New to DC: topic for my simple questions to the pros
Re: New to DC: topic for my simple questions to the pros
Postby pibuz » Wed Sep 11, 2019 11:47 am
Hi again! I want to have to possibility to have the Definition Name of a DC to be displayed in the Options Dialog, so that if I rename a DC I have its correct name on the dialog. Is that possible?
pibuz
Postby pcmoor » Wed Sep 11, 2019 12:27 pm
The components instance name is already tied to both the attribute and option dialog, this can be updated on the fly. This works if you do not use the name attribute and only after loading the component.
Otherwise the component definition name can be accessed via a ruby script and placed into an attribute value.
pcmoor
Postby pibuz » Wed Sep 11, 2019 2:30 pm
Thanks! And what would this ruby script be?
pibuz
Postby pcmoor » Wed Sep 11, 2019 11:09 pm
see the link to topic
viewtopic.php?f=289&t=71346
pcmoor
Postby pibuz » Fri Sep 13, 2019 9:31 am
thanks Moor!
Sorry, but maybe I misexplained what I need, I'm attaching an example.
In this case I'd like that if I rename the component to whatever else, I get the new name in the Option dialog title. At the moment, this wont' happen: it keeps titling "elemento da prelevare_shell".
pibuz
Postby pcmoor » Fri Sep 13, 2019 1:11 pm
you can use the component instance name to give each instance an unique name which is reflected in all the dialog, which is the natural inbuilt way
otherwise set
Name = _name
in the DC then
use a button from the toolbar extension to fire the code snippet to alter the _name attribute, which reads the current definition name, updates the original name to update the option dialog
pcmoor
Postby pibuz » Fri Sep 13, 2019 1:31 pm
Sorry Moor, I don't understand. In the file I sent you, if I change the Instance name of "elemento da prelevare_shell" NOTHNG CHANGES in any window...
pibuz
Postby pcmoor » Fri Sep 13, 2019 1:52 pm
saveas the DC to a folder then bring it into another file, for some reason it does not initially work within its created file, after that, should work, regardless of the number of changes, the references are still maintained
pcmoor
Postby pibuz » Fri Sep 13, 2019 1:54 pm
OH BIG THANKS! I WAS MISSING THE FACT THAT IT DOESN'T WOTK ON THE ORIGINAL FILE!
pibuz
Postby pibuz » Fri Sep 20, 2019 11:20 am
Hi again! is there a way I can LOCK the rotation of a DC along specific axis'?
I have a panel which I don't want users to be able to use as ceiling, so I only want it to be rotateable along its blue axis
pibuz
Postby pibuz » Wed Apr 01, 2020 5:39 pm
It's me again!
I'm struggling since a couple days about one thing I think should be doable but I can't get in any way
to work in my DC.
Basically I have a wall, made of two side pillars and a series of panels in the middle. My wall can be stretched to match some precise measures, which I set. The measures are exact multiples of the panels but may also admit an half-panel on the end, if needed.
When I stretch the wall, the start pillar must stay still (works now), the end pillar must reach the final point (works now) and in the middle I want the panel to copy a number of times. It works when I fix the length of the panels to a value, but I'm not able to tell SketchUp that it must stretch the last panel to half its dimension if needed.
Do you guys know a way to do that? Thanks in advance!!!
pibuz
Postby pcmoor » Thu Apr 02, 2020 12:52 am
To work out the number divide the opening by the whole door size and convert to integer
To get the remainder take this number times the size from opening
For door lenx, use condition if remainder then the last copy (= copies) is to be remainder
There were some issues with the geometry and scaling, first applied lenX to two faces, then had to make a group of the edges so that it obeyed the formula rather than its natural scale
made outline to size to opening, added some copy function to the support
pcmoor
Postby pibuz » Thu Apr 02, 2020 7:39 am
Thanks a lot pc!!! I'll have a look at it immediately!
*EDIT*
Everything is clear, I don't understand the syntax of these two formulas though:
=parete Arty!d_mod_num-1 +if(parete Arty!remain,1,0)
Here I don't understand the space between "-1" and "+if" and I don't know the meaning of the "parete Arty!remain" without any checks to perform.
=if(and(parete Arty!remain,copy=copies),parete Arty!remain,98)
Here I don't understand the meaning of "parete Arty!remain" without any checks: what will it solve into?
MANY MANY THANKS!
pibuz
Postby pcmoor » Thu Apr 02, 2020 8:55 am
The condition is either true or false, 0 or any negative number is read as false whereas any positive number is true.
A bit of a short cut in logic.
The space is not required for mathematical functions, just there for my own readability
pcmoor
Postby pibuz » Thu Apr 09, 2020 2:19 pm
I have a new question for the community: I have an attribute which ALWAYS include alternatively the words "OPACO" "LUCIDO" or "SEMILUCIDO" (name of the material applied). The words are always at the end of the text string, but the number of digits before may change.
I want another attribute to report ONLY the occuring word from case to case.
EG: my material attribute returns "grey RAL7040 OPACO", I want another attribute to report only "OPACO".
Is there a way to do this?
pibuz
Postby kostiaarh » Thu Apr 09, 2020 9:03 pm
pibuz wrote:I have a new question for the community: I have an attribute which ALWAYS include alternatively the words "OPACO" "LUCIDO" or "SEMILUCIDO" (name of the material applied). The words are always at the end of the text string, but the number of digits before may change.
try so: =RIGHT(Material, 5)
kostiaarh
Postby pibuz » Thu Apr 09, 2020 9:09 pm
Thanks Kostiaarh!
Sadly this formula returns always the last 5 characters, while the number of letters I have to report varies from 5, 6 and 10 digits.
pibuz
Postby pcmoor » Thu Apr 09, 2020 11:21 pm
You can use find with the item to be found included in the text to avoid the error , and test if the result is within the length of the original text
Note that semi is placed before in the conditional statements otherwise will not be selected
pcmoor
Postby pibuz » Fri Apr 10, 2020 4:40 pm
wonderful! Thanks!!
pibuz
Previous
Return to Dynamic Components
