A Moxon-Style Vise
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
A Moxon-Style Vise
Postby Dave R » Mon Jun 10, 2019 7:20 pm
This is a model I did for plans for this vise designed by a woodworker in North Carolina. Fairly simple build and cheap. Other than the wood for the chops, there's less than $20 in parts.
It is clamped to the workbench so it can be put away when not needed.
Global Moderator
Re: A Moxon-Style Vise
Postby tuna1957 » Mon Jun 10, 2019 11:39 pm
Great job ! :thumb:
tuna1957
Premium Member
Premium Member
Postby baz » Tue Jun 11, 2019 1:36 am
Hi Dave. I have been thinking of making one of these.
The function of the track on the front chop is not obvious to me.
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Postby Dave R » Tue Jun 11, 2019 1:40 am
baz wrote:The function of the track on the front chop is not obvious to me.
It's a secret. :D
Actually, it is used for a couple of hold down clamps. The fellow who designed it uses one to hold a saddle square (he made a wooden one for it today) and another hold down holds the tail board in place while making out the pins. He's been making and using this sort of vise for many years and he says the hold down clamps are really useful.
Global Moderator
Postby baz » Tue Jun 11, 2019 2:08 am
Ah, I see. This style I presume?
baz
Postby Dave R » Tue Jun 11, 2019 2:42 am
Yes. Exactly.
Global Moderator
Postby baz » Tue Jun 11, 2019 10:21 am
/quote] Actually, it is used for a couple of hold down clamps. The fellow who designed it uses one to hold a saddle square (he made a wooden one for it today) a.[/quote] Whoops, broke the code:)
Did he make a saddle square for his Moxin. Or a wooden hold down?
Might have to ask him for a pic?
No hurry.
baz
Postby Dave R » Tue Jun 11, 2019 12:53 pm
He made a wooden saddle square. Here is a picture showing the one he made just glued up and clamped in his vise. Previously he used a Veritas saddle square.
Global Moderator
Postby jtri » Tue Jun 11, 2019 1:03 pm
Adding a square can really speeds things up when setting up to transferring marks. That is an idea I had thought about incorporating into the vice, but I had not done it yet. The hold downs are even a better idea! Thanks to both of you for sharing the tips.
jtri
Postby Dave R » Tue Jun 11, 2019 1:21 pm
I like the idea of keeping the square as a separate thing. You can place it where you want it in the vise and with my luck, a permanently attached thing would just be in the way. Wish I could take credit for the idea but I'm only the messenger.
Global Moderator
Postby Dave R » Mon Aug 12, 2019 3:04 pm
Here''s another vise designed and built by the fellow who did the Moxon-style vise. This one can be clamped to a bench or counter or table when needed.
Modeled for plans like the Moxon.
Interesting thing. Both of these use dumbbell handles for the screws. You can buy a screw with two knobs for less than $7 US.
Global Moderator
Postby Joe Wood » Mon Aug 12, 2019 4:19 pm
Dave you did a great job lining up the edge and face textures
Joe Wood
Postby Dave R » Mon Aug 12, 2019 4:30 pm
Thanks Joe. It's not so hard with a proper texture to work with.
Global Moderator
Postby baz » Tue Aug 13, 2019 12:46 pm
Joe Wood wrote:Dave you did a great job lining up the edge and face textures
So he did, well spotted Joe. The short grain on the handle is a bit of a worry tho' :)
baz
Postby Dave R » Tue Aug 13, 2019 12:55 pm
baz wrote:The short grain on the handle is a bit of a worry tho' :)
It's tough and stringy elm. :D
I only made it the way the the old head who built it did. It's made out of scrap wood he had around. He probably has more.
Global Moderator
Postby jtri » Tue Aug 13, 2019 1:30 pm
That would be a handy vice, thanks for sharing. Used some elm on a project and never again. That stuff moves way too much!
jtri
Postby Dave R » Tue Aug 13, 2019 1:39 pm
I wouldn't use elm either. I just made that up. I think he used pine or something else that is easier to work.
I don't think elm is good for much. My father told me that before I came along, he and my mother lived on the second floor in an old Victorian style house that had been divided up into apartments. He was given some elm to burn in the fireplace. He said he'd burn the same log for three or four nights. When they were ready to go to sleep he would put on asbestos gloves, grab the log and throw it out the window into the snow. In the morning he would go collect it and bring it in so it would dry out. He said it didn't give off much heat, either.
