UI::Tool protoclass
Moderator: Jim
UI::Tool protoclass
Postby Dan Rathbun » Fri Dec 21, 2012 3:34 am
    UI::Tool protoclass
    Not sure if anyone has proposed a UI::Tool protoclass yet... but it's something I've been missing in the API, and I believe the API needs, IF we ever get our oft professed wish that the Sketchup::ToolsObserver work with Ruby tools.
    so here's a start:
    Code: Select all
    class UI::Tool
      ### CLASS METHODS
      alias_method(:create,:new)
      private_class_method( :create )
      public
      # self.new()
      # The public constructor method.
      # Calls the private method initialize(), in the new instance,
      #  after creating it, passing it all arguments it received.
      def self.new(*args)
        obj = self.create(*args)
        obj.instance_eval('@first_activation=true')
        obj.instance_eval('@tool_id=0')
      ### INSTANCE METHODS
      private
      def first_activation?()
        @first_activation
      def first_activate()
        model = Sketchup.active_model()
        tset  = model.tools()
        @tool_id = tset.active_tool_id()
        @first_activation = false
      # initialize()
      # Instance method called in the new instance itself, by the class
      #   constructor method, after it has instantiated the instance.
      # ! This method prototype must be included in any UI::Tool template.
      def initialize(*args)
        # NOTE: @tool_id will be set upon first activation.
        @tool_name  = "" # always English.
        @local_name = "" # name in localized language (optional.)
        @tool_state = 0  # can use @state instead, if so inclined.
        # Your additional initialization code here ...
      public
      # activate()
      # Callback: called by model.select_tool handler.
      def activate()
        # do not remove the following statement!
        first_activate if first_activation?
        # Add your activation code here ...
      # local_name()
      # Return the localized name of the tool.
      def local_name()
        @local_name
      end # def
      # tool_id()
      # Return the [Integer] tool_id of the tool.
      def tool_id()
        @tool_id
      end # def
      # tool_name()
      # Return the "Ruby" English name of the tool.
      def tool_name()
        @tool_name
      end # def
      # tool_state()
      # Return the [Integer] state of the tool.
      def tool_state()
        if defined?(@tool_state)
          @tool_state
        elsif defined?(@state)
          @state
        else
          return 0
      end # def
    end # class UI::Tool
    Last bumped by Dan Rathbun on Fri Dec 21, 2012 3:34 am.
      I'm not here much anymore. But a PM will fire email notifications.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Return to Skx Extension Library
