Speed Modelling #38 - Fishing - Voting
Choose the one you like best.
Poll ended at Wed Apr 13, 2011 8:53 pm
SketchupNoobie
2%
Solo
7
11%
jbacus
3
5%
oganocali
10
16%
tpstigers
No votes
20
31%
Boofredlay
7
11%
KiraNL
No votes
rspierenburg
No votes
mukul.ar #1
2%
bupaje
No votes
qqq
3%
Rich O'Brien
3%
mukul.ar #2
5
8%
Fabiazz
6
9%
Total votes : 64
Postby boofredlay » Wed Apr 06, 2011 8:53 pm
Voting time for this challenge. Best of luck to all involved.
SketchupNoobie
Solo
jbacus
oganocali
tpstigers
Boofredlay
KiraNL
rspierenburg
mukul.ar #1
bupaje
qqq
Rich O'Brien
mukul.ar #2
Fabiazz
boofredlay
Global Moderator
Re: Speed Modelling #38 - Fishing - Voting
Postby Rich O Brien » Wed Apr 06, 2011 8:59 pm
Ooooooh, that's tough!
Rich O Brien
Administrator
Postby SketchUpNoobie » Wed Apr 06, 2011 9:12 pm
Wow! :shock: So many great entries. It was hard but I went with Box's submission. The modeling is great for 30 minutes and his presentation is awesome.
Which leads me to ask a question that I have been wondering for some time. I will use Box's entry as an example. If he modeled the net, rope, deck, and buoy components all in 30 minutes, could he then after the time arrange everything? (e.g. copy and rotate additional nets, rope, and buoys and placement of these as well as changing the style in SketchUp etc. to match the mood of his model.) I thought this is within the rules as nothing is said against it and he finished all the modeling within the limit. If someone could clear this up, that would be great.
Note: I am not saying Box went over the time limit. I was just using his fine entry as an example. ;)
Last edited by SketchUpNoobie on Wed Apr 06, 2011 9:17 pm, edited 1 time in total.
SketchUpNoobie: the complete noob in all things SketchUp.
SketchUpNoobie
Postby boofredlay » Wed Apr 06, 2011 9:17 pm
No and I guess we can be more clear in the coming competitions.
Start to finish, 30 min.
boofredlay
Global Moderator
Postby SketchUpNoobie » Wed Apr 06, 2011 9:19 pm
Ooh, okay. Thanks for clearing that up. :)
That makes his model even more awesome then. :D
SketchUpNoobie
Postby SketchUpNoobie » Wed Apr 06, 2011 9:21 pm
The screenshots can be taken after the 30 minutes though, right? :?
SketchUpNoobie
Postby boofredlay » Wed Apr 06, 2011 9:26 pm
Sure, just no more modeling or tweaking.
boofredlay
Global Moderator
Postby SketchUpNoobie » Wed Apr 06, 2011 9:29 pm
Gotcha. Thanks.
SketchUpNoobie
Postby mukul.ar » Wed Apr 06, 2011 9:50 pm
Eric or Oganocali its got to be..! Really innovative techniques employed by both of you..:)
mukul.ar
Postby modelhead » Fri Apr 08, 2011 2:04 am
So much fun to watch this....always. I'm lodging a formal protest! The challenge has evolved to a level that requires more than one vote. I cannot honestly enjoy voting for one anymore. I cannot refuse a vote for any of the top three here.
I know...I know, your forums php template only allows one vote per user ...right?...ok :| ...I'll vote anyway.
modelhead
Postby KiraNL » Fri Apr 08, 2011 9:24 am
Boofredlay wrote:Any chance you had time to upload the vid of your mechanical fish yet? :berserk:
KiraNL
Postby Gaieus » Fri Apr 08, 2011 11:46 am
modelhead wrote:...I know, your forums php template only allows one vote per user ...right?...
Actually, it could be more - it has just never been a practice.
Maybe we could re-consider this (also maybe according to the number of submissions, something like "up to 5 submissions, 1 vote, between 6 and 10, 2 votes" etc. This would not mean "weighing" between these two, cast votes however. It would mean "these to are my favourite".