Global Moderator
Postby baz » Tue Aug 13, 2019 2:40 pm
You are both right about Elm, nasty and unpredictable to work with and tough as old boots. It rewards you in the end but its a battle. I used it in Pommieland many years ago.
Of course, now, Dutch Elm disease ruining city landscapes.
And funnily enuf: on the news tonite, A lady walking down one of our leafy Melbourne boulevards today, got fatally crushed by a hundred year old healthy Elm. (Theres more to this).
Is this a Hijack? Never sure.
Anyway, I love the portable Leg Vise. I want one. Suits my lifestle. But goes on the project list about 90 down.
And the story, Dave, sounds intriguing. The 'Old head'. More please.
baz
Postby Dave R » Tue Aug 13, 2019 2:58 pm
I don't know much more about the "old head". He's a member of one of the woodworking forums I participate on and he seems to have a vice for shop made vises. The screw is typically the most expensive part but he came up with the idea of using these cheap dumbbell handles which work quite well. He also buys inexpensive HDPE cutting boards to use for the bearings, shown in white. Another cool trick that he does is to drill and tap the ends of the brass pins so a small machine screw can be inserted to use as a handle to extract the pin if he wants to disassemble the thing.
Global Moderator
Postby baz » Tue Aug 13, 2019 4:16 pm
Dave R wrote:I don't know much more about the "old head". He's a member of one of the woodworking forums I participate on and he seems to have a vice for shop made vises. The screw is typically the most expensive part but he came up with the idea of using these cheap dumbbell handles which work quite well. He also buys inexpensive HDPE cutting boards to use for the bearings, shown in white. Another cool trick that he does is to drill and tap the ends of the brass pins so a small machine screw can be inserted to use as a handle to extract the pin if he wants to disassemble the thing.
Great stuff, are you able to share the model?
If so I might adapt it for metric and me, and share of course. Although I s'pose I could do it the hard way....:(
baz
Postby Dave R » Tue Aug 13, 2019 4:28 pm
Unfortunately I'm not at liberty to share the model.
Global Moderator
Postby baz » Tue Aug 13, 2019 4:33 pm
Dave R wrote:Unfortunately I'm not at liberty to share the model.
No worries, thought that might be the case.
baz
Postby Dave R » Sun Sep 01, 2019 4:45 pm
Here's a work in progress shot of another Moxon-inspired vise. This one is considerably more expensive to build, though. The screws are Acme left-hand threaded rods that have been turned down over a good part of their length. The left hand threading allows the chop to be moved in when turning the handwheel clockwise. The main body of the vise has sides dovetailed into the front piece. Just waiting on some dimensions for those bits.
Here's a view from earlier when I was working out the order of the round bits that go on the shafts.
Global Moderator
Postby Dave R » Mon Sep 02, 2019 4:13 pm
4
Global Moderator
Postby baz » Mon Sep 02, 2019 11:35 pm
Fab drawing, love the combination of solid line and x-ray. (Now to figure out how you did it :)
baz
Postby jtri » Tue Sep 03, 2019 12:44 am
Great drawing thanks for sharing! That is an ambitious project (drawing and fabrication) for sure. What is the inspiration for this vice or is it a copy?
jtri
Postby Dave R » Tue Sep 03, 2019 1:13 am
Thank you, gentlemen.
baz, I'll be interested to see what youcome up with for that. ;)
jtri, this latest vise is from a design by a woodworker on one of the woodworking fora that I am a member of. Interesting point: He used solid counter top material to make threaded inserts for the chop so it moves in and out with the turn of the hand wheel.
Global Moderator
Postby jtri » Tue Sep 03, 2019 2:01 pm
I have used "corian" for many things other than counter tops but not as a nut! Your texture should have told me what the material was. Is there a metal insert in the nut or are the threads to be cut into the "corian"? I need a small metal lathe to cut threads and turn some parts. Now to convince the wife...........
jtri
Postby Dave R » Tue Sep 03, 2019 2:07 pm
The guy who designed and built this vise said he threaded the Corain. He also said it was "not an easy task, but time and patience win out." He made a tap out of a piece of the threaded rod. He tapered the end and cut groves down the length.
A metal lathe would certainly be a nice addition to your shop.
Global Moderator
Postby Dave R » Wed Sep 04, 2019 9:46 pm
I think this is the final of my part in this latest Moxon vise deal.
3
Global Moderator
Next
Return to Woodworking
