SketchUcation Premium Membership
Invitation to the SketchUcation collection
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
Re: Invitation to the SketchUcation collection
Postby brandy20 » Fri Feb 13, 2009 6:10 pm
Dave, I understand your explanation, you talked about your technique in the cabinet project on th FWW blog. So it should be a quick job. I'll try it soon.
brandy20
Postby brandy20 » Fri Feb 13, 2009 10:16 pm
sorry guys, but I really can't get it! I can rotate the axex but I spent the entire evening in trying to rotate the texture!
This is what I do:
I choose the material, I apply it to the component and when I right click the mouse pointed on the texured face of the component I can't find the option Texture-rotate. Where am I wrong?
brandy20
Postby Dave R » Fri Feb 13, 2009 10:31 pm
The problem is that you applied the material to the component's "wrapper". That's my term. When you apply the material, open the component for editing, first. Then apply the material to the faces. Select one face that needs to have the material orientation edited, right click and you'll find Texture in the menu.
See if that helps.
Dave
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby brandy20 » Fri Feb 13, 2009 11:12 pm
thanks Dave, tomorrow morning (it's late now here) I'll try to fix the problem. I'll give you the feedback.
brandy20
Postby brandy20 » Sat Feb 14, 2009 12:06 pm
Mission accomplished!
brandy20
Postby Dave R » Sat Feb 14, 2009 3:48 pm
Good work! ;)
Global Moderator
License type: Pro
Postby Gaieus » Mon Feb 16, 2009 1:53 pm
To elaborate Dave's advice; you can only position a texture/material on a single face. "Not single faces" are (and the "Texture item thus doesn't even appear in the context menu):
  • groups/components - like in your case. Dave explained how to solve this.
  • curved/smoothed surfaces - let them be "really" curved or even just coplanar with a softened, dividing edge (in fact, these edges should be deleted instead of being dealt with like below). With curved/smoothed surfaces however you can do the following
    1. Go to View > Hidden geometry; this will reveal the "facets" building up a curved surface
    2. these facets can be manipulated like single faces - i.e. in this case you can position a texture on one
    3. Now select the Paint bucket tool :paint: and pres the Alt key > the tool will turn into an eyedropper/sampler tool
    4. sample the positioned material on the above "one" face
    5. Turn off hidden geometry (again; uncheck it in the View menu)
    6. Paint the whole, curved/smoothed surface with the positioned > sampled material.
Sounds to be a lot more complicated and longer than doing it with a little routine...
Administrator
License type: Pro
SketchUp use: historical reconstruction
Postby brandy20 » Fri Feb 27, 2009 3:26 pm
Good shot Gaeius! :thumb: I normally use the projection mode to texture curved surfaces and I'm going to try your method.
brandy20
Postby Gaieus » Sun Mar 01, 2009 3:16 pm
Projection is fast and handy but when the curve goes round too much, it is distorted on the sides. Or actually it is always distorted just in these cases it is too apparent.
With positioning however, though it may look "nicer", it is a bit tiresome.
Administrator
License type: Pro
Postby brandy20 » Sun Mar 01, 2009 6:27 pm
Actually I noticed that in a curved leg I made
brandy20
Postby ktkoh » Tue Apr 28, 2009 1:05 pm
Here are 2 new models that may meet the requirements for the collection. One is extra long twin bed made as a captians bed with drawers below the bed. The other is a twin pedestal dining room table.
Keith
http://sketchup.google.com/3dwarehouse/details?mid=f21822974c8c492085c5f690e9252fc5
http://sketchup.google.com/3dwarehouse/details?mid=615b800fb332525385c5f690e9252fc5
Edited link to Table
ktkoh
SketchUp version: 8
License type: Free/Make
Postby Dave R » Tue Apr 28, 2009 1:14 pm
Nice bed Keith.
