Resolve [Ruby help] Script for create window sills
Postby benj59380 » Fri Nov 08, 2019 2:04 pm
Hello , Today I wanted Creat script for window sills
my approach is create face manuel
click for select
run script
( part 1 : select face , creat color , Push -30 mm
Part 2 : select vertical face for push +30)
Part 1 work , but Part 2 fail :(
But Ruby = SyntaxError help me please for resolve the problem ;)
thank you in advance , Benjamin
#part 1
model = Sketchup.active_model
ent = model.entities
sel = model.selection
ad = sel.ent
faces = []
sel.each do |e|
faces <<e if e.is_a? Sketchup::Face
faces.each do |appui|
appuicolor = Sketchup::Color.new(238,130,238)
appui.material = appuicolor
appui.back_material = appuicolor
status = appui.pushpull(-30.mm , true)
#part 2
ad.each do |e|
s=Sketchup.active_model.selection;
a=s.to_a;s.clear;
a.grep(Sketchup::Face).each{|f|s.add(f)if f.normal.z==0}
faces.each do |facade|
status = facade.pushpull(30.mm )
benj59380
Re: [Ruby help] Script for create window sills
Postby sdmitch » Sat Nov 09, 2019 7:40 pm
Part 1 works if you delete or comment out the ad=sel.ent statement which is invalid.
Part 2 doesn't work because the faces created by the pushpull operation are not automatically added to the selection. Also you reuse the faces array which only contains the original faces selected.
Here is how I would do it
Code: Select all
mod = Sketchup.active_model
ent = mod.active_entities
sel = mod.selection
SKETCHUP_CONSOLE.clear
sel.grep(Sketchup::Face).each do |appui|
  old = ent.to_a
  new = ent.to_a - old
  new.grep(Sketchup::Face).select{|f|f.normal.z==0}.each{|f|f.pushpull 30.mm}
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby benj59380 » Tue Nov 12, 2019 8:27 am
hello , Thank you SDMITCH for help ;)
cordially Benj
benj59380
Return to Developers' Forum
