OK. You don't need a plugin for that. Make copies of the components/groups placed throughout the model as needed. Create layers that can be associated with the scenes. Then assign the layers to the components/groups that you want to show in each scene.
So you might have a component in Position 1 in Scene 1 and that component is associated with Layer 1. All other layers are turned off for Scene 1. Then in Scene 2, the component in Position 2 is on Layer 2 and all other layers are turned off.
Thank you very much for your explanation If this is how I work with the layer and components or groups. But it is more simple, just move objects and save your position in each scene. Keyframeanimator is a good plugin, but payment and more complex. I just want a simple tool that allows to keep the same object is different positions, different scenes
jorge2011 wrote:Thank you very much for your explanation If this is how I work with the layer and components or groups. But it is more simple, just move objects and save your position in each scene. Keyframeanimator is a good plugin, but payment and more complex. I just want a simple tool that allows to keep the same object is different positions, different scenes
There may be some folks out there looking at your subject line and having questions of their own, like what does this guy think the subject line is for? Better to put some meat on that hook if you want to catch something. Otherwise they may think you don't mind wasting their time... Do you know what I mean?
Dave R wrote:OK. You don't need a plugin for that. Make copies of the components/groups placed throughout the model as needed. Create layers that can be associated with the scenes. Then assign the layers to the components/groups that you want to show in each scene.
thanks for their answers. Pilou Forexample. 1 - I want to make an office and try 10 different ways to arrange the furniture. After show my client and titrated in 3d it the most interesting options. I do not need the image, I need the 3D options, then go adjusting the most interesting. This can be done by creating groups and components, duplicate, and show different layers and different scenes. But this makes duplicate geometries and is a bit annoying to go hiding and showing.
jorge2011 wrote:But this makes duplicate geometries and is a bit annoying to go hiding and showing.
You are right about the duplicates but not about the annoying. Once you create the different scenes there is no delay to speak of and the hiding and showing is all done for you. You can have transitional effects and animate it if impressing is in your program.
This plugin is interesting. I would like, if possible, add some features.?
1 - to use different components and groups. 2 - to usr many identical components. 3 - add an interface to sin, perhaps, html or something similar to the interface of this plugin: http://www.smustard.com/script/RepeatCopy
