mavie » Tue May 25, 2010 8:41 pm
Okay, yes. Woke up fresh, tried another 2 installs and I'm good to go! Such a cool plugin. Merci bien Fredo!
mavie
Premium Member
Premium Member
Please Help to install Tools On Surface - v1.6c - 15 May 10
Postby hgdn » Wed May 26, 2010 3:53 pm
Is anyone please pointing it out for me of what is not right as I have tried a lot of times to install but still not get it? I got files LIBFREDO6_Dir_34, FREDOSCALE_Dir_20, TOS_Dir_16 and 3 rb(s) LibFredo6.rb, ZLoader__FredoScale.rb, ZLoader__OnSurface.rb located in Program Files\Google\Google SketchUp 7-pro\Plugins.. . The Fredoscale is fine and working icons shown but Tools on Surface icon(s) is not and in Preferences I saw it there and I checked that box and restart computer but still not shown. Oh one more thing that I never had installed any of those files before (3 files) so is there any relation of old and new files installed that makes it does not work or any missing things I don't know??? please tell me as I am tired of trying so many times...Thanks! :fecstatic:
hgdn
Re: Please Help to install Tools On Surface - v1.6c - 15 May
Postby fredo6 » Wed May 26, 2010 9:20 pm
hgdn wrote:Is anyone please pointing it out for me of what is not right as I have tried a lot of times to install but still not get it? I got files LIBFREDO6_Dir_34, FREDOSCALE_Dir_20, TOS_Dir_16 and 3 rb(s) LibFredo6.rb, ZLoader__FredoScale.rb, ZLoader__OnSurface.rb located in Program Files\Google\Google SketchUp 7-pro\Plugins.. . The Fredoscale is fine and working icons shown but Tools on Surface icon(s) is not and in Preferences I saw it there and I checked that box and restart computer but still not shown. Oh one more thing that I never had installed any of those files before (3 files) so is there any relation of old and new files installed that makes it does not work or any missing things I don't know??? please tell me as I am tired of trying so many times...Thanks! :fecstatic:
Your set up seems OK. You only need these 3 folders and 3 files at the level of the Skethcup Plugin directory.
However, I can't judge if you have other files that would conflict and if the contnet of these folder are right. Please check the documentation, as it gives the footprint.
Also, you do not need to "restart the computer" to enable the plugins. Just restart Sketchup.
Finally, can you check the menu Tools > Fredo6 Collection and see if you have Tools on Surface submenus.
Fredo
fredo6
Premium Member
Premium Member
Re: Finally, I got that Tools On Surface - v1.6c - 15 May
Postby hgdn » Thu May 27, 2010 5:43 am
Hello Fredo,
I am glad it okay now as I deleted/installed it again and it works fine now and I have no idea why! Your design plugin stuffs are truly amazing and provide more choices in different languages around the world...very eager to try it soon!
Thanks for spending time of looking over the problem! :lol:
hgdn
Postby tmanoso » Sun May 30, 2010 12:12 am
Hey Fredo6,
i recently downloaded this and i cannot get it to work attached is the image of message box. :oops:
tmanoso
Postby utiler » Tue Jun 01, 2010 3:02 am
Hi Fredo, Just having a bit of a problem with TOS. I'm trying to draw an arc on a curved vertical surface but it seems to be playing up a bit.... see attached short screen movie.
Any ideas?
Thanks in advance.
Andrew
utiler
Top SketchUcator
Postby zilvinasz » Mon Jun 21, 2010 11:49 am
:ecstatic: DUDEEE!!!! your just bringin Sketchup alive!!!
Thanks!!!
zilvinasz
Postby rachmatrf » Tue Jun 22, 2010 8:32 am
YOU'RE THE MAN FREDO!! :berserk: :sketchstatic:
rachmatrf
Postby Daniel S » Sat Jul 10, 2010 10:41 pm
There is a small problem with the polygon of 3 segments on the red axis working on 2D.
It creates the triangle but in the other direction. On a surface works right.
