SketchUcation Plugin Store
batch rendering?
batch rendering?
Postby dav21 » Wed Sep 07, 2011 3:22 pm
How can i do rendering like this? The second one starts when first one finishes. there are two files. When the second one finishes and gets completed the third one starts, so on and so forth. Is there an option in vray for su too like this? Many times all the modeling gets complete and all the views are set. There's only the need to hit the render button and go for dinner :D.
dav21
Re: batch rendering?
Postby lvl1201 » Sat Sep 10, 2011 8:14 pm
It is very simple.
First you set up your scenes in sketchup.
Scene1 scene2 scene 3 etc
In some older version of vray the scene 1 will be rendered 2 times in version 1.49.01 this no longer happens.
In sketchup go to view/animation/settings enable scene transition with 0 seconds.
And below that put the scene delay to 1 second.
Now in vray option be sure to have batch render enabled (options/globalsiwtches/batch render)
Then go to the output section, select render output save and name the file whatever you want, i always use simple things like A,B or C.
Below select animation on, instead of NTSC select in the frame rate custom, fps=1 and enable the include frame number thingie.
Yes i want to become an Architect.
Yes im pretty close to that.
lvl1201
Postby Rodrigonotor » Sat Sep 10, 2011 8:27 pm
In sketchup, make the number of scenes what you need to render.
First. In Menu: View->Animation->settings
Disable Scene transitions and put scene delay = 1
Second. In V-ray->options->Output
Check the animation On
Last. Go to dinner.
Regards
Rodrigonotor
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: architecture
Postby bagatelo » Fri Sep 16, 2011 4:10 pm
Is not needed to assign on "Save file"? And the option "Batch render"?
Rodrigonotor wrote:In sketchup, make the number of scenes what you need to render.
Last. Go to dinner.
Regards
bagatelo
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Postby Rodrigonotor » Sat Sep 24, 2011 1:40 am
Sorry. Yep, you have to check the save option and put a name.
Rodrigonotor
SketchUp version: 8
License type: Free
Postby rendell2009 » Sat Nov 12, 2011 1:36 pm
how can we play the render animation in SU?
rendell2009
Postby Rodrigonotor » Sun Nov 13, 2011 2:03 am
Menu->View->Animation->Play
Rodrigonotor
SketchUp version: 8
License type: Free
Postby valerostudio » Mon Nov 14, 2011 3:13 pm
It sounded like the question was asking about rendering different files and not different scenes of the same file. If this is the case, the answer is no. You cannot setup renderings for different files to batch.
valerostudio
SketchUp version: 8
License type: Pro
Level of SketchUp: Advanced
Postby peter_shaw » Thu Nov 24, 2011 3:24 pm
valerostudio wrote:It sounded like the question was asking about rendering different files and not different scenes of the same file. If this is the case, the answer is no. You cannot setup renderings for different files to batch.
BUT if you have multiple files, you could merge them to 1 file (copy paste) and do it the way described here, with scenes
in addition, u can use something like http://sourceforge.net/projects/shutdown/ to shut down your PC after it finished rendering (use the CPU usage option).
btw: this is my first post here, hello! :bounce:
peter_shaw
SketchUp version: 8
License type: Free
Level of SketchUp: Beginner
Postby davelee100 » Thu Jan 26, 2012 3:26 pm
Am I missing something here?
I follow the instructions above but don't know how to actually set the rendering in motion as nothing I try works.
I click render and the screen scrolls rapidly through the scene tabs and the frame buffer renders all the scenes one by one but why are the renders not being stored as JPEGs in the folder that I assigned on my hard drive?
If I export using sketchups export option I get all the scenes saved as you see them on the sketchup screen but I want the vray rendered images... Can anyone help please?
Dave
davelee100
Postby andybot » Thu Jan 26, 2012 4:05 pm
@davelee: which version of vfsu? Also, is the vray frame buffer window (render window) showing up? If not, can you do a rendering without animation from that file? If you don't see the window, the render isn't happening.
andybot
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby davelee100 » Thu Jan 26, 2012 5:15 pm
I am using the latest version for the mac 1.49 i think.
The frame buffer shows yes and I see the scenes render one by one on the screen but only on the screen. Shouldn't they save out to my drive?
Ill try rendering one scene to disk as per your advice.
davelee100
Postby andybot » Thu Jan 26, 2012 5:24 pm
It sounds like the render works fine. You need to make sure in your output option you have an autosave file name specified.
andybot
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby valerostudio » Fri Jan 27, 2012 7:24 pm
You also have to make sure you have INCLUDE FRAME NUMBER ticked on.
valerostudio
SketchUp version: 8
License type: Pro
Postby Flatchoum » Wed Dec 12, 2012 7:59 pm
Hello, I don't know wether or not Davelle solved his problem, but I do have the same one, with sketchup 8 and I think the last version of VFSU, but on PC. The batch rendering operates, but doesn't save the picture files anywhere, that's very frustrating. Any idea?
