SketchUcation Plugin Store
Sketchup CNC
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
Re: Sketchup CNC
Postby Dave R » Mon May 07, 2012 10:37 am
Nice icon. I think I'd make the background white. Transparent would be good, too. And make the cherry material lighter so it reads better when tiny.
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Re: Sketchup CNC
Postby noelwarr » Mon May 07, 2012 12:13 pm
I'm just glad to have something to use! :D Anything is better than the blank icons I am currently using. Scott's doing a fine job.
noelwarr
Re: Sketchup CNC
Postby noelwarr » Mon May 07, 2012 1:59 pm
ANNOUCEMENT:
The project's first tutorial/screencast. Here is hoping it gives you some idea of what the plugin does.
https://plus.google.com/u/0/106243199685455140135/posts/9xCjXqFJkug
noelwarr
Re: Sketchup CNC
Postby Scott M » Tue May 08, 2012 11:59 am
Noel I loaded the plugin and followed the steps but when I wright the G code I get the following error in the ruby console.
Error: #<Errno::ENOENT: No such file or directory - c:\Users\Noel\CNC>
C:/Program Files/Google/Google SketchUp 8/Plugins/postprocessor.rb:181:in `chdir'
C:/Program Files/Google/Google SketchUp 8/Plugins/postprocessor.rb:181:in `make'
C:/Program Files/Google/Google SketchUp 8/Plugins/minivistii/ui.rb:250
C:/Program Files/Google/Google SketchUp 8/Plugins/postprocessor.rb:181:in `call'
Scott M
Re: Sketchup CNC
Postby noelwarr » Tue May 08, 2012 12:07 pm
Mmm... Indeed you would get that error. At the moment the plugin is only really usable by people who are comfortable editing some ruby. postprocessor.rb is trying to save the CNC files to my directory ("c:\Users\Noel\CNC"). If you want to give it a shot, scan through the file. You should be able to spot the paths. Look for the double slashes (Mac unfriendly as Tim pointed out).
I'm working on making it all MUCH easier to edit. Keep you posted.
noelwarr
Re: Sketchup CNC
Postby Scott M » Tue May 08, 2012 10:58 pm
Just curious but would it be more user friendly for the user to draw the tool paths on the work piece then select that geometry and select the tool path button then have a pop up info box for them to set the tool info such as cut diameter cut depth feed speed rpms and maybe a max plunge for that tool as well as the other info you have set up (cut direction,compin,compout,or centerline.)That way the user would not have to move the geometry into the work piece out of view. If the geometry is a circle they would select the drill button and do the same process. And if the geometry is on the back side of the work piece then all of those tool paths would be back operations. Not trying to redesign your plugin just brainstorming. Another thought is to have some sort of database to setup the tools for the toolbox so the user could just select the toolbox button and enter the tool geometry as well as feed speed plunge rate etc. for that tool. See The attached file hopes this explains it better
Scott M
Re: Sketchup CNC
Postby Scott M » Tue May 08, 2012 11:44 pm
By the way I am taking Dave's advise after seeing your post I think I can come up with someting better. That one looks like a tooth pick jabbed into a board
Scott M
Re: Sketchup CNC
Postby noelwarr » Wed May 09, 2012 8:07 am
:D Don't be so hard on yourself. I'm just glad to have your help. Just one thing... If you are going to edit it please don't make the background white. Use the same grey as the rest of the sketchup icons otherwise it'll look out of place.
noelwarr
Re: Sketchup CNC
Postby Dave R » Wed May 09, 2012 12:09 pm
FWIW, the other toolbar icons have a transparent background, not grey.
Global Moderator
SketchUp version: 8
License type: Pro
Re: Sketchup CNC
Postby noelwarr » Wed May 09, 2012 6:12 pm
I thought png didn't do transparency... my bad. I've always found transparency tricky to work with, though if the other icons have transparent backgrounds it would clearly be the most correct. Imagine if SU9 changed its colour theme to green :mrgreen: Our buttons would be the only grey ones. How dire that would be
noelwarr
Re: Sketchup CNC
Postby Scott M » Thu May 10, 2012 12:17 am
Noel here are some icons please tell me what you think and maybe Dave will approve also
Scott M
Re: Sketchup CNC
Postby noelwarr » Thu May 10, 2012 7:36 am
The colours came as a bit of a shock but after a few seconds I warmed to them. I love the retro feel, ESPECIALLY the 5 1/4 inch floppy. What a pleasant surprise! First time I've seen Sketchup used for 2D too
noelwarr
Re: Sketchup CNC
Postby noelwarr » Thu May 10, 2012 10:40 am
Looking good AND retro!
noelwarr
Re: Sketchup CNC
Postby noelwarr » Thu May 10, 2012 4:35 pm
My head's about to explode.
noelwarr
Re: Sketchup CNC
Postby Scott M » Thu May 10, 2012 10:44 pm
noelwarr wrote:My head's about to explode.
