SketchUcation Premium Membership
Invisible sketchup model when VRAY rendering
Postby sinanp » Sat Dec 19, 2009 6:24 am
Having some issues trying to render a sketchup model using VRAY. All that appears in the render is the landscape surface I made using contours. The rest of the model is invisible, I've tried applying VRAY material to groups and all the lines/surfaces within the group (not sure if I need to do the latter, is applying materials to groups alone enough?) but still to no avail?
sinanp
Re: Invisible sketchup model when VRAY rendering
Postby thomthom » Sat Dec 19, 2009 10:42 am
what version of V-Ray for Sketchup do you use?
What does it say in the About section?
Global Moderator
Name: Thomas Thomassen
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby sinanp » Sun Dec 20, 2009 1:45 am
Not quite sure what happened but the install must have been corrupted/faulty reinstalled VRAY and finally getting some model outputs! thanks very much
sinanp
Postby thomthom » Sun Dec 20, 2009 3:26 am
sinanp wrote:Not quite sure what happened but the install must have been corrupted/faulty reinstalled VRAY and finally getting some model outputs! thanks very much
Or ... it could be the disappearing group bug. Which will correct itself if you reload the file...
Global Moderator
License type: Pro
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Return to V-Ray
Users browsing this forum: Bing [Bot] and 4 guests
