SketchUcation Plugin Store
Rotating handle then opening door
Postby imadamjad » Tue Jul 03, 2012 1:31 pm
Hello,
I am pretty much a noob at DCs, I was wondering how you would rotate a door handle, say 45 degrees and THEN have the door open 90 degrees. I have my door setup with handle rotating but i need to door and handle to rotate as if you are opening it realistically. Hopefully not too difficult to do.
imadamjad
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Re: Rotating handle then opening door
Postby Jim » Sat Jul 07, 2012 12:00 am
In SketchUp Components, search for "non concurrent" for my example.
(http://sketchup.google.com/3dwarehouse/ ... e0d18c3e5e)
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby imadamjad » Sat Jul 07, 2012 6:09 pm
Thank You for your reply however how do you get your model to work/animate.
imadamjad
SketchUp version: 8
License type: Pro
Postby Jim » Sat Jul 07, 2012 8:44 pm
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby imadamjad » Sat Jul 07, 2012 10:41 pm
Thank You, it now works, the only thing I did differently was download it from 3d warehouse from a browser not directly inside sketchup, that is why it was not dynamically interactive.
Again thanks for the help.
imadamjad
SketchUp version: 8
License type: Pro
Postby Jim » Sun Jul 08, 2012 1:19 am
Right, this model was intended to be imported into a model. If the model was downloaded, use File > Import to add the component to the model.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Return to Dynamic Components