Flatchoum
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby panixia » Mon Dec 17, 2012 10:47 pm
did you check "enable scene transition" in sketchup animation settings???
panixia
SketchUp version: 8
License type: Free
SketchUp use: other
Postby Flatchoum » Tue Dec 18, 2012 11:22 pm
Yes I did, the scenes render, but just don't get saved anywhere...
Flatchoum
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Flatchoum » Thu Dec 20, 2012 9:21 pm
HI, still haven't found a solution, except for wacking up every hour last night, change scenes manually, pray and go back to bed...for one hour. I tryed several ways, calculating pictures of 5x5...They always calculate but don't get saved anywhere. I wish I could find a solution before the end of this world, please help!
Flatchoum
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby ATLAStudio » Fri Dec 21, 2012 10:13 am
This tutorial has fairly comprehensive options setup, not sure if it'll solve the issues though as haven't tried animation myself.
http://sketchupvrayresources.blogspot.c ... ation.html
ATLAStudio
SketchUp version: 8
License type: Free
Postby andybot » Fri Dec 21, 2012 12:11 pm
Flatchoum wrote:HI, still haven't found a solution, except for wacking up every hour last night, change scenes manually, pray and go back to bed...for one hour. I tryed several ways, calculating pictures of 5x5...They always calculate but don't get saved anywhere. I wish I could find a solution before the end of this world, please help!
Just a simple thing to check - have you specified a file name for your saved images? You have to have autosave enabled so vray can save your images.
andybot
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby Pierreaudouin » Thu Jan 03, 2013 10:08 am
I also had this problem recording.
I did a search in windows and the files were stored in TEMP / vfstextureCache.
I hope you find it!
Pierreaudouin
Postby Pierreaudouin » Thu Jan 03, 2013 10:38 am
lvl1201 wrote:In some older version of vray the scene 1 will be rendered 2 times in version 1.49.01 this no longer happens.
I have the last version of Vray (1.49.01), but the first scene is rendered two times!!!
I don't know why.
Is it the same for you?
Pierreaudouin
Postby Flatchoum » Thu Jan 03, 2013 3:43 pm
Thanks for your answers, I still have the same problem; to Andybot, yes I specified a name, and to PierreAudouin, I'm very surprised, it looks like I don't have such a file named vfstextureCache? I looked for it, I don't think I have Hidden files, on Windows 7... Still trying to do a Batch rendering now, I hope 2013 gives me the answer. I'm on Sketchup 8 and bought my Vrayfor SU version in August. To Pierre, you must have an option like "reboot on first scene"?
Flatchoum
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Flatchoum » Thu Jan 03, 2013 4:20 pm
Wow! I just looked again, and I finally found the pictures! They were hidden in the OS(C:)/User/(Me)/AppData/Local/Temp/VfsTextureCache!!!
Thank god I can now work and sleep 8 hours in a row!! And Special thanks to PierreAudouin too, you were right! I just wonder why the pics are saved ther and not where I told Vray to save it? an other bug? And the search tool on windows 7 is just useless, perhaps should I stay on a mac next time I buy a Computer...This little gag almost cost me a project
Flatchoum
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Pierreaudouin » Thu Jan 03, 2013 5:09 pm
Yes, good, this is 2013!!!
Happy new year!
it's weird, it is thanks to the windows search tool I have found my files.
Good for you.
I search "reboot on first scene".I don't have option like this.
it doesn't matter,but if you have a solution...
Pierreaudouin
Postby Flatchoum » Fri Jan 04, 2013 9:25 am
Happy new year too! I can't find this option any more, but I'm pretty sure it was part of the previous sketchup versions. By the way I also have the first scene doubled in my file this morning...And they look strictly the same? Now I have a little bug with the "face me components": some of them are grouped at the origin of the axes...Weird, but I may find an explanation on this forum...
Flatchoum
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby peter_shaw » Fri Jan 04, 2013 4:19 pm
is it possible to change layer states during a batch render? i'm trying to render an animation made with SU animate, but vray only seems to accept the layer state of the first scene.
check the attachement to see what i mean
peter_shaw
SketchUp version: 8
License type: Free
Postby andybot » Fri Jan 04, 2013 4:35 pm
peter_shaw wrote:is it possible to change layer states during a batch render? i'm trying to render an animation made with SU animate, but vray only seems to accept the layer state of the first scene.
unfortunately, no. That's just the way vray works currently. It only loads the model once at the beginning for batch rendering.
andybot
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby Pierreaudouin » Fri Jan 04, 2013 4:59 pm
and i ask the same question with camera setting (focal, aspect ratio...)?
Pierreaudouin
Postby peter_shaw » Sat Jan 05, 2013 1:30 pm
Pierreaudouin wrote:and i ask the same question with camera setting (focal, aspect ratio...)?
only position if i remember correctly
peter_shaw
SketchUp version: 8
License type: Free
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Next
Return to V-Ray
Users browsing this forum: kripkari and 4 guests
