[Plugin] Tools On Surface - v2.3a - 06 Oct 17
Re: [Plugin] Tools On Surface - v1.5f (Doc in French)
Postby kilgo » Sun Nov 15, 2009 3:13 am
Thanks TIG,
The drape tool only drapes in a vertical fashion (whats the coordinate? X,Y?) So if for example I wanted to drape a #2 on the side of a slope it becomes distorted, elongated. Love your work by the way.
kilgo
Re: [Plugin] Tools On Surface - v1.5f (in Chinese)
Postby fredo6 » Thu Nov 26, 2009 9:43 pm
The script is now translated to Chinese, thanks to the effort of the CLT Team at SketchupBar.
see main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212&p=76625#p76625
fredo6
PluginStore Author
PluginStore Author
Postby Daniel S » Sun Dec 06, 2009 9:46 pm
Fredo...
Changing the axes has no effect in your inference system.. it still uses the standard axes.
Look that the standard SU tools are not using the original orientation of the axes.
Is there a way to choose that Tools on Surface can use the user defined axes instead the standard ones?
Daniel S
Daniel S
Re: [Plugin] Tools On Surface - v1.5f - 26 Nov 09
Postby red_shift » Tue Dec 22, 2009 12:40 am
Can someone please assist me with installing this plugin on Mac OS 10.6.2 (SU 7.1) I have unzipped the folder into SU plugin folder and moved Toolsonsurface.plugin to the Sketchup application package. I see no new menus in Sketchup.
red_shift
Postby majid » Wed Dec 30, 2009 9:00 am
I started to draw an arc on a curved face, and here is the result,....what is wrong with it? I was expecting that result , be somthimg like the black line , but finally I had the red line ,as result.
majid
Top SketchUcator
Postby red_shift » Thu Dec 31, 2009 12:07 am
I have still not been able to get the plugin to work on my Mac...can someone please give me some help?
red_shift
Postby fredo6 » Thu Dec 31, 2009 12:59 pm
red_shift wrote:I have still not been able to get the plugin to work on my Mac...can someone please give me some help?
On Mac, the plugin files should be copied to Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
Please make sure that your unzipping operation leads to the same footprint as indicated in page 2 of the PDF documentation, that is:
The 2 folders, LIBFREDO6_Dir_34 and TOS_Dir_15 must contains several files (.rb, .lang, ...) and a subfolder IMAGES_STANDARD (make sure that you do not have another LIBFREDO6_Dir_34 or TOS_Dir_15 embedded).
If needed, unzip in a separate place, check the files and directories and then copy them in the Sketchup Plugin folder:
Fred
PS: if it still does not work, then I must call the Mac user community to help.
fredo6
PluginStore Author
PluginStore Author
Postby tlerak » Sun Jan 17, 2010 12:44 am
where can i find tools on surface 1.5? thanks
tlerak
Postby thomthom » Sun Jan 17, 2010 12:20 pm
tlerak wrote:where can i find tools on surface 1.5? thanks
First post on the first page of this thread.
PluginStore Author
PluginStore Author
Postby haynesc » Sun Jan 17, 2010 4:57 pm
how would i draw a diagonal curved line from plain to plain ... ? top right corner to bottom left corner ?
haynesc
Postby Daniel S » Sun Jan 17, 2010 6:22 pm
haynesc wrote:how would i draw a diagonal curved line from plain to plain ... ? top right corner to bottom left corner ?
Alternative solution:
I see that you have Whaat´s "subdivide and smooth". Use the knife tool (a.k.a. zorro) in parallel projection. Also you can group the faces you don´t want to divide:
Daniel S
Daniel S
Postby Toucan » Fri Jan 22, 2010 4:02 am
Where do I find this script?
Toucan
Postby Chris Fullmer » Fri Jan 22, 2010 5:00 am
Hi Toucan, the script is located in the first post of this thread. Go back to page one and look for a download link there. Have fun!
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby thomthom » Wed Jan 27, 2010 10:57 am
I occasionally get this happening while using TOS. What's causing it?
I wanted to draw an arc between the two points - going across the two faces.
PluginStore Author
PluginStore Author
Postby fredo6 » Wed Jan 27, 2010 7:24 pm
The algorithm has many flaws, espcially on shape volumes that are closed.