Funny thing, though. The table looks like the bed. ;)
Global Moderator
License type: Pro
Postby Ericschimel » Thu May 28, 2009 8:33 pm
I just posted this model in another thread, but I think its appropriate here.... Its a dynamic, reconfigurable door. I use it all the time for my woodworking plans...
http://sketchup.google.com/3dwarehouse/ ... efa90a53a4
-Eric
http://www.SketchThis.Net
Sketchup Training & Videos
Custom Models
Ericschimel
Postby mics_54 » Sat Nov 14, 2009 3:34 pm
Thanks Eric
mics_54
SketchUp version: 8
Level of SketchUp: Beginner
Postby CactusMatt » Thu Apr 15, 2010 9:55 pm
http://sketchup.google.com/3dwarehouse/ ... revstart=0
This is the Heirloom Hope Chest orginally publised by Wood Magazine in Issue 142 (june/July 2002). I built this chest as a Christmas present to my wife in 2008.
From the original plans from Wood:
From my model:
CactusMatt
Postby mics_54 » Fri Apr 16, 2010 3:32 am
Excellent!
mics_54
SketchUp version: 8
Postby Ericschimel » Fri Apr 16, 2010 5:04 am
Nice model! I really like it.
Did you use LayOut, or the CutList plugin to figure out how to build it?
-Eric
Custom Models
Ericschimel
Postby CactusMatt » Fri Apr 16, 2010 6:12 pm
Gaieus wrote:To elaborate Dave's advice; you can only position a texture/material on a single face. "Not single faces" are (and the "Texture item thus doesn't even appear in the context menu):
Thanks for this Gaieus!
I cannot tell you the frustration I've had when trying to tweak some textures on certain surfaces that 'appeared' flat. The "Texture" part of the right-click menu just did not show up (as in the post above). All of these problem-surfaces (it turns out) had some kind of rounded edge-treatment applied (using follow-me). Using your advice, I was able to go back into several of my models and turn-on hidden geometry. Voila! -- I was able to isolate my flat-surfaces ad scale my textures the way I wanted.
CactusMatt
Postby Laxian Key » Fri Nov 12, 2010 4:21 am
My first complex model in SketchUp. This is my interpretation of Christian Becksvoort's Shaker Collector Cabinet.
Laxian Key
Postby Dave R » Fri Nov 12, 2010 4:25 am
Interesting cabinet. It's a pretty big file for such a small cabinet. I purged unused stuff and got rid of 26 unused components and 4 unused materials. If you'd apply the materials to the faces instead of the components, you could eliminate one each of the Cherry and Maple materials. And why are the knobs buried in 17 component levels? The knobs are rather high poly for no larger than they are.
Why are there two copies of the right side panel in the same space? And why do you have a single group inside a component? There's a lot of unneeded nesting going on throughout. This makes it difficult to work with the model. I found three drawer sides in one component. So if you want to open one of those drawers, all three of those sides move out at the same time.
I'm not trying to be critical but I think your modeling could be a lot easier. It all looks like you're working pretty hard and you should need to do that.
By the way, where did you find this piece? I'm working on larger a Becksvoort Shaker piece right now. I've already done his little Classic Shaker table with two leg options and a chest of drawers
Global Moderator
License type: Pro
Postby Laxian Key » Fri Nov 12, 2010 4:41 am
I'm new to SketchUp and there is still a lot I have to learn. I had already finished the knobs before I saw Tim Killen's video about Shaker Knobs on another blog.
I had seen this cabinet in a couple of different publications and I wanted to get the proportions and approximate measurements in case my woodworking skills take a quantum leap...
Laxian Key
Postby Dave R » Fri Nov 12, 2010 4:55 am
The SketchUp stuff and the woodworking will come.
Are you going to build this piece? Hand cut all those dovetails? That'll make your woodworking skills take that leap. After this piece you'll be able to cut those dovetails with your eyes closed. :D
Global Moderator
License type: Pro
Postby davidheim1 » Fri Nov 12, 2010 4:17 pm
Here's a small Arts & Crafts table I designed recently. It features legs with a subtle curve on their outside edges and through-tenons to hold the stretchers to the legs. The stretchers join with a half-lap joint.
