[Obsolete] Offset On Surface (v1.0)
Re: [Plugin] Offset On Surface (v1.0)
Postby ely862me » Sat Apr 12, 2008 2:26 am
ok ok now is serious... :ecstatic: .... u*re the man.... :thumb:
Thx a lot!
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
ely862me
Top SketchUcator
Postby Marian » Sat Apr 12, 2008 12:23 pm
I've been waiting for this tool for years:P
THANK YOU THANK YOU THANK YOU :ecstatic:
Marian
Postby Dan » Sat Apr 12, 2008 12:27 pm
Just found out about this :oops:
Very useful idea and amazing new possibilities.
What more can I say other than a big "Thank you!" ?
Dan
Postby notareal » Sat Apr 12, 2008 6:37 pm
Thank you a lot.
notareal
Thea Render Support
Thea Render Support
Postby majid » Sun Apr 13, 2008 3:30 am
all my thanx to you for this jewel :thumb:
My perspective shortcuts book: https://bit.ly/30Tdbce
majid
Top SketchUcator
Postby Daniel S » Sun Apr 13, 2008 4:06 pm
I was thinking about JPP and OOS and how you take out the SketchUp limitations.
They are every-day use tools and replace the original ones.
The idea of improving the drape tool or the smoove tool like they are talking on other topic is great and can change the way we are using SketchUp... in fact, with JPP and OOS you change the way I use it. Thank you!!!
Just another idea... the follow me tool has limitationts too.. you can´t take a curved face and you can´t take more than one path to follow.
Daniel S
Daniel S
Postby glenal » Mon Apr 14, 2008 9:53 am
Thanks a lot. this is just too good!
glenal
Postby sigue2000 » Mon Apr 14, 2008 9:55 am
Thank you! This is great work. :ecstatic:
sigue2000
Postby el.antuan » Tue Apr 15, 2008 2:37 pm
Another guy saying: THANKS IN DEED!!!
Fantastic!! Thanks a lot!!!
Regards 8-) :
Antonio.
(PS: In spanish: ¡Cojonudo! ¡¡la pera limonera!! ¡la berza! ¡Este programa y esta web son la leche!!)
"En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
el.antuan
Postby otb designworks » Tue Apr 15, 2008 3:32 pm
Just beautiful!
Thank you thank you!!
Cheers, Chuck
OTB Designworks is on Youtube
otb designworks
Postby Baker518 » Fri Apr 18, 2008 2:32 am
I really like the possibilities and potential this script has. This is superb work.
...but, I have a question? When I pull the off-set, the edges are contoured, so they don't have a discernible face to each side. Is this correct or am I doing something wrong?
Let me know and thanks again, this is a gem for sure
Mike
Don't worry about things you have no control over. Worry is a lack of Faith!
Baker518
Postby Razor681 » Fri Apr 18, 2008 1:47 pm
Fredo, this thing is AWESOME!!!!!
Your plugin ROCKS!
:ecstatic: :ecstatic: :ecstatic: :ecstatic: :ecstatic:
Razor681
Postby fredo6 » Fri Apr 18, 2008 7:43 pm
Baker518 wrote:...but, I have a question? When I pull the off-set, the edges are contoured, so they don't have a discernible face to each side. Is this correct or am I doing something wrong?
Mike
Mike,
I suspect this is related to the question of edge style but I am afraid I would need a picture or a SKP sample to see what is the problem, and if this is a problem that can be solved. Thanks to post it.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Baker518 » Sat Apr 19, 2008 12:36 am
Here you go Fred
Baker518
Postby fredo6 » Sat Apr 19, 2008 7:53 am
I think I understand now.
When you offset, the new contour is generated as a curve (you can change this by toggling F9).
Then, a Joint Push Pull will consider that because the contour is a curve, the edges have to be generated as Soft and Smooth. This behavior actually is natural in most situations where you push pull a curved surface (for instance generated from Sand Box).
Of course, it is possible to introduce options for all these behaviors, as it would anyway difficult for the script to decide by itself!
fredo6
PluginStore Author
PluginStore Author
Postby juanjo06 » Wed May 14, 2008 6:13 pm
thanks guys.... in the plugins crai web this script is not working... maybe this realy does :bounce:
juanjo06
Re: [Obsolete] Offset On Surface (v1.0)
Postby Einstein » Wed Jun 06, 2018 9:46 am
Hi!
I know, it's a dusted thread but maybe someone will make me know.
Is it possible that Offset on Surface would treat separately several neighbouring surfaces selected at one time? I mean, instead of creating one big offset from selection border, it would make several offsets, each out of one surface separately.
Einstein
Postby fredo6 » Wed Jun 06, 2018 2:46 pm
Einstein wrote:Hi!
Not sure I understand. Could you be more precise or give a concrete example.
Fredo
PS: you can use the Thread of ToolsOnSurface, or start a new discussion thread for this subject.
fredo6
PluginStore Author
PluginStore Author
Previous
Return to Developers' Forum
Users browsing this forum: moom88 and 10 guests
