SketchUcation Premium Membership
Need help  Topic is solved
Need help
Postby Epix3d » Fri Jan 27, 2012 3:48 pm
Hello,
I am a rookie when it comes to dynamic Components. Attached is a model of an archive system which copies when scaled. My problem is how to make an end to the archive which doesn´t copy in between the two ends. I also have a problem with the back cross which I would like to copy only every second copy. Another problem is I cannot scale to make 3 copies, only 4 and more.
Can anybody help me/show me how to do it?
Arkiv_grunnfag-D300mm.skp
Epix3d
Re: Need help
Postby DareDevil » Fri Jan 27, 2012 5:44 pm
Here a solution (not THE only solution ;) ).
The end must be an unique element positioned at (Copies+1)*ModuleXLength.
The cross must be outside of the module and the number of copies must be the half of the Module copies and positioned at 2*copy*ModuleXLength. You can also let the cross in the module and define the visibility on odd number of module copy.
DareDevil
Re: Need help
Postby Epix3d » Fri Jan 27, 2012 10:30 pm
daredevil wrote:Here a solution (not THE only solution ;) ).
Thank you DD
Looks fine except I want the right end on row to be rotated 180 degrees with end cap on top. The cross seems out of dimension and when I try to modify to original strange things happen...??
Tried to copy your solution without sucsess. Must have missed something.
Epix3d
Re: Need help
Postby DareDevil » Fri Jan 27, 2012 10:56 pm
Epix3d wrote:Looks fine except I want the right end on row to be rotated 180 degrees with end cap on top.
Just add "+2.5" at the Stige's X and a RotZ = 180. You can ajust manualy the Y position or on the Y if you know the size.
You must define the LenX of each Arkiv sub-component cause if you don't, you resize the sub-component when you resize the Arkiv. I don't know the right size of the cross, so I put the same size than Hyllesystem ; you can change with the right value. You can add a little offset to the Croos X value to put it on the right position.
DareDevil
Re: Need help  Topic is solved
Postby Epix3d » Sun Jan 29, 2012 4:08 pm
Thank you again DD. It works fine now :D
I learned a lot from this. I am testing to make a menu system. I guess there will be problems if I wanted to implement another choice of depth of shelves and endwalls(Stige) into this model due to the holes..?
Epix3d
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Return to Dynamic Components
