Visopt for exterior
General discussion on V-Ray for SketchUp
Visopt for exterior
Postby DVERGER » Thu Mar 22, 2012 12:26 pm
Hello,
Where I can find good visopt for exterior? (for 1.49)
DVERGER
Re: Visopt for exterior
Postby andybot » Thu Mar 22, 2012 12:40 pm
I would suggest using the default visopt, it's a good place to start. You can then tweak things like GI levels (remove TexSky, and check default lights in global options, so you get more ambient light and still have sun shadows) or irrmap settings (increase hsph subdivs), etc. It seems a lot of the older visopts you find online are from previous versions and may cause errors. Make sure you look at the various tutorials for vfsu to understand which settings to change.
my blog featuring recent projects
andybot
Premium Member
Premium Member
Postby DVERGER » Thu Mar 22, 2012 1:58 pm
Thank you for the advice.
Here on the left my render with VRay1.05 and on the right with VRay 1.49. I used the same texture for the wall (I have lost the grany texture).
DVERGER
Postby andybot » Thu Mar 22, 2012 3:37 pm
Yeah, there's been a fix with the gamma level, so renders with the current version will be brighter. You can adjust with the inverse using 0.4545
andybot
Premium Member
Premium Member
Return to V-Ray
Users browsing this forum: magic1888, rickycamui, witwiw and 10 guests
