[Plugin] Polar line - 20110525
Re: [Plugin] Polar line
Postby Matt666 » Thu Jan 15, 2009 6:16 pm
I don't understand the problem... Again !! Grmbl.
Can you try line below in the ruby console, please ?
Code: Select all
Math.cos(45.degrees)
And these lines
Code: Select all
a = Geom::Point3d.new(12.5,12.5,25.2)
a[0]
a[1]
a[2]
On each line, can you give me the results, please ?
Thank you again for your patience, Edson!
Frenglish at its best !
My scripts
Matt666
Postby Edson » Thu Jan 15, 2009 7:35 pm
is this what you wanted?
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby thomthom » Fri Jan 16, 2009 12:17 pm
Edson: you wrote 0 = Geom:: and 1 = Geom:: . That's not what he wanted. Just type exactly what he listed.
First:
Code: Select all
Then
Code: Select all
a[0]
and so on.
PluginStore Author
PluginStore Author
Postby Edson » Fri Jan 16, 2009 12:46 pm
is this it?
Edson
Global Moderator
Postby thomthom » Fri Jan 16, 2009 12:52 pm
Yes, like that. :)
PluginStore Author
PluginStore Author
Postby Matt666 » Fri Jan 16, 2009 12:59 pm
Thank you Edson and Thomthom !
I really really don't understand...
Can someone help me for this bug, please ?
My scripts
Matt666
Postby thomthom » Fri Jan 16, 2009 2:23 pm
I can have a look on my own Mac when I get home.
Looks very weird. Does PC SU and MacSU use the same Ruby version?
Have you tried placing () around lg * Math.cos(ang) . (just a wild guess)
PluginStore Author
PluginStore Author
Postby thomthom » Fri Jan 16, 2009 3:15 pm
Hey, I notice you use $lg and then lg. Is it suppose to be two different things?
PluginStore Author
PluginStore Author
Postby Matt666 » Fri Jan 16, 2009 3:57 pm
I don't know, but I often have problems...
Thank you !
I will look in the code... Thank you!
My scripts
Matt666
Postby thomthom » Fri Jan 16, 2009 5:30 pm
Got it nailed!
It's all down to line 69:
Code: Select all
case Sketchup.active_model.options[0][2]
On my mac it returned nil
Your case switch doesn't account for that value so lg is passed on as a string.
Code: Select all
    when 0;lg = result[0].to_f
    when 1;lg = result[0].to_f.feet
    when 2;lg = result[0].to_f.mm
    when 3;lg = result[0].to_f.cm
    when 4;lg = result[0].to_f.m
My fix was to add a default handler for the switch.
Code: Select all
    else  ;lg = result[0].to_f
Not sure why line 69 return nil though, didn't look into that.
PluginStore Author
PluginStore Author
Postby Matt666 » Mon Jan 19, 2009 8:37 am
Ok cool !! Thank you for your bug research Thomthom !
I am pretty sure it works if you try this code below
Code: Select all
Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
can you try it please ?
For "pl" variable, no problem. "$pl" is used to reuse last number entered in the polarline window...
My scripts
Matt666
Postby thomthom » Mon Jan 19, 2009 2:02 pm
I'll try it and report back.
PluginStore Author
PluginStore Author
Postby thomthom » Mon Jan 19, 2009 6:49 pm
Yes, that worked. :thumb:
PluginStore Author
PluginStore Author
Postby Matt666 » Tue Jan 20, 2009 8:35 am
Thank you Thomthom!
I've updated the first post... Can you try it on Mac please? Thank you!
My scripts
Matt666
Postby Edson » Tue Jan 20, 2009 11:49 am
matt,
now nothing happens at all. not even the request for the first point appears.
Edson
Global Moderator
Postby Matt666 » Tue Jan 20, 2009 1:09 pm
:cry: :cry: :cry:
Can you show me the error in the ruby console please?
My scripts
Matt666
Postby Edson » Tue Jan 20, 2009 1:29 pm
the console window was filled with a lot of stuff. this is the last piece. if you need the rest, let me know.
Edson
Global Moderator
Postby Matt666 » Tue Jan 20, 2009 3:06 pm
:oops: :oops:
Excuse me Edson... A silly error... Shame on me !
I updated the code...
Sorry !
My scripts
Matt666
Postby Edson » Tue Jan 20, 2009 5:35 pm
YESSSSSS! it does work!
and thanks, matt, for the great scripts you have been creating. count on me anytime to help you with testing scripts on mac.
Edson
Global Moderator
Postby Matt666 » Wed Jan 21, 2009 8:14 am
:ecstatic: :ecstatic: :ecstatic:
It does work, AT LAST !! Ouf... Thank you for your patience Edson!
Thank you, Edson :oops:
Ok, cool! There is also one only script that doesn't work on Mac... I'll try to do smt on it...
My scripts
Matt666
Postby thomthom » Wed Jan 21, 2009 8:51 am
I got a Mac Mini at disposal on a OSX 10.4 system. Slow as heck, but works to see if it runs.
PluginStore Author
PluginStore Author
Postby Matt666 » Wed Jan 21, 2009 10:10 am
Ok, Thank you Thomthom!
My scripts
Matt666
Postby Matt666 » Wed Jan 21, 2009 1:58 pm
sorry Thomthom, but can you have a Mac look on this script, please?
My scripts
Matt666
Postby thomthom » Sun Jan 25, 2009 11:31 pm
Matt666 wrote:sorry Thomthom, but can you have a Mac look on this script, please?
Sorry, dude! I completely forgot. I'll see if I can have a look at it tomorrow.
PluginStore Author
PluginStore Author
Postby Click Draw » Mon Jan 26, 2009 12:02 am
Hey Matt,
Just installed your script. Good stuff. The icon matches nicely too. Keep'em comin'.
Cheers,
Jeff
Have I mentioned how much of a laugh I get out of some of the Signatures on here!
Click Draw
Postby pmain68 » Tue May 24, 2011 11:43 pm
Hey ThomThom & Edson,
Any ideas why i get this error when opening SU 8 after installing the polarline script?
Error Loading File polarline.rb
undefined method `file_loaded?' for main:Object
cheers
pmain68
Postby thomthom » Wed May 25, 2011 7:38 am
That sounds like the file doesn't have require 'sketchup.rb'. A bug that won't be noticed if you have other plugins installed that require 'sketchup.rb'.
PluginStore Author
PluginStore Author
Postby Matt666 » Wed May 25, 2011 8:55 am
Hi all!
New version updated. See first post. Thank you Thomthom & pmain68.
My scripts
Matt666
Postby thomthom » Wed May 25, 2011 9:13 am
:thumb:
Could you add the date of update in the topic title? (Makes browsing plugins easier if you're looking for updates.)
PluginStore Author
PluginStore Author
Postby Matt666 » Wed May 25, 2011 9:16 am
Ok.
My scripts
Matt666
PreviousNext
Return to Plugins
Users browsing this forum: Bing [Bot] and 9 guests