I hope its not the icons
Scott M
Re: Sketchup CNC
Postby noelwarr » Fri May 11, 2012 4:44 pm
Hey guys. Well, this is really starting to come together. I guess you could say that we now have a solid foundation upon which to build. I'd bore you to bits with what the plugin does, how it does it and what it could do but I think I'll just sit back for the time being and wait for the questions to come.
There are a few minor issues with it not being an extention and not propperly integrated into the toolbar but I think I've earned a rest. The point is it works and I am now doing ALL my CNC work with it.
Big shout out to Scott for the icons and look forward to answering any questions. I'll be posting photos of CNC jobs on my Google+ stream so you know where to find me
todo list
..make it an extention
..improve ui (show/hide toolpaths, etc)
..get more files into the cnc folder (Especially a template one)
..get assemblies working (I tried but my head exploded)
..automatic toolpath/hole generation
noelwarr
Re: Sketchup CNC
Postby noelwarr » Fri May 18, 2012 8:22 pm
100% Sketchup CAM. 100% minivistii
noelwarr
Re: Sketchup CNC
Postby tim » Sun Jun 03, 2012 4:19 am
Seriously? Those are real tables and chairs made directly from SU output? Very cool!
tim
Re: Sketchup CNC
Postby noelwarr » Sun Jun 03, 2012 11:25 pm
Well, I'm not sure what you mean by "directly". There is nothing automatic about the process. All toolpaths have to be specified. But yes, it's all done within the Sketchup UI. From Sketchup to CNC.
noelwarr
Re: Sketchup CNC
Postby chrisadww » Wed Jun 27, 2012 2:50 pm
Hello
I am in the cabinet business and have used my Thermwood model 45 5' x 10' for the last four years. I use sketchup for all design work and convert skp surfaces to 2d toolpaths by exporting them to dxf. Layers are then created to identify tools, cutting depths etc. in the dxf. The Thermwood then converts these layers to G code.
Is a plug in available to automatically save selected surfaces to a 2d plane?
Chris
adwwinc.com
chrisadww
Re: Sketchup CNC
Postby Scott M » Wed Jul 04, 2012 6:58 pm
chrisadww wrote:Hello
Chris
adwwinc.com
Try this plugin http://rhin.crai.archi.fr/rld/plugin_details.php?id=753
Scott M
Re: Sketchup CNC
Postby beginner » Sat Sep 22, 2012 1:10 pm
Hi Guys,
This is the 19th September 2012 Grand Design - Series 7 Episode 4 with CNC in action...
http://www.channel4.com/programmes/gran ... od#3414075
CNC + REVIT = BUILDING :)
I wonder if that could be done with SU - I assume it could...
CNC + SketchUp = BUILDING :idea:
They are using MultiCam 1000 Series
http://www.multicam.com/eng/Products/1000series.html
I'm not sure if you can watch outside UK - maybe you could use some proxy servers to 'overcome the hurdle'... ;)
PS. I'm watching the topic closely :D
Regards, SU 'beginner'
beginner
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Beginner
Re: Sketchup CNC
Postby anthony.smith.email » Thu Nov 08, 2012 11:23 pm
Noel,
nice plugin. Good work. Your coding is better than mine. (I'm self taught on Ruby, so my code ain't so great).
I work in a factory which does hardly any solid timber, we do board and edgetape.
We have a nested-base machine - you know, a flat bed cnc. So my output has to be to "optimising software" (we use on old version of aspan) which nests the parts and writes the G-code. So I'm working on a plugin of my own...when I reach a meaningful milestone, I'll post it (in another thread).
Even though I can't really use your plugin for our work, your code can help me (make better code and give me better ideas.).
Regards,
Anthony
anthony.smith.email
Re: Sketchup CNC
Postby noelwarr » Mon Nov 12, 2012 10:56 am
Cheers Anthony.
Just last week I got mailed by someone else working on another CNC plugin. (http://sketchucation.com/forums/viewtopic.php?f=180&t=48781&p=439028#p438163) I got sent a screen shot and it looks quite promising.
It might be interesting to form a kind of common language between all of our plugins. A standard of sorts. I have a rough idea of how that might work. Would you be willing to work together a little?
noelwarr
Re: Sketchup CNC
Postby anthony.smith.email » Fri Nov 16, 2012 3:47 am
Hi Noel,
I'm always happy to jump onto a standard...but...I think my work is not actually closely aligned with the work you are doing...The Factory I work at makes kitchens.
