SketchUcation Plugin Store
[CityGen] Trying to use City_Gen.module_path
Moderator: Jim
Postby Chris Fullmer » Thu Jun 18, 2009 9:37 pm
I'm sure this is fundamental ruby 101 question and I'm being dense....so nothing new!
I want to make a variable with the path to the "building" folder (not in the program yet, its something I'm playing with). So I figured I could do this:
path = City_Gen.module_path
path.concat "/buildings"
But everytime I run that, it keeps adding another /buildings onto the end. So I get:
C:/Program Files/Google/Google SketchUp 7/Plugins/citygen/modules/buildings/buildings/buildings/buildings/buildings/buildings/buildings
I figure that each time I ran it, it would return the path, and so the concat would just add /buildings onto the end of the path. I wasn't expecting it to actually modify the @module_path variable.
So what would be the correct way to use City_Gen.module_path so I could append my buildings folder onto it, and not change the @module_path and mess up everything else that depends on that variable remaining constant.
User avatar
SketchUp Team
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Level of SketchUp: Advanced
Re: Trying to use City_Gen.module_path
Postby thomthom » Thu Jun 18, 2009 9:49 pm
hm... taht's odd.
I thought ruby made a copy when you used the =
What happens if you do: path = City_Gen.module_path + "/buildings" ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby Chris Fullmer » Thu Jun 18, 2009 9:52 pm
Ahh, yes that works. I so rarely work with strings, its like my mind turns to mush when I try. Thanks Thom!
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby tbd » Thu Jun 18, 2009 9:54 pm
Code: Select all
path = File.join(City_Gen.module_path,"buildings")
http://plugins.ro
User avatar
tbd
Postby thomthom » Thu Jun 18, 2009 9:57 pm
FYI; if you do a lot of string processing then you might want to use single quotes strings instead of double quoted string. Double quoted strings allows variables inside it and require more processing than single quoted. I'm not that familiar with the performance difference in Ruby, but it's the same in PHP. I've done quite a bit of PHP programming for making websites and then it's always string manipulations so I got into the habit for always using single quoted unless I need variables in my string.
The Su plugins there's usually not that much string processing going on, so I don't think it'll matter that much.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Jun 18, 2009 9:58 pm
TBD wrote:
Code: Select all
Ah. :)
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to City Generator
Who is online