If this model passes muster, I'll share others.
David Heim
http://sketchup.google.com/3dwarehouse/ ... 27361b2733
davidheim1
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby Dave R » Fri Nov 12, 2010 4:39 pm
Nice little table, David. Are you building it after the Bombé chest? :)
Global Moderator
License type: Pro
Postby davidheim1 » Mon Nov 15, 2010 4:36 pm
No, Dave, the little table comes first. It's something I'm actually capable of building. The bombe chest is another story. That one's going to exist strictly in SketchUp for a very long time.
I'll try to add the file for the current model. I just refined the feet to model the ball-and-claw detail more completely.
davidheim1
SketchUp version: 8
License type: Pro
Postby Dave R » Tue Nov 16, 2010 3:25 pm
Those ball-and-claw feet look better. They are a bit of a challenge to do. It's something I want to do a blog post on when I have time to work out a good method that I can do and describe.
Global Moderator
License type: Pro
Postby davidheim1 » Sun Jan 09, 2011 8:23 pm
Here's a link to my latest model: The Governor Winthrop Secretary, featured in the 1957 book "Heirloom Furniture," by Franklin Gottschall. At one level, modeling a complex piece like this is akin to building a scale model of the Titanic out of toothpicks. A secretary has so many components, small bits, hidden elements. Modeling all that stuff is an exercise in self-satisfaction. However, this particular piece has some challenging elements: the round medallions on the gooseneck molding (done with a Curviloft plug-in), the flame finial, the carvings on the gallery doors and drawers (Curviloft again), and the ball-and-claw feet. Modeling those sharpens one's SketchUp skills considerably.
I'd appreciate feedback of all kinds. Let me know what you think of the model.
Many thanks,
dh
http://sketchup.google.com/3dwarehouse/ ... 53cf0a14c9
davidheim1
SketchUp version: 8
License type: Pro
Postby chrisjk » Sun Jan 09, 2011 10:24 pm
Seems like a very nice job with most of the joinery sufficiently detailed to build it from the model. There is the odd small face missing here and there but that doesn't amount to anything serious at all.
I think the ball and claw feet could do with more work - the claws especially seem to lack definition (although not knowing this piece, they might be like that) but I am used to seeing knuckles on the talons which need to hug the balls more closely..
Chris
chrisjk
Postby davidheim1 » Mon Jan 10, 2011 12:18 am
chrisjk wrote:Seems like a very nice job with most of the joinery sufficiently detailed to build it from the model. There is the odd small face missing here and there but that doesn't amount to anything serious at all.
You're right that the feet could use some added definition. To make them, I take a profile of the foot, give it some thickness, copy and rotate the profile, then intersect the copies and remove the waste. After that, I extrude a ball and scale it until it fits the space in the foot (more or less). I was feeling pretty smug that I'd figured out how to take the modeling even that far. I've tried without success to figure out how to give the talons more definition. So I'm open to any suggestions. How would you do the feet?
Thanks,
dh
davidheim1
SketchUp version: 8
License type: Pro
Postby chrisjk » Mon Jan 10, 2011 10:10 am
David,
I think my approach would be to wrap a torus round a sphere, intersecting stuff as required to give me the necessary arc lengths, then to cheat a little (or a lot) and use the free training edition of this plugin ( http://www.tgi3d.com/index.php?Page=Download ) to thicken/thin the tube as required to make knuckles. I have not tried to give them any particular shape here - just illustrating the resizing possibilities of the plugin.
Other approaches might use Fredo's Tools on Surface to draw the lines for the talons directly on the ball, without cutting up a torus and then use pipe along path or tube along path to create the claws.
Again, one could employ a method like the one below where I made a radial array of circles (no need for a full circular array of course, then used the MOVE tool on the cardinal points to resize a couple of the circles then used Fredo's Curviloft to skin them.
Chris
chrisjk
Not a Premium Member yet? Check out the great time-limited deal we are offering.
PreviousNext
Return to Woodworking
