I'm trying to model very large wind farms that have been proposed for my area in Michigan. This means putting hundreds of wind turbines over dozens of square miles, a reletively easy job to do in Sketchup but...
If the models are put in Google Earth via the Sketchup "Place" function they export fast, navigation is reletively smooth and the kmz created by google earth is small--BUT the turbines float in the air and google earth clamping option, under properties, doesn't help.
If the model is exported directly from sketchup to a kmz file the file size is huge, the navigation is slow and often the export to kmz simply doesn't work, but the models are all clamped to the earth.
Does anyone here know how to get the good navigation and small file size by exporting via the Place function and have all the models clamped to the surface as they are when the kmz is created by the export function in sketchup?
Thanks in advance for any assistance.
Charlie
P.S. Here are some screen captures of what i'm trying to do. When there is good navigation with all the windmills clamped to the earth I'll make kmz files available to the local community so they can explore and see what is coming.
http://www.thumbpower.net/wind%20farm%20resort.htm