In such a case, it should always be made very clear in the voting announcement however that "you can cast two votes, three votes..." etc.
Postby modelhead » Fri Apr 08, 2011 11:52 am
I think it is time now. Once upon a time when we were all getting the hang of this often a single entry would stick out. But not anymore. There are at least 3 or 4 entries that are always neck and neck. I would personally have more fun with it if I could extend my pondering.
modelhead
Postby boofredlay » Fri Apr 08, 2011 12:23 pm
After the comp. I don't want to sway any votes although I think Box is taking this one ;)
boofredlay
Global Moderator
Postby boofredlay » Fri Apr 08, 2011 12:24 pm
I think we just might look into this. Thanks.
boofredlay
Global Moderator
Postby Rich O Brien » Fri Apr 08, 2011 12:46 pm
I think you can set to number of votes for polls but not quite sure?
Rich O Brien
Administrator
Postby david_h » Fri Apr 08, 2011 3:13 pm
Those were mine. :mrgreen:
If I make it look easy. . .then it probably is.
david_h
Top SketchUcator
Postby modelhead » Sat Apr 09, 2011 2:09 pm
Those were mine.
Sorry! I forgot to mention that. :D
modelhead
Postby Box » Sat Apr 09, 2011 7:43 pm
See what happens David when you don't submit an entry, everyone gets confused and just votes randomly. :shock:
Thanks for the votes so far but it should be noted that the actual modelling in mine is rather basic, there is a lot more skill involved in many of the other entries. Oganocali's knot, for one, is a masterwork of line placement.
Postby Rich O Brien » Sat Apr 09, 2011 8:06 pm
This competition isn't over yet!
I'm slowly catching..... :roll:
Rich O Brien
Administrator
Postby SketchUpNoobie » Thu Apr 14, 2011 2:54 am
Uh, oh. Box must wear the purple box of shame. :( Better luck next time buddy. On the bright(ish) side, what will the next challenge be? ;)
SketchUpNoobie
Postby Rich O Brien » Thu Apr 14, 2011 8:27 am
Well done guys. Good challenge :thumb:
So Box what'll be the next challenge?
Rich O Brien
Administrator
Postby Box » Thu Apr 14, 2011 8:32 am
I had two ideas for the next one.
Sort of following on in theme from the last, Camping. That gives quite a broad range of options.
Or something a little different. Meccano. I thought that would be interesting because you are virtual modelling with a modelling tool.
I have created a small beginner set that people could download so everyone starts at the same point rather than spending all the time just making the pieces.
You can use the basics I have made then add to them however you want.
I can attach my Meccano set here later today and let you guys decide, I'll be heading off into the North sea for a few days this afternoon, so I won't have much connection.
Let me know what you think.
Postby Gaieus » Thu Apr 14, 2011 8:37 am
I had to look up what meccano is... Then I realised I had something similar when I was a kid. I really enjoyed that toy
(We did not have Lego in the 60's-70's for instance but later I enjoyed that, too).
Postby Box » Thu Apr 14, 2011 8:41 am
Yep, sorry about that, showing my age again.
A quick google for you youngns will explain it. Many hours of fun and the start of many an engineers career.
Postby Rich O Brien » Thu Apr 14, 2011 9:01 am
I like camping :thumb:
Rich O Brien
Administrator
Postby KarinaGM » Thu Apr 14, 2011 9:09 am
I like camping too :D
"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
-Benjamín Franklin.
KarinaGM
Postby Box » Thu Apr 14, 2011 10:30 am
Camping is probably a good idea, the meccano may be too restricting, but I'll attach it here in case it's of interest.
Postby oganocali » Thu Apr 14, 2011 1:43 pm
Congrats Box, and thanks for your comments. I like the camping idea better too.
oganocali
Postby Gaieus » Thu Apr 14, 2011 2:08 pm
Congrats, Box - I have now changed your colour to that ugly purple.
Also, no hurry with the next challenge idea (you have 5 more minutes so take your time)
Next
Return to Competitions
