[code] alias Sketchup as SU
Moderator: Jim
Postby Dan Rathbun » Thu Jan 27, 2011 5:12 pm
(code) alias Sketchup as SU
Code: Select all
Object.const_set('SU',Sketchup)
Notes:
    Creates a global alias SU to refer to the Sketchup module.
Examples:
    model = SU.active_model
    SU.require('somefile.rbs')
SKX_alias_Sketchup_as_SU.rb
Can be added into the master skx.rb file.
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Re: [code] alias Sketchup as SU
    Postby thomthom » Thu Jan 27, 2011 5:15 pm
    Does Object.const_set('SU',Sketchup) have any advantage over SU == Sketchup ? Is it that it works regardless of the calling scope?
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Fri Dec 21, 2012 3:42 am
    thomthom wrote:Does Object.const_set('SU',Sketchup) have any advantage over SU == Sketchup ? Is it that it works regardless of the calling scope?
    Well first of all, you meant: SU = Sketchup
    It has no difference at the console, because you are already in the Object namespace.
    But to be precise, and to allow setting a global constant from ANY namespace, you need to call: Object.const_set('Name',object)
    You could call: Object.instance_eval("Name=object"), but that would be blurring what you are doing, just a bit.
    Better to use the const_set() method for readability.
    Last bumped by Dan Rathbun on Fri Dec 21, 2012 3:42 am.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Return to Skx Extension Library
