SketchUcation Premium Membership
[Plugin] Create Section Drawing V1.3(update Dec16.2012.)
Postby tak2hata » Wed May 02, 2012 3:31 pm
Hi,everyone.
I release plugin named "Create Section Drawing".
##General disclaimer
##I MAKES NO GUARANTEE OF VALIDITY about reports by using this script.
##Please use this script at your own risk.
##This plugin need sketchup v8 higher.
##May 02.2012:v1.0 Fisrt release.
##May 06.2012:v1.1 Bugfix about calculating baselines on mac.
##Jun 28.2012:v1.2 Improve about dxf value scaling by units in sketchup.
##Dec 16.2012:v1.3 The drawings is added the text about Distance of SectionPlane.
##And Add "About This" in menu.The version infos can be see.
#Description
#Select the section plane and pulldown menu "Create Section Drawing".
#And The section will be created in the component definition list of the model.
#and export to "DrawingSection" folder as skp and dxf.
#The section from solid will be filled.
#The infomation of component or group will add text to drawings.(name,and BST info)
#The ComponentDefinition named "BST_BASELINES" will add baselines to drawings.
##Under the line added in May03.2012.
##"DrawingSection" folder will be created in the same folder with the editing sketchup model file.
##Do not create new folder when it is not saved.
##But section drawing is created as component definition ,too.
##So looking for the component list.It will be found.
Download Current version(v1.3):
create_section_drawings.rb
Download Older version( v1.2):
Video "How to use"(youtube).
Enjoy! :D
Thanks.
by TAK2HATA
tak2hata
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Intermediate
Re: [Plugin] Create Section Drawing May02.2012.
Postby Bob James » Wed May 02, 2012 4:40 pm
A major addition to the arsenal: thank you. :thumb:
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
User avatar
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby glro » Wed May 02, 2012 6:25 pm
tak2hata wrote:...
The problem for me when i use section plans is that there is no inference; you can not set their position precisely
for a reinforced concrete structure, it may not be important; for a steel structure it is because you might have to be more precise
is there a way to paste a section plan precisely to a point, or a line, for example?
It is only a detail compared to all the work you have already done... congratulations...
glro
Name: Georges LE ROUX
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby Panga » Wed May 02, 2012 10:31 pm
Amazing tak2hata, this will be very usefull !!! Thanks a lot !!
Panga
Premium Member
Premium Member
Postby pbacot » Wed May 02, 2012 11:21 pm
That looks great. I might be wanting this in my workflow. Must have taken a lot of work (and brains). Thank you. Peter
User avatar
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby guanjin » Thu May 03, 2012 2:28 am
I do not see the video, so I got the effect is, am I doing wrong what. :roll:
User avatar
guanjin
SketchUp version: 8
License type: Free
SketchUp use: interior design
Postby SUFractal » Thu May 03, 2012 3:27 am
#Description
Download Version1.0:
Looks interesting.
Where is the "Section Drawing" folder? I can't seem to locate it?
SUFractal
Postby tak2hata » Thu May 03, 2012 4:21 am
Hi,guanjin.
This plugin create section to drawing.
So the drawing of face side is not supported.
But,The door openning in center of the picture you posted weighs on my mind.
I want upload your file here.
Hi,SU Fractal.
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby tomislavm » Thu May 03, 2012 6:42 am
Thank You!
tomislavm
SketchUp version: 8
License type: Free
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby ZFRPS » Thu May 03, 2012 11:07 am
Very very nice!
sketchup is bim
ZFRPS
Postby mitcorb » Thu May 03, 2012 12:42 pm
Hi, tak2hata:
I would like to say that this is a significant accomplishment based on what I saw in the video. I can see this as a very useful and valuable tool in a document production process. Congratulations.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Ben Ritter » Thu May 03, 2012 1:20 pm
Very nice and thank you. However, when the section is created, the window that pops up indicates how long the process took and it says "Time Wasted". I wouldn't call it "time wasted". It's not a waste at all, but it is a time saver. :thumb: :thumb: Thank you so much.
Ben Ritter
Postby SUFractal » Fri May 04, 2012 5:21 pm
tak2hata wrote:
Hi,SU Fractal.
Thanks.
I'm sorry tak2hata, I'm not following you. I looked inside the folder (on my hard drive) where the model is located ... is that what you mean?
Thanks.
SUFractal
Postby tak2hata » Sat May 05, 2012 4:31 pm
Hi,SU Fractal.
I fixed bug about calculating baselines on mac.
This script was aborted on mac with this problem.
This version become to 1.1 .
