Set Component Options Window Height above 760  Topic is solved
Postby Pete » Fri Apr 26, 2013 4:02 pm
Anyone out there know of a way to make the component options window taller than 760 pixels? I am trying to fill all the vertical space above the windows task bar. I have tried setting the dialog height to 1336 pixels but the window will not expand to that height. I can drag the window border to that dimension but it will snap back to 760 when the options in the window change.
I have a AOC e1649fwu second monitor in portrait mode. This would be a great setup for components with many options if I can get the component options window to stay tall.
Demonstration:
Pete
Re: Set Component Options Window Height above 760  Topic is solved
Postby Pete » Sun Apr 28, 2013 5:04 pm
Solved!!
CadFather (http://sketchucation.com/forums/memberlist.php?mode=viewprofile&u=378) has provided a solution that works well for anyone using MS Windows. A program called winsize2: http://sourceforge.net/projects/winsize2/
This program works on any window not just the options window. It's great for people with laptops and second screens because it can save different configs for different resolutions.
Pete
Return to Dynamic Components
