Vray render error
General discussion on V-Ray for SketchUp
Vray render error
Postby JASTAR » Tue Nov 01, 2011 2:25 pm
HI,
Im rendering sketchup models with vray. This was working fine until yesterday. Then the render window starting showing a plain black screen with white dots (see screen shot). When i render the model using 'override material color' it comes out fine (see render).
This has been such a problem that i have downloaded new sketchup and vrays in case of corruption. On new models it is generally ok, however rendering this same sketchup model causes the same problem - black render box with white dots.
Does anyone know the problem?
thank you,
jacob
JASTAR
Re: Vray render error
Postby andybot » Tue Nov 01, 2011 3:24 pm
try loading your default vray options and do the rendering again. If that doesn't work, check if you have displacement map on any of your materials - that can sometimes cause the Light Cache pass to hang. In that case try turning off your displacement and use bump instead, see if it works.
my blog featuring recent projects
andybot
Premium Member
Premium Member
Postby JASTAR » Wed Nov 02, 2011 12:33 pm
Thanks for your response andybot.
None of my materials had displacement maps on them. I have since changed all my materials to originate from the vray material editor rather than the SU material pallet. This seems to have done the trick.
It still seems very odd that this was happening. Maybe a glitch with Vray?
Cheers,
jacob
JASTAR
Postby andybot » Wed Nov 02, 2011 4:20 pm
sometimes I run into problems with materials if I am using components from the warehouse. I have to go through and check materials carefully.
andybot
Premium Member
Premium Member
Postby valerostudio » Wed Nov 02, 2011 4:38 pm
I get this issue all the time with displacement. Sometimes it takes hours to get the thing to start cranking along.
valerostudio
Return to V-Ray
Users browsing this forum: No registered users and 8 guests