So "DrawingSection" folder will be created.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Re: [Plugin] Create Section Drawing V1.1(update May06.2012.)
Postby mwm5053 » Sat May 05, 2012 4:47 pm
Thanks,tak2hata very good stuff
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby saturne45 » Sat May 05, 2012 10:44 pm
Thank you, tak2hata, very good plugin.
saturne45
Postby SUFractal » Sun May 06, 2012 1:26 am
tak2hata wrote:Hi,SU Fractal.
Beautiful! :D
SUFractal
Postby Elibjr » Tue May 08, 2012 3:40 am
Wow, Tak2hata This is truly an amazing plugin. I can't wait to use it. The more I see plugins like this, I keep asking the question why Revit when you can SketchUp? It's plugins like this that will make Trimble proud they are getting a program that gets cooler by each user's contribution. Autodesk could NEVER say that. Great work!
User avatar
Elibjr
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby nabilaaftab » Mon May 14, 2012 7:54 pm
hey but where can i doownload this great plugin????????????????
nabilaaftab
Postby tak2hata » Tue May 15, 2012 4:20 am
nabilaaftab wrote:hey but where can i doownload this great plugin????????????????
Hi,nabikaaftab.
It can be downloaded in the top of this thread.Need to login this forum.
It can be downloaded from my homepage,too.http://onigiriburning.so.land.to/plugins.html when you can not log in this forum.
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby nabilaaftab » Tue May 15, 2012 11:16 am
hey, thanx a lot for ur reply. but i must have missed sth. i cant find any download link in this tread even though i am logged in. i also tried ur website where i could download some other great plugins. but i couldnot download section cut plugin...
what am i doing worng...?
nabilaaftab
Postby Gaieus » Tue May 15, 2012 11:30 am
nabilaaftab wrote:i cant find any download link in this tread even though i am logged in.
Go to the first post of this topic: viewtopic.php?p=402561#p402561 and find the download link at the bottom of that topic:
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby refy » Tue May 15, 2012 5:30 pm
Sir Tak2hata you have contributed very useful plug-ins but this is off topic because i did find your plug-in multi export using the vidro. Could you please make a tutorial on exporting and adding material with vidro. i just don't know how to use the vidro renderer.
refy
Postby wodur » Tue May 22, 2012 9:44 am
very usefull plugin thanks
wodur
Postby paolomiana » Thu May 24, 2012 11:32 am
Hi TAK2HATA,
first of all thanks a lot for the plugin, it is very very useful. I just have a problem: if I create a section of my drawing and export it, works fine if I open the .skp file, but when I open the the .DXF one it convert it automatically from the metric system to the UK/US units. So in the end I have a drawing that is 25.4 times bigger than the original.
I am using solidedge 2D software and all the drawings I am using are in metric system
any suggestion?
thanks
Paolo
paolomiana
[Plugin] Create Section Drawing V1.1 Won´t Wrok? Try This.
Postby Phanga » Wed Jun 27, 2012 7:47 pm
After few searching i found how to install this plug in.
Just in case, i´ld like to share with you one thing. After i install it, it didn´t work, but i found that if you have a number of complex objects, specially with hidden informations, probably it wont give you the results you expect.
Try to clean your drawing first and try again.
It was a good way to rethink a way to make a clean project.
Have a nice day!
Phanga
Postby tak2hata » Thu Jun 28, 2012 3:31 pm
Hi,Paolo.
I update this plugin in Jun 28.2012.
Export dxf as inch values when the length unit in sketchup is inch.
Hi,Phanga.
Thanks your sharing. :D
refy wrote:Sir Tak2hata you have contributed very useful plug-ins but this is off topic because i did find your plug-in multi export using the vidro. Could you please make a tutorial on exporting and adding material with vidro. i just don't know how to use the vidro renderer.
Hi refy.
I will improve su2objmtl_vidro in future.
I will add material edit function for vidro.
In this time,material name is used for vidro material setting.
Su2objmtl_vidro material setting manual.http://onigiriburning.so.land.to/su2objmtl_page.html
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Re: [Plugin] Create Section Drawing V1.2(update Jun28.2012.)
Postby tulacong » Fri Jun 29, 2012 2:24 pm
ok thank you men :sketchstatic:
tulacong
Postby Bertier » Fri Jun 29, 2012 10:16 pm
+ 1
Bertier
Postby paolomiana » Mon Jul 02, 2012 8:19 am
thanks a lot!
Paolo
paolomiana
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: andressolizpaz, Betinho Cruz, chau.robert, fredo6, karimtabbara, ksprmx, MrArchitect13, Rich O Brien, W3C Validator and 6 guests