Daniel S
Daniel S
Postby derweissi » Thu Jul 15, 2010 8:50 am
After installing this great Plugin - I unzipped it in the plugin folder - I only get following message when starting sketchup and can't use it now. Whats wrong ? Did i make a mistake?
Fehler beim Laden der Datei __loader.rb
uninitialized constant TraductorFehler beim Laden der Datei EraserOnSurface.rb
uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei FreehandOnSurface.rb
uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei FreeScale_Common.rb
uninitialized constant FreeScale::T6Fehler beim Laden der Datei FreeScale_Tool.rb
uninitialized constant FreeScale::SU_MAJOR_VERSIONFehler beim Laden der Datei LibOnSurface.rb
uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei LineOnSurface.rb
uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei LoaderOnSurface.rb
uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei OffsetAlgoOnSurface.rb
uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei OffsetOnSurface.rb
uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei PaletteOnSurface.rb
uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei PolylineOnSurface.rb
uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei ShapeOnSurface.rb
derweissi
Postby walpurgisnacht » Mon Aug 23, 2010 5:57 am
I cant get fredo6 colllection to show up in my tools menu. the plugin is installed and i have it enabled in preferences but dosnt appear otherwise
walpurgisnacht
Postby melissa11 » Sat Sep 04, 2010 12:42 am
hi,
doesnt seem to appear under the toolbars menu. It is turned on under preferences> extensions but I dont no where it is :?
new to this!
thanks
melissa11
Postby melissa11 » Sat Sep 04, 2010 3:19 pm
Hi, Did you find out the answer to your question - I have the same problem and havent figured it out yet. :?
melissa11
Postby thomthom » Sat Sep 04, 2010 8:09 pm
the first post doesnt make any references to libfredo...
PluginStore Author
PluginStore Author
Postby hassanykb » Thu Sep 09, 2010 7:50 am
:ecstatic: this is a life saver man!!!
you rock Fredo!
hassanykb
Postby Banjo » Tue Oct 26, 2010 9:21 am
Hey! I'm new member at Sketchucation. Wonder how I can get the plugin "Tools on surface"
regards /Banjo
hassanykb wrote::ecstatic: this is a life saver man!!!
you rock Fredo!
Banjo
Postby Gaieus » Tue Oct 26, 2010 9:28 am
Hi Banjo,
Download it from the first post of this topic.
Postby potatochips » Tue Oct 26, 2010 6:41 pm
why does it say there's an error???
Error Loading File ZLoader__OnSurface.rb
no such file to load -- LibFredo6.rb
potatochips
Postby Gaieus » Tue Oct 26, 2010 8:31 pm
Hi Potatochips,
Have you also installed the LibFredo library as advised in the first post?
Postby potatochips » Tue Oct 26, 2010 11:53 pm
Gaieus wrote:Hi Potatochips,
i got it to work now, thanks!
potatochips
Postby Ruturaj » Mon Nov 08, 2010 11:50 am
Hello sir,
your new version is working on google-sketchup pro 8 ...... ?
Thank you,
Ruturaj
Thanks,
RuturaJ
Ruturaj
Postby thomthom » Mon Nov 08, 2010 12:06 pm
yes - it work with SU8
PluginStore Author
PluginStore Author
Postby Ruturaj » Mon Nov 08, 2010 12:08 pm
Thank you ,..... :D
Thanks,
RuturaJ
Ruturaj
Postby thomthom » Mon Nov 08, 2010 1:28 pm
You can assume that most plugins work in SU8 if they worked in earlier versions. Just install and try.
PluginStore Author
PluginStore Author
Postby davidheim1 » Mon Jan 10, 2011 5:44 pm
Does Tools on Surface run on SU 8? I've tried to download and install it just as you described, but I can't seem to get it to appear in either the Tools menu or the Plug Ins menu, even after I restart my computer. I have the Dir 35 running on my computer. Any suggestions?
As always, many thanks
davidheim1
PreviousNext
Return to Plugins
cron
Users browsing this forum: brmediawks, Gabriela al, junmo bae, liutingkuang, Polynechramorph and 11 guests
