[Plugin] FredoTools - v4.5a - 02 Apr 24
I think the problem was already signaled, and it seems this happens only on MacOS.
Note that you can also type Enter to activate / deactivate the gizmo.Difficult for me to troubleshoot as I don't have a Mac. I made a modif blindly, just in case this improves.
Fredo6_FredoTools - v3.1f - 03 Nov 17 - certified - encrypted.rbz
Could you check if you still have the problem.
I installed that version but the issue persists.
Fredo like I said to you before, for me it's a minor issue. -
The FredoTools v3.1e works fine on OS X 10.11.6 & SU2016, the issue is with SU2017.
Even more weird.
Did you try with double-click on a textured face?Fredo
Yes, but this doesn't resolve the issue. Don't worry Fredo, it's a little problem but it doesn't interrupt my workflow.
Just try to understand what can be caused by
- a difference between Mac and Windows
- a difference between SU2016 and SU2017
To you get a stable gizmo when pressing Enter on a textured face ?
What happen if you click down, release without moving the mouse ?
Yes, If I press Enter over a textured face the gizmo is stable. When click down the gizmo appears but it disappear immediately (1 second).
NEW RELEASE: FredoTools v3.1g - 11 Nov 17
FredoTools 3.1g fixes a bug in FredoTools::ReportLabelArea, for the CSV export in non-English languages.
See FredoTools plugin home page for Download.
See also main post of this thread for User Discussion.
Hello Fredo,
Is the thrupaint bugsplat fixed in "FredoTools v3.1g - 11 Nov 17" release?
It still occur on some of my machines!
Any suggestion is much appreciated.
NEW RELEASE: FredoTools v3.2a - 24 Feb 18
FredoTools 3.2a is about bug fixing and introduction of FaceTriangulator.
NEW RELEASE: FredoTools v3.2b - 27 Feb 18
FredoTools 3.2b is about a small adjustment in FaceTriangulator and some bug fixing.
May I ask, what is the main purpose of triangulator?
Just to divide a face into triangles, which is useful in some situations. Actually FaceTriangulator is just a byproduct of another plugin to come.
Note that there exists other plugins for face trinagulation (at least one by TIG). FaceTriangulator gives the same result, but you can impose triangulation points as Construction Points on the face.
Fredo, I installed this update, but SketchUp still crash when I launch the Thrupaint.
Which version of Sketchup? Your profile says SU2016.
That occur on SketchUp 2018 and SketchUp 2017, I didn't test it on 2016.
I know there is this random bugsplat, but I am unable to reproduce it in my own environment.
If you have it, could you send a report to Sketchup in the bugsplat window, note the bugsplat record number and post or send this crash number to me.
I thought this update has a fix for these random bugsplat. The Bugsplat record number is #37782
I have sent the bugsplat report to you as a PM.Thanks
NEW RELEASE: FredoTools v3.2c - 12 Mar 18
FredoTools 3.2c fixes a major bug in the calculation of volume in SolidVolume
Fredo, in this particular model reverse\ orient tool fails to exit with savedresult. could you take a look? Thanks!
