Forward compatibility?
Moderator: Jim
Postby thomthom » Wed Jun 24, 2009 3:20 pm
What if we implement missing methods that Google later wants to implement?
What if we fix bugs in a method that Google later fixes.
I'd think that Google's code would run faster than ours, but we'd rather not override that unless we have to.
So for new methods - we could add a little check routing before the method definition that checks for the existence of that method?
Not sure about bug fixing methods. If we do a version check we have to update the methods when a new version comes out whether it fixes the bug or not. If we leave it, we will have to update the methods that's been fixed.
Ideas? Thoughts?
PluginStore Author
PluginStore Author
Re: Forward compatibility?
Postby Dan Rathbun » Wed Oct 28, 2009 5:33 am
thomthom wrote:
"What if we implement missing methods that Google later wants to implement? ... I'd think that Google's code would run faster than ours, but we'd rather not override that unless we have to. ... So for new methods - we could add a little check routing before the method definition that checks for the existence of that method?"
Compiled C would always run faster than interpreted Ruby, I would think.
Code: Select all
# sample override code, assume a 'menu_wizard'
module ::Sketchup
if not defined? Sketchup.menu_wizard
  if Sketchup.version_number <= '7.1.4870'
    def self.menu_wizard
      .. { code goes here } ..
  else # different code for newer version of Sketchup
end # module
thomthom wrote:
"What if we fix bugs in a method that Google later fixes."
..and..
"Not sure about bug fixing methods. If we do a version check we have to update the methods when a new version comes out whether it fixes the bug or not. If we leave it, we will have to update the methods that's been fixed."
We would always need to check ANY method overrides (or mix-ins) when new versions of Sketchup or the SU ruby API are released. It would be nice if Google gave us a 'heads-up" before hand... we have a Google programmer as a SKX member so perhaps that may happen.
If we override ANY method, in ANY Google SU module... what we are doing is saying "this should be a part of the module in the future, and this override is only temporary until Google actually does add the features in a later release.
Afterall... those modules really "belong" or are "owned" by Google.
Some perfect examples:
NO "Sketchup.unregister_extension" method
Methods to set text on StatusBar, VCB_Label and VCB_Value, but NO methods to GET the actual text (assume the text was set by Sketchup itself, or another plugin,) if I want to do something, such as stuff a value for a Radius into the VCB, when the VCB Label says a certain string, I can't do it easily (I could write a API call sure, but this should have been part of the standard Sketchup module method set.) Yes there is a onToolStateChanged event, and can be used for SOME tools, but many tools don't report any ToolState numbers, and there is no commonality to the usage of ToolState numbers. (THERE SHOULD BE tho.. Google.. hint, hint!)
Alternative is to put new functionality in modules with a new name:
Code: Select all
module SU
  include Sketchup
  ... new methods ...
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Return to Skx Extension Library
