[Plugin] [CityGen] - Core [WIP] (0.1.3a) — 19 September 2009Moderator: Jim
• Page 2 of 4 • 1, 2, 3, 4
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009Hi Thom again.-
efectively, I use Skecthup 7 pro in a Dell Presicion M6400, 16 Gb ram and it crashes. The OS is Vista Ultimate 64bit. I think In use the last version I found, but I can't find the latest one you just uploaded as you wrote today. Please can you explain me where can I download the latest version? and if you know how can I solve these problems to use it? thanks jann
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009All downloads are located at the bottom of the first post in the thread.
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009Ok, I see, it seems every updates will be always at this site... I'll try again and tell you the result in a while.
thanks jann
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009Yea - public releases are posted here. The Google Code site is for developers that want to join the project.
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009any result pics?
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009The Core doesn't have any GUI - nor does it 'do' anything which the end user can see.
Check the modules for what they can do. So far I think it's just StreetGen available. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
Yeah, its a pretty killer app we've built so far! Chris
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009It's he thought that counts, ... right?
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009HI thom.-
Now it works perfectly. I found some incoveniences if you have instaled several plugins more at the same time: MODULOR, 1001bit and lightup you can't use CityGen, Sketchup crashed. Please review this post and check it. I'd tried for four days diferents combinations of configurations, and after all I'd put these plugins in another sketchup's instalation. Good jod and wait for news for this nice application. Jann
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009That's odd. Not sure why any of those would affect anything. Essentially make any difference between 0.4.x and 0.5.x.
Does any combination of these plugins crash - or is it with all of them? Personally I have 1001bit and Modulor - both of which works fine on my system. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009I seem it's a combination of these plugins, I don't know why, but I'd been all the weekend try con find the right combination and after all i opted to install Modulor in Skecthup 6 and now all works. I mean it's lightup which is the main problem, couse is just when is reading the protection or key from this plugin when sktchup crashed after install citygen.
maybe there must be developed some application to purge and depure all the plugins to be installed at the same time. best regards jann
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009hm... LightUp is the only app I don't have. I could try to install the trial - but I'm short of time this whole week. Maybe give Adam a prod and see what he says.
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009as of the 19-sep update, are you still using the google code repo? I noticed there were no updates when I tried to pull after the announcement.
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009This is from the repo. I just made an easy public download that was more up to date.
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009Bookmark...
Had a tough time trying to put the program in it. So, I'd look forward to updates.
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009Hi- This is an interesting project. Unfortunately I wasn't able to get all the files from both Core and Streetgen in the correct heirarchy in the plugins folder so I keep getting error messages. Is this a Mac problem?
![]() Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009Depends on how you extracted it. Macs tend to create an extra folder when extreating - the files you need would be inside the first one.
(note - this depend on how you extracted it.) Thomas Thomassen — SketchUp Monkey & Coding addict
Where can we find this plug "Modulor" ?
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009THX
It's not exactly the same name
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009no ... but it's hard to juggle them eoueoue's...
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009Does it possible with your plug to generate "streets" with no round Corners?
here 0.01 as corner radius (Why not 0 possible) 90° as Angle threshold PS Are you interested by a little French translation of your Plug's UI? Please, register (free) to access all the attachments on the forums.
Set Angle Threshold to 180 degrees (or more).
In the future, yes. But as it is now - this plugin is experimental and many things will change. (When I get around to work on it again.) Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009Not possible to average for have an angle more straight?
Because after there are some glitch when you make some functions with it Please, register (free) to access all the attachments on the forums.
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009In your last versions measures are not keeping from previous calculate in the dialog box
Re: [Plugin] CityGen - Core [WIP] (0.1.3a) — 19 September 2009As it is now - it does no error checking at all. But you're right - it's something that'd be nice if it did.
