SketchUp Guide for Woodworkers: Advanced Techniques
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
Re: SketchUp Guide for Woodworkers: Advanced Techniques
Postby Dave R » Sat Dec 30, 2017 1:43 am
Andy, I sent you a PM.
Global Moderator
Postby lockha » Mon Jan 01, 2018 12:36 am
Argh!!!
Made the box. Cut the dovetails.
Marked the curve and made the cutter oversize.
Copy to clipboard. Delete the cutter.
Hide the ends (didn't bother to rotate but I've done it.)
Open a side for editing. Edit-> Paste in Place. Everything now within Edit box.
Edit-> Intersect faces with Selection
"No intersections found between selection set
and the rest of the model"
Tried again- same thing
Probably a simple answer- usually is
lockha
Postby Dave R » Mon Jan 01, 2018 12:53 am
Did you make the cutter a component before copying it to the clipboard? Why did you delete the cutter after copying it?
Global Moderator
Postby lockha » Mon Jan 01, 2018 7:00 pm
No, it's not a component.
I deleted the cutter after copying it so I could open the side for editing and then paste the cutter back in place.
Was that the wrong way?
lockha
Postby Dave R » Mon Jan 01, 2018 7:10 pm
lockha wrote:No, it's not a component.
Well, there's no need to delete it after copying it. Just open the side component for editing and use Paste in Place. If you tick the Hide boxes in Model Info>Components, the original cutter geometry won't be visible when you are editing the component.
Global Moderator
Postby lockha » Thu Jan 04, 2018 9:54 pm
Dave-
I seem to have it working, appreciate your assistance.
We talked about the change from SU Make to SU Free- if I heard you correctly, you said that Make would be continued on offer, but not updated after 2017- did I hear you correctly? Because when I go onto SU.com, I don't see any reference to Make anywhere. Could you clarify? thanx
lockha
Postby Dave R » Thu Jan 04, 2018 10:15 pm
You did hear that right. SketchUp 2017 Make will continue to be available for hobbyist use from SketchUp.com/download/all. Of course anyone using SketchUp in their business will need to use SketchUp Pro and should probably be using SketchUp 2018 Pro at this point.
Global Moderator
Postby lockha » Fri Jan 05, 2018 4:07 pm
Thanks I'll try that
lockha
Postby lockha » Fri Jan 05, 2018 4:09 pm
Is it correct that one takes the Pro trial and then after 30 days can licence Make?
lockha
Postby Dave R » Fri Jan 05, 2018 5:16 pm
lockha wrote:Is it correct that one takes the Pro trial and then after 30 days can licence Make?
There is no Make 2018 version. If you install SketchUp 2018 Pro, you'll get a 30 Day trial period. If you choose not to purchase the license, it will be dead in the water after the trial period expires.
Global Moderator
Postby lockha » Fri Jan 05, 2018 6:18 pm
Forgot to put the second / in- now all is good.
lockha
Postby Khai » Sun Mar 17, 2019 3:14 pm
heads up for you, the book is not available in the UK or Europe... went to have a look at the price and got :
"Unfortunately we are unable to fulfill your request at this time. Due to GDPR (General Data Protection Regulation) requirements we are unable to support our European Union market through our online store. We apologize for the inconvenience that this may cause and we would be happy to assist you with your print subscription or product purchases as needed. Please contact Customer Service at 515-247-2990. Thank you."
Khai
Postby Dave R » Sun Mar 17, 2019 4:02 pm
Thanks for that. It looks like GDPR affects all of their digital offerings. Unfortunately it's not something I have any control over.
Global Moderator
Previous
Return to Woodworking
Users browsing this forum: No registered users and 5 guests
