Bear with me as this is very complicated and I'm looking for a guru to enlighten me.
I am modelling some 3d wall structures (indoor climbing walls) That are made from panels of plywood that are tessellated to some degree and joint together by way of bisected angles. To start with I model the basic look of the wall and features and then create individual components for each of the tessellations. These are all in flat shapes to start with, then I extrude the shapes to 18mm to model the thickness of the ply. As the joining panels are at different angles to each other they have to be bevel cut at the bisected angle. Is there a quicker way to draw in the lines where they bisect and to get this angle on the finished components. I then copy the components away from the structure and add all the dimensions to it etc. All this is so I can produce a cutting list to make production quicker in the workshop. Currently I am having to use guides and am drawing them individually. Is there some kind of plug in that can do all this ?
Provided pictures below.
Simon
