I am trying to get a grip of DOF in Vray and my tests have failed miserably.
Kwistenbiebel if you are around I could use your help as i've seen many examples of your work with vray using this feature so I'd assume you could give me some pointers.
Vray- D.o.F help
• Page 1 of 1
Vray- D.o.F helpI am trying to get a grip of DOF in Vray and my tests have failed miserably.
Re: Vray- D.o.F helpHi Pete,
Setting the DOF is not that easy. As I recall the DOF parameters need to be set in Feet. So you need to convert your file units. I never used camera DOF that much in VfSU (because of that reason). I got away with using the 'Depth Map' option in the Frame Buffer in many cases. There was an interesting thread on the Asgvis forum some time ago . I'll try to find it and post the link here... EDIT: Found it
Inches. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: Vray- D.o.F helpMucho gracias my friend.
* off topic * How is Oz?
Re: Vray- D.o.F helpNo worries (as they say here
And Thomas is right (again *Off Topic*: Oz is great. We enjoy it a lot, especially the weather, the beach/nature and the people. Work is quite busy, so no going to beach for a short while now.
Re: Vray- D.o.F helpSolo,
Check out this youtube tutorial, it's not exactly what you were looking for but it's a good alternative way of approaching DOF.......hope this helps.....http://www.youtube.com/watch?v=fDzNJYi6Bok zzzSPUzzz
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
• Page 1 of 1