I am thinking of a serious refresh to resolve these problems (and some others).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby whippie » Sun Jan 31, 2010 10:51 am
What a brilliant tool thanks thanks thanks :)
whippie
Re: [Plugin] Tools On Surface - v1.3 (more shapes, inference)
Postby balloon » Sun Jan 31, 2010 11:23 am
:enlight: :berserk: Thanks Fredo6 :ecstatic:
balloon
Postby Khai » Sun Jan 31, 2010 9:40 pm
may I request an additional feature?
adding rounded corners to a shape?
Khai
Postby thomthom » Sun Jan 31, 2010 10:21 pm
Fredo6 wrote:espcially on shape volumes that are closed.
So it some times picks the wrong distance/direction between the two points? A workaround would be to break the volume somehow?
PluginStore Author
PluginStore Author
Postby fredo6 » Sun Jan 31, 2010 10:35 pm
Somehow, it works much better when the surface is open.
But I know how to fix the problem. No easy, but I need some time, as I have to revisit the whole algorithm.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby nilblo » Thu Feb 04, 2010 12:06 pm
Rightclick menues issue..
After having installed Fredo6 Tools on surface + FredoScale I´m having the darnest stupid problem:
Most contextual menues are greyed out, like Intersect with model, Flip along Groups Red, and so on..
I can create shortcuts to these commands and they work as expected, but I rely heavily on shortcuts in my work and list of shortcuts is getting more and more crowded. Have I done something wrong here and this is normal behavior? I have been searching the forum but so far havent found a description af this "problem".
I have most definetely missed out on something here and the fault is obviously mine (as it usually is) but I really would appreciate an input to help me solve this matter.
Vista 64- Sketchup Pro 7.1.6860
Plugins: Fredo6 ToolsOnSurface v1.5f LIBFREDO6_Dir_34 (109 mS seems OK?
Total time to load plugin = 187 mS) FredoScale v2.0g (Total time to load plugin =124 mS)
SketchyPhysics verson3 Kerkythea SU2KT version 3.0 model exporter
nilblo
Postby sus4 » Wed Feb 10, 2010 9:02 am
too Dont Work Ver7.1.6087
error massage ZLoader__OnSurface.rb File loading error
No such file to load -- LibFredo6.rb
sus4
Postby fredo6 » Tue Feb 16, 2010 10:43 pm
nilblo wrote:Rightclick menues issue..
I have heard that this problem is related to SU itself, though it may be 'helped' by some plugins.
I got it occasionally, even not using any plugins.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby sketchyup2010 » Fri Feb 19, 2010 6:29 am
Great tool bro. Nice work!!!!
sketchyup2010
Postby dylan » Sat Feb 20, 2010 12:36 pm
A minor issue and not sure if this is Mac related.
I can only get the default icons to show.
If I go into Default Parameters and choose IMAGES_DanielS then save changes, it does nothing. I can open the default parameters again and the box is un-ticked.
I have the latest version installed.
dylan
Postby theark » Sun Mar 21, 2010 10:32 am
Thanks a lot.Good plug-in :berserk:
theark
Postby Rogue® » Thu Apr 08, 2010 9:10 am
Thanks loads for this tool, your work is great!
@ Dylan
Just replace the default icons with the ones you wish (in the plugins directory). Thats actually the way I did it.
I’m also having another issue. IDK if this has been discussed before or not, but after I use this tool I sometimes loose right click options such as; smooth, make group/component, reverse faces, etc.
Find all my models on the 3D Warehouse
Rogue®
Postby COSEDIMARCO » Thu Apr 08, 2010 9:13 am
Rogue® wrote:Thanks loads for this tool, your work is great!
I have this issue too.
COSEDIMARCO
Postby TIG » Thu Apr 08, 2010 9:23 am
The issue of loosing some right-click context-menu items [i.e. they get "greyed-out"] is a known bug with more recent versions of SketchUp - Google are being pressed to fix it...
Its cause is not wholly established, although having lots of plugins that make context-menu items and repeated clicking on objects seem to both trigger it - separately or together !
All of a context-menu's items still appear correctly under the last item in the main Edit Menu - so you can access them this way if the worst happens...
The only 'fix' is to save and restart SUp - then you should get back the context-menu, albeit momentarily.
Don't load plugins you aren't ever going to use - they increase the load and might just be the 'last-straw...' - move them out of the Plugins folder or rename them from .rb to .txt - that way you can always load them during a session by typing in the Ruby Console load"the_script_name.txt" ...
:roll:
Global Moderator
Postby COSEDIMARCO » Thu Apr 08, 2010 10:43 am
COSEDIMARCO
PreviousNext
Return to Plugins
Users browsing this forum: asiqahmed33, shing5o and 9 guests
