I am having my first try at some simple experimental Vray renders and have run into a couple of issues.
When I have applied materials to a number of faces and render it is fine. When I change these faces with alternate materials, it still works ok. But when I then try to use a Sketchup material and/or a jpeg texture via the sketchup menu (not the Vray menu), the Vray seems not to notice the exchanged texture.
Yet it will recognise the texture if it is never changed at commencement of a new file and render.
Any suggestions?
