angle_between issue
angle_between issue
Postby rinse04 » Wed Sep 25, 2019 9:19 am
Hi guys wonder if someone can help.
I am trying to differentiate the difference between an internal corner and an external corner to get two different angles as shown in the below image.
This is the code I am using, which is returning the same angle for all...?
Code: Select all
puts (sel[0].faces[0].normal.angle_between (sel[0].faces[1].normal)).radians
Any help would be greatly appreciated.
rinse04
Re: angle_between issue
Postby fredo6 » Thu Sep 26, 2019 2:12 am
rinse04 wrote:I am trying to differentiate the difference between an internal corner and an external corner to get two different angles as shown in the below image.
angle_between() returns the angle between 0 and 180 degrees. If you wish the oriented angle, you need to set a reference of some sort to distinguish between concave and convex angles. Look at your model, and make abstraction of the walls, keeping only the vectors, and you'll see that none can make a difference between inside and outside.
Usually, if you have vectors v1 and v2, say in the horizontal plane, then
(v1 * v2) % Z_AXIS is either positive or negative. Now, up to you, based on conventions to consider this is an internal or external angle.
Fredo
fredo6
PluginStore Author
PluginStore Author
Return to Developers' Forum
Users browsing this forum: No registered users and 11 guests