My project:
1. in sketchup the user will construct a cabinet from rectangular prisms (dynamic components named Panel1,Panel2,Panel3,etc) eg 720mm x 538mm x 16mm.
2. They will be able to click on which of the 4 panel edges will have "edgetape" applied.
3. They will be able to place 5mmDrillHole dynamic components inside the Panel component. on one of the faces, for hinges, shelves etc.
4. Then group several panels into a cabinet, and specify a cabinet name, number etc.
5. The output will be a file which specifies the rectangle size, (adjusting for the thickness of the edgetape), and also where to drill the 5mm hole, and how deep.
6. This file will be imported into "nesting software" (in this case Aspan (http://www.autosoftware.it/index.php/en ... id-54.html)). This nesting software nests all the panels into a full sheet and writes gcode to cnc rout and drill the panels. and print labels to identify which cabinet and where to apply the edgetape.
7. I'll build up a library of dynamic components of cabinets containing panels containing drilling structures containing 5mmDrillHoles....for faster drawing. So I can resize the cabinet from the library, and the holes will update, and get drilled to suit...what-you-see-is-what-you-get drilling and panel sizes.
So, I'm happy to try to work together, but, I think our goals are different...
My Maths is good...I have a clear understanding of matrices, vectors, dot and cross products, transformations, etc....but my ruby is really bad, I didn't know till I read your code that you can "class something < Array"...and now I want to overhaul badly written code...
all is not lost...If we write clearly commented code, others can see how we achieved something and might be able to use/modify that for themselves.
I think that people generally will have to modify the output routines or write/modify their own postprocessors anyway....so my output code will be commented and structured so that others will be able to customise it to their own nesting software...
Regards,
Anthony
anthony.smith.email
Re: Sketchup CNC
Postby noelwarr » Mon Nov 19, 2012 11:23 am
Ah! I misread your earlier post. You're right. There is little our scripts can do for one another. Good luck writing it. Ruby is a great language and has a great community.
I wish I had commented my code. The code of the project I am working on now has little or nothing to do with my first plugin. I really feel I have come a long way. But still I don't comment it. :oops: I have no excuse.
I don't want to seem pedantic but if you were surprised about inheretance (MyClass < Array) make sure you get used to working with blocks...
my_array.each{|obj| obj.do_something }
I consider them to be the most ruby thing about ruby. A good sign that you're doing things the ruby way is if you have no for/while/until loops in your code. But he coolest thing about ruby is you can do things any way you want. So if you like loops, go for it! :)
noelwarr
Re: Sketchup CNC
Postby anthony.smith.email » Tue Nov 20, 2012 7:21 am
Hi Noel,
yeah, there is a little alignment, but not enough....
I didn't have any problem reading your code...you use meaningful class and variable names, and you write a blurb at the start...people can read it....
yeah i did learn and use the .each thing....I even found the .reverse thing too when I needed it...
I actually read a few tutorials, and had read about inheritance, but didn't make the connection for " < Array"...till I read your code...
I quite like ruby, but still have lots to learn...I'm a little worried it might run too slow when I have it working, and am concerned that badly written code runs slow too...
Regards,
Anthony
anthony.smith.email
Re: Sketchup CNC
Postby noelwarr » Tue Nov 20, 2012 9:59 am
Great to know you can read it! There are a few recursive methods there that are so obfuscated that even I can't figure out how they work! :D Wish I had commented them
I don't think you'll have much of a problem with speed. Apart from general good practices there are a few Sketchup specific ones too. Off the top of my head...
1) Interact with the model as little as possible.
2) Don't use
my_entity.typename == "Edge"
instead use
my_entity.is_a?(Sketchup::Edge)
If you have to perform "serious" stuff there are always c extensions. But I wouldn't head down that path if I were you.
Keep me posted on how you get on. I'm at gmail with this username.
noelwarr
Re: Sketchup CNC
Postby Futurepast » Mon Mar 11, 2013 1:53 am
So, it's been almost a year. Has there been any more progress? ;) OK not a year but for the impatient.......
Futurepast
SketchUp version: 8
License type: Pro
Re: Sketchup CNC
Postby Rich O Brien » Mon Mar 11, 2013 2:01 am
Futurepast wrote:So, it's been almost a year. Has there been any more progress? ;) OK not a year but for the impatient.......
Did you read this....?
http://sketchucation.com/catch-up/334-c ... edition-17
there's a preview in there
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
PreviousNext
Return to Woodworking
