SketchUcation Plugin Store
Spatial Error and Correct Georeferencing
Postby geochallenger » Wed Jul 16, 2008 3:20 am
Fellow SketchUp Users,
I have been working with GIS for a few years and have been working with SketchUp for a few months now. I have been able to follow the processes posted here as well as a few online and get building footprints and point shapefiles into SketchUp with success. I have however encountered a few problems and have some questions.
I did a project for Fat City in Jefferson Parish LA in which I easily imported the building footprint and then extruded the buildings to their correct height based on the Height in the attribute table. Was impressed with how much detail and the imaging abilities in SketchUp but my problem came when I tried to import the model into google earth. The entire model was placed within the correct region, but was orientated nearly 80 degrees clockwise from its true location. I messed with a few projections and tried to manipulate the model but still haven't been able to place the model completely accurate with the google earth image. Any thoughts about Google Earth Projections, Model Placement or potential error?
My second problem that I have encountered is with elevation. The project is in the Galisteo Basin just south of Santa Fe NM. The area is fairly extensive and has a considerable amount of deviation in topography. What is the best way to drape the buildings onto the correct elevation. In google earth, some of the buildings are embedded into the terrain, while some are hanging above the terrain. I worked to try and create a field in the attributes that gave the building base height with little success. I also tried to import a tin along with the building footprint but the tin was drawn several hundred feet above the buildings.
Any thoughts on where an am going wrong with this project would be greatly appreciated!
geochallenger
Re: Spatial Error and Correct Georeferencing
Postby modelhead » Thu Jul 17, 2008 5:46 pm
Just a test for you:
Build yourself a cube and put a mark (image) on one side. Go to any GE location and "get the current view. Place your block on the GE view in SU. Rember how it is oriented. Now "place the model". If the model is not now placed in the correct location then either GE or SU are not behaving properly.
You must turn on terrain of course and plant your building in the ground. The parts that are hanging in mid air need to have a mount built under them to be placed on GE within the model. The parts that are burried will just have to stay burried as GE does not let you break ground. The alternateive is to build a complete base for the model using proper contours and lay it above the GE surface planted into the ground.
Cheers!!
modelhead
Postby Howard Leslie » Mon Jul 21, 2008 10:56 am
Hello,
You may find this quick tutorial useful:
viewtopic.php?f=18&t=11436
Regards
Howard L'
Howard Leslie
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Level of SketchUp: Advanced
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Return to Google Earth
